Hi, i facing the error "MMC: no card present" in uboot. Below are the logs when booting up.
U-Boot SPL 2022.04-daviscomms+gcd10348f3e (Jun 20 2023 - 07:22:21 +0000)
DDRINFO: start DRAM init
DDRINFO: cfg clk
DDRINFO: DRAM rate 4000MTS
DDRINFO: ddrc config start
DDRINFO: ddrc config done
DDRINFO:ddrphy config start
DRAM PHY training for 4000MTS
check ddr_pmu_train_imem code
check ddr_pmu_train_imem code pass
check ddr4_pmu_train_dmem code
check ddr_pmu_train_dmem code pass
[PMU Major message = 0x0000000d]
[PMU Major message = 0x00000000]
[PMU Major message = 0x00000002]
[PMU Major message = 0x00000001]
[PMU Major message = 0x0000000a]
[PMU Major message = 0x000000fd]
[PMU Major message = 0x000000fe]
[PMU Major message = 0x00000004]
[PMU Major message = 0x00000003]
[PMU Major message = 0x00000009]
[PMU Major message = 0x00000007]
Training PASS
DRAM PHY training for 400MTS
Training PASS
DRAM PHY training for 100MTS
Training PASS
[PMU Major message = 0x00000006]
[PMU Major message = 0x00000005]
Training PASS
DDRINFO: ddrphy config done
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
SEC0: RNG instantiated
Normal Boot
Trying to boot from BOOTROM
Boot Stage: Recovery boot
image offset 0x8000, pagesize 0x200, ivt offset 0x0
NOTICE: BL31: v2.6(release):automotive-13.0.0_1.1.0-0-g3c1583ba0
NOTICE: BL31: Built : 11:00:38, Nov 21 2022
U-Boot 2022.04-daviscomms+gcd10348f3e (Jun 20 2023 - 07:22:21 +0000)
CPU: i.MX8MP[8] rev1.1 1600 MHz (running at 1200 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 31C
Reset cause: POR
Model: NXP i.MX8MPlus LPDDR4 EVK board
DRAM: 6 GiB
Core: 74 devices, 23 uclasses, devicetree: separate
MMC: FSL_SDHC: 1, FSL_SDHC: 2
Loading Environment from MMC... MMC: no card present
*** Warning - No block device, using default environment
Fail to setup video link
In: serial
Out: serial
Err: serial
BuildInfo:
- ATF 3c1583b
flash target is MMC:1
MMC card init failed!
** Block device MMC 1 not supported
Net:
Warning: ethernet@30bf0000 (eth1) using random MAC address - a2:90:58:27:b0:b4
eth1: ethernet@30bf0000 [PRIME]
Fastboot: Normal
Normal Boot
Hit any key to stop autoboot: 0
starting USB...
Bus usb@38100000: Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
Bus usb@38200000: Register 2000140 NbrPorts 2
USB XHCI 1.10
scanning bus usb@38100000 for devices... 1 USB Device(s) found
scanning bus usb@38200000 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
Device 0: unknown device
switch to partitions #0, OK
mmc2(part 0) is current device
** No partition table - mmc 2 **
Couldn't find partition mmc 2:1
Running BSP bootcmd ...
Couldn't find partition mmc 1:1
Can't set block device
Booting from net ...
ethernet@30bf0000 Waiting for PHY auto negotiation to complete.......
解決済! 解決策の投稿を見る。
Sorry,
I based on the u-boot lf_v2021.04 (tag lf-5.10.72-2.2.3). Yours seems to be more recent.
I would say that one needs to check the hardware interface to the SD card.
Khang
Hi @Jimmychea,
Is the GPIO dedicated to SD2_nCD well configured and wired ?
Do you also use eMMC on your custom board ?
Would it be possible to share the relevant schematic and/or device-tree and board configuration (in <u-boot>/include/<board-name>.h) ?
Khang
1. The schematic for SD2_nCD attached.
2. Yes, also using eMMC.
Device Tree
// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
* Copyright 2019 NXP
/dts-v1/;
#include <dt-bindings/usb/pd.h>
#include "imx8mp.dtsi"
model = "NXP i.MX8MPlus LPDDR4 EVK board";
compatible = "fsl,imx8mp-evk", "fsl,imx8mp";
chosen {
bootargs = "console=ttymxc1,115200";
stdout-path = &uart2;
gpio-leds {
compatible = "gpio-leds";
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_gpio_led>;
status {
label = "yellow:status";
gpios = <&gpio3 16 GPIO_ACTIVE_HIGH>;
default-state = "on";
memory@40000000 {
device_type = "memory";
reg = <0x0 0x40000000 0 0xc0000000>,
<0x1 0x00000000 0 0xc0000000>;
reg_usdhc2_vmmc: regulator-usdhc2 {
compatible = "regulator-fixed";
pinctrl-0 = <&pinctrl_reg_usdhc2_vmmc>;
regulator-name = "VSD_3V3";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
gpio = <&gpio2 19 GPIO_ACTIVE_HIGH>;
enable-active-high;
startup-delay-us = <100>;
off-on-delay-us = <12000>;
&eqos {
pinctrl-0 = <&pinctrl_eqos>;
phy-mode = "rgmii-id";
phy-handle = <ðphy0>;
status = "okay";
mdio {
compatible = "snps,dwmac-mdio";
#address-cells = <1>;
#size-cells = <0>;
ethphy0: ethernet-phy@1 {
compatible = "ethernet-phy-ieee802.3-c22";
reg = <1>;
eee-broken-1000t;
&i2c1 {
clock-frequency = <400000>;
pinctrl-names = "default", "gpio";
pinctrl-0 = <&pinctrl_i2c1>;
pinctrl-1 = <&pinctrl_i2c1_gpio>;
scl-gpios = <&gpio5 14 GPIO_ACTIVE_HIGH>;
sda-gpios = <&gpio5 15 GPIO_ACTIVE_HIGH>;
status = "okay";
pmic: pca9450@25 {
reg = <0x25>;
compatible = "nxp,pca9450c";
/* PMIC PCA9450 PMIC_nINT GPIO1_IO3 */
pinctrl-0 = <&pinctrl_pmic>;
gpio_intr = <&gpio1 3 GPIO_ACTIVE_LOW>;
regulators {
#size-cells = <0>;
pca9450,pmic-buck2-uses-i2c-dvs;
/* Run/Standby voltage */
pca9450,pmic-buck2-dvs-voltage = <950000>, <850000>;
buck1_reg: regulator@0 {
reg = <0>;
regulator-compatible = "buck1";
regulator-min-microvolt = <600000>;
regulator-max-microvolt = <2187500>;
regulator-boot-on;
regulator-always-on;
regulator-ramp-delay = <3125>;
buck2_reg: regulator@1 {
reg = <1>;
regulator-compatible = "buck2";
regulator-boot-on;
buck4_reg: regulator@3 {
reg = <3>;
regulator-compatible = "buck4";
regulator-max-microvolt = <3400000>;
regulator-boot-on;
buck5_reg: regulator@4 {
reg = <4>;
regulator-compatible = "buck5";
regulator-boot-on;
buck6_reg: regulator@5 {
reg = <5>;
regulator-compatible = "buck6";
regulator-boot-on;
ldo1_reg: regulator@6 {
reg = <6>;
regulator-compatible = "ldo1";
regulator-min-microvolt = <1600000>;
regulator-boot-on;
ldo2_reg: regulator@7 {
reg = <7>;
regulator-compatible = "ldo2";
regulator-min-microvolt = <800000>;
regulator-max-microvolt = <1150000>;
regulator-boot-on;
ldo3_reg: regulator@8 {
reg = <8>;
regulator-compatible = "ldo3";
regulator-boot-on;
ldo4_reg: regulator@9 {
reg = <9>;
regulator-compatible = "ldo4";
regulator-boot-on;
ldo5_reg: regulator@10 {
reg = <10>;
regulator-compatible = "ldo5";
regulator-min-microvolt = <1800000>;
&i2c2 {
pinctrl-0 = <&pinctrl_i2c2>;
pinctrl-1 = <&pinctrl_i2c2_gpio>;
scl-gpios = <&gpio5 16 GPIO_ACTIVE_HIGH>;
sda-gpios = <&gpio5 17 GPIO_ACTIVE_HIGH>;
status = "okay";
&i2c3 {
clock-frequency = <100000>;
pinctrl-0 = <&pinctrl_i2c3>;
pinctrl-1 = <&pinctrl_i2c3_gpio>;
scl-gpios = <&gpio5 18 GPIO_ACTIVE_HIGH>;
sda-gpios = <&gpio5 19 GPIO_ACTIVE_HIGH>;
status = "okay";
&i2c4 {
pinctrl-0 = <&pinctrl_i2c4>;
pinctrl-1 = <&pinctrl_i2c4_gpio>;
scl-gpios = <&gpio5 20 GPIO_ACTIVE_HIGH>;
sda-gpios = <&gpio5 21 GPIO_ACTIVE_HIGH>;
status = "okay";
&snvs_pwrkey {
status = "okay";
&uart2 {
/* console */
pinctrl-0 = <&pinctrl_uart2>;
status = "okay";
&usb3_phy0 {
status = "okay";
&usb3_0 {
status = "okay";
&usb_dwc3_0 {
status = "okay";
&usb3_phy1 {
status = "okay";
&usb3_1 {
status = "okay";
&usb_dwc3_1 {
status = "okay";
&usdhc2 {
pinctrl-names = "default", "state_100mhz", "state_200mhz";
pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>;
pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>;
pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>;
cd-gpios = <&gpio2 12 GPIO_ACTIVE_LOW>;
vmmc-supply = <®_usdhc2_vmmc>;
bus-width = <4>;
status = "okay";
&usdhc3 {
pinctrl-0 = <&pinctrl_usdhc3>;
pinctrl-1 = <&pinctrl_usdhc3_100mhz>;
pinctrl-2 = <&pinctrl_usdhc3_200mhz>;
bus-width = <8>;
non-removable;
status = "okay";
&wdog1 {
pinctrl-0 = <&pinctrl_wdog>;
fsl,ext-reset-output;
status = "okay";
&iomuxc {
pinctrl_eqos: eqosgrp {
fsl,pins = <
MX8MP_IOMUXC_ENET_MDC__ENET_QOS_MDC 0x3
MX8MP_IOMUXC_ENET_MDIO__ENET_QOS_MDIO 0x3
MX8MP_IOMUXC_ENET_RD0__ENET_QOS_RGMII_RD0 0x91
MX8MP_IOMUXC_ENET_RD1__ENET_QOS_RGMII_RD1 0x91
MX8MP_IOMUXC_ENET_RD2__ENET_QOS_RGMII_RD2 0x91
MX8MP_IOMUXC_ENET_RD3__ENET_QOS_RGMII_RD3 0x91
MX8MP_IOMUXC_ENET_RXC__CCM_ENET_QOS_CLOCK_GENERATE_RX_CLK 0x91
MX8MP_IOMUXC_ENET_RX_CTL__ENET_QOS_RGMII_RX_CTL 0x91
MX8MP_IOMUXC_ENET_TD0__ENET_QOS_RGMII_TD0 0x1f
MX8MP_IOMUXC_ENET_TD1__ENET_QOS_RGMII_TD1 0x1f
MX8MP_IOMUXC_ENET_TD2__ENET_QOS_RGMII_TD2 0x1f
MX8MP_IOMUXC_ENET_TD3__ENET_QOS_RGMII_TD3 0x1f
MX8MP_IOMUXC_ENET_TX_CTL__ENET_QOS_RGMII_TX_CTL 0x1f
MX8MP_IOMUXC_ENET_TXC__CCM_ENET_QOS_CLOCK_GENERATE_TX_CLK 0x1f
MX8MP_IOMUXC_SAI2_RXC__GPIO4_IO22 0x19
pinctrl_gpio_led: gpioledgrp {
fsl,pins = <
MX8MP_IOMUXC_NAND_READY_B__GPIO3_IO16 0x19
pinctrl_i2c1: i2c1grp {
fsl,pins = <
MX8MP_IOMUXC_I2C1_SCL__I2C1_SCL 0x400001c3
MX8MP_IOMUXC_I2C1_SDA__I2C1_SDA 0x400001c3
pinctrl_i2c2: i2c2grp {
fsl,pins = <
MX8MP_IOMUXC_I2C2_SCL__I2C2_SCL 0x400001c3
MX8MP_IOMUXC_I2C2_SDA__I2C2_SDA 0x400001c3
pinctrl_i2c3: i2c3grp {
fsl,pins = <
MX8MP_IOMUXC_I2C3_SCL__I2C3_SCL 0x400001c3
MX8MP_IOMUXC_I2C3_SDA__I2C3_SDA 0x400001c3
pinctrl_i2c4: i2c4grp {
fsl,pins = <
MX8MP_IOMUXC_I2C4_SCL__I2C4_SCL 0x400001c3
MX8MP_IOMUXC_I2C4_SDA__I2C4_SDA 0x400001c3
pinctrl_i2c1_gpio: i2c1grp-gpio {
fsl,pins = <
MX8MP_IOMUXC_I2C1_SCL__GPIO5_IO14 0x1c3
MX8MP_IOMUXC_I2C1_SDA__GPIO5_IO15 0x1c3
pinctrl_i2c2_gpio: i2c2grp-gpio {
fsl,pins = <
MX8MP_IOMUXC_I2C2_SCL__GPIO5_IO16 0x1c3
MX8MP_IOMUXC_I2C2_SDA__GPIO5_IO17 0x1c3
pinctrl_i2c3_gpio: i2c3grp-gpio {
fsl,pins = <
MX8MP_IOMUXC_I2C3_SCL__GPIO5_IO18 0x1c3
MX8MP_IOMUXC_I2C3_SDA__GPIO5_IO19 0x1c3
pinctrl_i2c4_gpio: i2c4grp-gpio {
fsl,pins = <
MX8MP_IOMUXC_I2C4_SCL__GPIO5_IO20 0x1c3
MX8MP_IOMUXC_I2C4_SDA__GPIO5_IO21 0x1c3
pinctrl_pmic: pmicirq {
fsl,pins = <
MX8MP_IOMUXC_GPIO1_IO03__GPIO1_IO03 0x41
pinctrl_reg_usdhc2_vmmc: regusdhc2vmmc {
fsl,pins = <
MX8MP_IOMUXC_SD2_RESET_B__GPIO2_IO19 0x41
pinctrl_uart2: uart2grp {
fsl,pins = <
MX8MP_IOMUXC_UART2_RXD__UART2_DCE_RX 0x140
MX8MP_IOMUXC_UART2_TXD__UART2_DCE_TX 0x140
pinctrl_usdhc2: usdhc2grp {
fsl,pins = <
MX8MP_IOMUXC_SD2_CLK__USDHC2_CLK 0x190
MX8MP_IOMUXC_SD2_CMD__USDHC2_CMD 0x1d0
MX8MP_IOMUXC_SD2_DATA0__USDHC2_DATA0 0x1d0
MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d0
MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d0
MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d0
MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc1
pinctrl_usdhc2_100mhz: usdhc2-100mhzgrp {
fsl,pins = <
MX8MP_IOMUXC_SD2_CLK__USDHC2_CLK 0x194
MX8MP_IOMUXC_SD2_CMD__USDHC2_CMD 0x1d4
MX8MP_IOMUXC_SD2_DATA0__USDHC2_DATA0 0x1d4
MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d4
MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d4
MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d4
pinctrl_usdhc2_200mhz: usdhc2-200mhzgrp {
fsl,pins = <
MX8MP_IOMUXC_SD2_CLK__USDHC2_CLK 0x196
MX8MP_IOMUXC_SD2_CMD__USDHC2_CMD 0x1d6
MX8MP_IOMUXC_SD2_DATA0__USDHC2_DATA0 0x1d6
MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d6
MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d6
MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d6
pinctrl_usdhc2_gpio: usdhc2gpiogrp {
fsl,pins = <
MX8MP_IOMUXC_SD2_CD_B__GPIO2_IO12 0x1c4
pinctrl_usdhc3: usdhc3grp {
fsl,pins = <
MX8MP_IOMUXC_NAND_WE_B__USDHC3_CLK 0x190
MX8MP_IOMUXC_NAND_WP_B__USDHC3_CMD 0x1d0
MX8MP_IOMUXC_NAND_DATA04__USDHC3_DATA0 0x1d0
MX8MP_IOMUXC_NAND_DATA05__USDHC3_DATA1 0x1d0
MX8MP_IOMUXC_NAND_DATA06__USDHC3_DATA2 0x1d0
MX8MP_IOMUXC_NAND_DATA07__USDHC3_DATA3 0x1d0
MX8MP_IOMUXC_NAND_RE_B__USDHC3_DATA4 0x1d0
MX8MP_IOMUXC_NAND_CE2_B__USDHC3_DATA5 0x1d0
MX8MP_IOMUXC_NAND_CE3_B__USDHC3_DATA6 0x1d0
MX8MP_IOMUXC_NAND_CLE__USDHC3_DATA7 0x1d0
MX8MP_IOMUXC_NAND_CE1_B__USDHC3_STROBE 0x190
pinctrl_usdhc3_100mhz: usdhc3-100mhzgrp {
fsl,pins = <
MX8MP_IOMUXC_NAND_WE_B__USDHC3_CLK 0x194
MX8MP_IOMUXC_NAND_WP_B__USDHC3_CMD 0x1d4
MX8MP_IOMUXC_NAND_DATA04__USDHC3_DATA0 0x1d4
MX8MP_IOMUXC_NAND_DATA05__USDHC3_DATA1 0x1d4
MX8MP_IOMUXC_NAND_DATA06__USDHC3_DATA2 0x1d4
MX8MP_IOMUXC_NAND_DATA07__USDHC3_DATA3 0x1d4
MX8MP_IOMUXC_NAND_RE_B__USDHC3_DATA4 0x1d4
MX8MP_IOMUXC_NAND_CE2_B__USDHC3_DATA5 0x1d4
MX8MP_IOMUXC_NAND_CE3_B__USDHC3_DATA6 0x1d4
MX8MP_IOMUXC_NAND_CLE__USDHC3_DATA7 0x1d4
MX8MP_IOMUXC_NAND_CE1_B__USDHC3_STROBE 0x194
pinctrl_usdhc3_200mhz: usdhc3-200mhzgrp {
fsl,pins = <
MX8MP_IOMUXC_NAND_WE_B__USDHC3_CLK 0x196
MX8MP_IOMUXC_NAND_WP_B__USDHC3_CMD 0x1d6
MX8MP_IOMUXC_NAND_DATA04__USDHC3_DATA0 0x1d6
MX8MP_IOMUXC_NAND_DATA05__USDHC3_DATA1 0x1d6
MX8MP_IOMUXC_NAND_DATA06__USDHC3_DATA2 0x1d6
MX8MP_IOMUXC_NAND_DATA07__USDHC3_DATA3 0x1d6
MX8MP_IOMUXC_NAND_RE_B__USDHC3_DATA4 0x1d6
MX8MP_IOMUXC_NAND_CE2_B__USDHC3_DATA5 0x1d6
MX8MP_IOMUXC_NAND_CE3_B__USDHC3_DATA6 0x1d6
MX8MP_IOMUXC_NAND_CLE__USDHC3_DATA7 0x1d6
MX8MP_IOMUXC_NAND_CE1_B__USDHC3_STROBE 0x196
pinctrl_wdog: wdoggrp {
fsl,pins = <
MX8MP_IOMUXC_GPIO1_IO02__WDOG1_WDOG_B 0xc6
<board>.h
#include <linux/sizes.h>
#include <linux/stringify.h>
#include <asm/arch/imx-regs.h>
#include "imx_env.h"
#define CONFIG_SYS_BOOTM_LEN (32 * SZ_1M)
#define CONFIG_SPL_MAX_SIZE (176 * 1024)
#define CONFIG_SYS_MONITOR_LEN (512 * 1024)
#define CONFIG_SYS_UBOOT_BASE (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
#ifdef CONFIG_SPL_BUILD
#define CONFIG_SPL_STACK 0x96dff0
#define CONFIG_SPL_BSS_START_ADDR 0x96e000
#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K /* 8 KB */
#define CONFIG_SYS_SPL_MALLOC_START 0x42200000
#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */
/* For RAW image gives a error info not panic */
#define CONFIG_SPL_ABORT_ON_RAW_IMAGE
#endif
#define CONFIG_CMD_READ
#define CONFIG_SERIAL_TAG
#define CONFIG_FASTBOOT_USB_DEV 0
#define CONFIG_REMAKE_ELF
/* ENET Config */
/* ENET1 */
#if defined(CONFIG_CMD_NET)
#define CONFIG_ETHPRIME "eth1" /* Set eqos to primary since we use its MDIO */
#define CONFIG_FEC_XCV_TYPE RGMII
#define CONFIG_FEC_MXC_PHYADDR 1
#define DWC_NET_PHYADDR 1
#define PHY_ANEG_TIMEOUT 20000
#endif
#ifdef CONFIG_DISTRO_DEFAULTS
#define BOOT_TARGET_DEVICES(func) \
func(USB, usb, 0) \
func(MMC, mmc, 1) \
func(MMC, mmc, 2)
#include <config_distro_bootcmd.h>
#else
#define BOOTENV
#endif
#define JH_ROOT_DTB "imx8mp-evk-root.dtb"
#define JAILHOUSE_ENV \
"jh_clk= \0 " \
"jh_root_dtb=" JH_ROOT_DTB "\0" \
"jh_mmcboot=setenv fdtfile ${jh_root_dtb};" \
"setenv jh_clk clk_ignore_unused mem=1920MB; " \
"if run loadimage; then " \
"run mmcboot; " \
"else run jh_netboot; fi; \0" \
"jh_netboot=setenv fdtfile ${jh_root_dtb}; setenv jh_clk clk_ignore_unused mem=1920MB; run netboot; \0 "
#define CONFIG_MFG_ENV_SETTINGS \
CONFIG_MFG_ENV_SETTINGS_DEFAULT \
"initrd_addr=0x43800000\0" \
"initrd_high=0xffffffffffffffff\0" \
"emmc_dev=2\0"\
"sd_dev=1\0"
#define CONFIG_EXTRA_ENV_SETTINGS \
JAILHOUSE_ENV \
BOOTENV \
"prepare_mcore=setenv mcore_clk clk-imx8mp.mcore_booted;\0" \
"scriptaddr=0x43500000\0" \
"kernel_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \
"bsp_script=boot.scr\0" \
"image=Image\0" \
"splashimage=0x50000000\0" \
"console=ttymxc1,115200\0" \
"fdt_addr_r=0x43000000\0" \
"fdt_addr=0x43000000\0" \
"boot_fdt=try\0" \
"fdt_high=0xffffffffffffffff\0" \
"boot_fit=no\0" \
"fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \
"bootm_size=0x10000000\0" \
"mmcdev="__stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \
"mmcpart=1\0" \
"mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \
"mmcautodetect=yes\0" \
"mmcargs=setenv bootargs ${jh_clk} ${mcore_clk} console=${console} root=${mmcroot}\0 " \
"loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${bsp_script};\0" \
"bootscript=echo Running bootscript from mmc ...; " \
"source\0" \
"loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \
"loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr_r} ${fdtfile}\0" \
"mmcboot=echo Booting from mmc ...; " \
"run mmcargs; " \
"if test ${boot_fit} = yes || test ${boot_fit} = try; then " \
"bootm ${loadaddr}; " \
"else " \
"if run loadfdt; then " \
"booti ${loadaddr} - ${fdt_addr_r}; " \
"else " \
"echo WARN: Cannot load the DT; " \
"fi; " \
"fi;\0" \
