Request to convert wbf to fw (E-Ink)
2,617 次查看
hiroyukihara
Please convert wbf for E-Ink 13.3 inch EPD to fw.
I will attach wbf.
(Would you please give me a conversion script if possible?)
Thanking you in advance
Original Attachment has been moved to: 320_R066_AD5901_ES133UT2C1_TC.WBF.zip
2,382 次查看
max_tsai
Please find the parsed waveform for i.MX6.
2,383 次查看
max_tsai
2,382 次查看
jimmychan
could you tell me which chip are you using?
2,382 次查看
hiroyukihara
Thank you for your reply.
I am using i.MX6 DualLite.
