Please convert wbf for E-Ink 13.3 inch EPD to fw.I will attach wbf.(Would you please give me a conversion script if possible?)
Thanking you in advance
Original Attachment has been moved to: 320_R066_AD5901_ES133UT2C1_TC.WBF.zip
Solved! Go to Solution.
Please find the parsed waveform for i.MX6.
could you tell me which chip are you using?
Thank you for your reply.
I am using i.MX6 DualLite.
