Request for LVDS Panel Driver / Configuration Support for 10.4″ TFT on i.MX8MP EVK
1,566 次查看
GOWRIPRIYA_G
Hello NXP Community,
I am currently using the NXP i.MX8MP EVK board and working with LVDS interface displays. I need some guidance and support regarding display drivers and related files.
Specifically, I have the following questions:
  1. Could you provide the necessary driver files or configuration files for a 10.4'' TFT LCD display panel compatible with the i.MX8MP EVK?
  2. Are there any standard display files available from Kingtech for a 10.4'' display that I can use with this board?
Any guidance, example driver file, device tree configurations, or reference files would be greatly helpful.
Thank you in advance for your support!
Gowripriya G
1,555 次查看
Bio_TICFSL
To implement LVDS display support on your i.MX8MP EVK, you'll need to make the following changes:
1. Device Tree Configuration:
- Reference the dual LVDS support device tree file for the i.MX8MP EVK at:
https://github.com/nxp-imx/linux-imx/blob/lf-6.6.y/arch/arm64/boot/dts/freescale/imx8mp-evk-it6263-l...
2. Panel Driver:
- You'll need to configure your display in the panel-simple.c driver file with the appropriate timing specifications for your 10.4" TFT display
- The panel-simple.c file is located at:
https://source.codeaurora.org/external/imx/linux-imx/tree/drivers/gpu/drm/panel/panel-simple.c?h=lf-...
- Add your display timing parameters in the struct display_timing section
3. Set the correct device tree file:
In U-Boot, set the appropriate device tree file for your LVDS panel:
=> setenv fdtfile imx8mp-evk-your-lvds-panel.dtb
=> saveenv
=> boot
4. For LVDS driver details, refer to:
- LVDS controller: drivers/gpu/drm/imx/imx93_ldb.c (similar structure for i.MX8MP)
- LVDS PHY: drivers/phy/freescale/phy-fsl-imx8mp-lvds.c
Note that for i.MX8MP, the frame buffer drivers are not supported as they are for i.MX6/7 - you'll need to use the DRM framework instead.
For additional reference, check the i.MX8QXP MEK Display Selection Guide at:
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX-8QXP-MEK-Display-Selection-Guide/ta...
1,523 次查看
GOWRIPRIYA_G
Thank you for the response and guidance.
I tried to access the panel driver link you provided:
However, the link seems to be inaccessible or no longer available. Please find the attached screenshot showing the issue. ). Could you please confirm if the repository has been moved to another location or if there’s an updated link for accessing the panel-simple.c file?
Gowripriya G
1,499 次查看
Bio_TICFSL
You can get it from your BSP
drivers/gpu/drm/panel/:
This is the standard location within the Linux kernel source tree for DRM panel drivers. You would find files like panel-simple.c (for basic panels), and drivers for specific panel models
%3CLINGO-SUB%20id%3D%22lingo-sub-2202765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%AF%B7%E6%B1%82%E4%B8%BA%20i.MX8MP%20EVK%20%E4%B8%8A%E7%9A%84%2010.4%20%E8%8B%B1%E5%AF%B8%20TFT%20%E6%8F%90%E4%BE%9B%20LVDS%20%E9%9D%A2%E6%9D%BF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%2F%E9%85%8D%E7%BD%AE%E6%94%AF%E6%8C%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2202765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E7%A4%BE%E5%8C%BA%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E7%9B%AE%E5%89%8D%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E6%81%A9%E6%99%BA%E6%B5%A6%20i.MX8MP%20EVK%20%E6%9D%BF%E5%B9%B6%E4%BD%BF%E7%94%A8%20LVDS%20%E6%8E%A5%E5%8F%A3%E6%98%BE%E7%A4%BA%E5%99%A8%E3%80%82%E6%88%91%E9%9C%80%E8%A6%81%E6%9C%89%E5%85%B3%E6%98%BE%E7%A4%BA%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%92%8C%E7%9B%B8%E5%85%B3%E6%96%87%E4%BB%B6%E7%9A%84%E6%8C%87%E5%AF%BC%E5%92%8C%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3CP%3E%E5%85%B7%E4%BD%93%E6%9D%A5%E8%AF%B4%EF%BC%8C%E6%88%91%E6%9C%89%E4%BB%A5%E4%B8%8B%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FP%3E%3COL%3E%3CLI%3E%E8%83%BD%E5%90%A6%E6%8F%90%E4%BE%9B%E4%B8%8E%20i.MX8MP%20EVK%20%E5%85%BC%E5%AE%B9%E7%9A%84%2010.4''%20TFT%20LCD%20%E6%98%BE%E7%A4%BA%E9%9D%A2%E6%9D%BF%E6%89%80%E9%9C%80%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%96%87%E4%BB%B6%E6%88%96%E9%85%8D%E7%BD%AE%E6%96%87%E4%BB%B6%EF%BC%9F%3C%2FLI%3E%3CLI%3EKingtech%20%E6%98%AF%E5%90%A6%E6%9C%89%2010.4%20%E8%8B%B1%E5%AF%B8%E6%98%BE%E7%A4%BA%E5%99%A8%E7%9A%84%E6%A0%87%E5%87%86%E6%98%BE%E7%A4%BA%E6%96%87%E4%BB%B6%E5%8F%AF%E4%BE%9B%E6%88%91%E5%9C%A8%E8%BF%99%E5%9D%97%E6%9D%BF%E4%B8%8A%E4%BD%BF%E7%94%A8%EF%BC%9F%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E4%BB%BB%E4%BD%95%E6%8C%87%E5%AF%BC%E3%80%81%E7%A4%BA%E4%BE%8B%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%96%87%E4%BB%B6%E3%80%81%E8%AE%BE%E5%A4%87%E6%A0%91%E9%85%8D%E7%BD%AE%E6%88%96%E5%8F%82%E8%80%83%E6%96%87%E4%BB%B6%E9%83%BD%E4%BC%9A%E9%9D%9E%E5%B8%B8%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%E6%8F%90%E5%89%8D%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%EF%BC%81%3C%2FP%3E%3CP%3E%E6%95%AC%E4%B8%8A%EF%BC%8C%3CBR%20%2F%3EGowripriya%20G%3C%2FP%3E%3C%2FLINGO-BODY%3E
