SDIO card enumeration problem on Android marshamallow
3,845 次查看
susangracerapak
I am working on porting my WIFI driver on Android marshmallow for Sabresd board. I have ported for USB successfully.for SDIO,the enumeration is failed.I have observed that , by default only BCMDHD module can used here.
How to use my own SDIO card ?
Can anyone help me ?
Susan
3,683 次查看
Hi Susan
you should obtain driver (compatible with used linux kernel version) from
vendor of custom wifi sdio card and include it in linux image, BCMDHD module
can be removed from image using attached Linux Manual sect.4.12.2.3 Menu Configuration Options.
