SDMA only 32 bits addressing?
1,103 次查看
niklasbergdahl
Is there some possibility/solution for using SDMA engine for data transfer to memory address > 4GB?
1,092 次查看
igorpadykov
Hi Niklas
sorry not possibe, in particular access above 4GB is described in sect.2.1.2 Cortex-A53 Memory Map
as "Quad-A53 only"
i.MX 8M Dual/8M QuadLite/8M Quad Applications Processors Reference Manual
1,093 次查看
igorpadykov
Hi Niklas
as "Quad-A53 only"