"netargs=setenv bootargs ${jh_clk} ${mcore_clk} console=${console} " \
"root=/dev/nfs " \
"ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \
"netboot=echo Booting from net ...; " \
"run netargs; " \
"if test ${ip_dyn} = yes; then " \
"setenv get_cmd dhcp; " \
"else " \
"setenv get_cmd tftp; " \
"fi; " \
"${get_cmd} ${loadaddr} ${image}; " \
"else " \
"if ${get_cmd} ${fdt_addr_r} ${fdtfile}; then " \
"else " \
"fi; " \
"fi;\0" \
"bsp_bootcmd=echo Running BSP bootcmd ...; " \
"mmc dev ${mmcdev}; if mmc rescan; then " \
"if run loadbootscript; then " \
"run bootscript; " \
"else " \
"run mmcboot; " \
"else run netboot; " \
"fi; " \
"fi; " \
"fi;"
/* Link Definitions */
#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000
#define CONFIG_SYS_INIT_RAM_SIZE 0x80000
#define CONFIG_SYS_INIT_SP_OFFSET \
(CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
#define CONFIG_SYS_INIT_SP_ADDR \
(CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
#define CONFIG_MMCROOT "/dev/mmcblk1p2" /* USDHC2 */
/* Totally 6GB DDR */
#define CONFIG_SYS_SDRAM_BASE 0x40000000
#define PHYS_SDRAM 0x40000000
#define PHYS_SDRAM_SIZE 0xC0000000 /* 3 GB */
#define PHYS_SDRAM_2 0x100000000
#define PHYS_SDRAM_2_SIZE 0xC0000000 /* 3 GB */
#define CONFIG_MXC_UART_BASE UART2_BASE_ADDR
/* Monitor Command Prompt */
#define CONFIG_SYS_CBSIZE 2048
#define CONFIG_SYS_MAXARGS 64
#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \
sizeof(CONFIG_SYS_PROMPT) + 16)
#define CONFIG_IMX_BOOTAUX
#define CONFIG_SYS_FSL_USDHC_NUM 2
#define CONFIG_SYS_FSL_ESDHC_ADDR 0
#define CONFIG_SYS_I2C_SPEED 100000
/* USB configs */
#define CONFIG_USB_MAX_CONTROLLER_COUNT 2
#define CONFIG_USBD_HS
#define CONFIG_USB_GADGET_VBUS_DRAW 2
Hi @Jimmychea ,
There's no problem with or without eMMC. Compared to the <u-boot>/include/configs/imx8mp_evk.h, I found that the following CONFIG_SYS_MMC_IMG_LOAD_PART is missing :
#define CONFIG_SYS_MMC_IMG_LOAD_PART	1
...Try to add it into your <u-boot>/include/configs/<board>.h.
And please share the <u-boot>/configs/<board>_defconfig if possible. It should NOT be much different compared to the <u-boot>/configs/imx8mp_evk_defconfig, except for the following :
CONFIG_TARGET_IMX8MP_<BOARD>=y vs CONFIG_TARGET_IMX8MP_EVK=y
CONFIG_DEFAULT_DEVICE_TREE="imx8mp-<board>" vs CONFIG_DEFAULT_DEVICE_TREE="imx8mp-evk"
CONFIG_DEFAULT_FDT_FILE="imx8mp-<board>.dtb" vs CONFIG_DEFAULT_FDT_FILE="imx8mp-evk.dtb"
Khang
I can't find CONFIG_SYS_MMC_IMG_LOAD_PART in <u-boot>/include/configs/imx8mp_evk.h.
Sorry,
Khang
Ok, Thanks.
