csi parallel question
2,369 次查看
yoonseok
At a resolution of 640x480, 120fps frames.
Can I get the camera image?
in i.mx8 csi Parallel interface
5 回复数
2,357 次查看
yoonseok
i.mx series would be great.
i.mx6dq is better
2,353 次查看
joanxie
i.mx6qd IPU can support up to 240Mhz, so can support 640x480@120fps
2,351 次查看
yoonseok
Did you actually experience it?
I'm going to decide on a spec now.
If it's nxp Techsupport, can I officially trust you and proceed?
2,309 次查看
joanxie
you can refer to the reference manual, and calculate by yourself if you believe in reference manual, pls refer  to the chapter 37.1.2.1.1 Camera Ports of imx6q reference manual
2,361 次查看
joanxie
what imx8 do you mention? imx8qm?
