Running Azure in Imx8m
1,652件の閲覧回数
jeslinpauljoseph
I want to compile and run Azure SDK on IMX8m mini Yocto.
Is there any documentation or article available on how to include Azure SDK in imX8 Yocto build and run sample application?
Jeslin Paul
3 返答(返信)
1,632件の閲覧回数
jeslinpauljoseph
Thanks for the reply.
We need to run Yocto Linux on an iMX8 device and establish a connection to the Azure cloud. To achieve this, we aim to compile the Azure C/C++ SDK within the iMX8 Yocto BSP and utilize the Azure API for cloud connectivity. Can you provide guidance on how to proceed with these requirements?
Jeslin Paul
1,623件の閲覧回数
Bio_TICFSL
I find azure have meta-layer source code in github:
https://github.com/Azure/meta-iotedge
and https://layers.openembedded.org/layerindex/branch/zeus/layer/meta-iot-cloud/
Right now, NXP don't have a documentation.
Hope it will helpful to you!
1,640件の閲覧回数
Bio_TICFSL
Not with yocto, you can build the WinIot for MX8M ad run azure:
https://www.nxp.com/design/design-center/software/embedded-software/i-mx-software/windows-10-iot-ent...
