SGTL5000 RESET
SGTL5000 RESET
5,259 次查看
敏周安井
We have a custom board with i.MX6SX and a SGTL5000 chip. On that board we are running Linux built with Yocto  and kernel . we have experienced an issue. we play sound on SGTL5000 and after The SGTL5000 registers have been reset.
What is the condition under which the SGTL5000 registers are reset?
标记 (1)
8 回复数
5,072 次查看
igorpadykov
Hi 敏周 安井
reset may be caused by power supply issues, so one can check hardware.
To narrow down issue, one can run sdk sgtl5000 bare metal test (zip can be found on link
SMP Enable in IMX6 )
for linux one can try third party bsps which support sgtl5000 (like BD sabrelite board)
linux-imx6/imx6qdl-sabrelite.dtsi at boundary-imx_4.9.x_8mq_ga-pass1-ath10k · boundarydevices/linux-...
5,072 次查看
敏周安井
Hi igor
Thank you for your message.
VDDIO and VDDA are used at 3.3v.
How many volts between VDDIO and GND get reset?
And
How many volts between VDDA and GND get reset?
5,072 次查看
igorpadykov
Hi 敏周 安井
one can refer to p.9 Table 7. Dynamic Electrical Characteristics SGTL5000 datasheet
https://www.nxp.com/docs/en/data-sheet/SGTL5000.pdf
5,072 次查看
敏周安井
Hi igor
I am saying that what is written in the data sheet is a power-up.
I want to know how many volts are reset at power down.
5,072 次查看
igorpadykov
>reset at power down
could you clarify what this means
5,069 次查看
敏周安井
Hi igor
I created the material.
Do you see the materials and understand my question?
5,069 次查看
igorpadykov
Hi 敏周 安井
thanks for the material. Regarding your question - voltage sags are allowed
in range defined for VDDA in Table 3. Recommended Operating Conditions
SGTL5000 datasheet.
5,069 次查看
敏周安井
Hi igor
Thank you very much.
