i.MX 8QXP MEK Display Selection Guide
Search instead for
This document describes the i.MX 8QXP MEK mini-SAS connectors features on Linux and Android use cases, covering the
supported daughter cards, the process to change Device Tree (DTS) files or Boot images, and enable these different display options on the board.
Comments
Dear Marco,
As i.MX 8QXP MEK Display Selection Guide 7.3. Dual-channel LVDS panel mentioned, can we order this panel?
Or you can share ordering information for reference?
Best Regards
Chris Lin
Hi Chris,
You can find it by the part number MX8-DLVDS-LCD1.
However, we do not have it in stock at the moment. So please, check it again in a few days.
Marco
Version history
Revision #:
1 of 1
Last update:
‎11-13-2018 07:46 AM
Updated by:
