Remote display from i.MX8
1,270 次查看
arunsathvik
Hello Team,
I am working on a i.MX 8M mini SOM, which doesn't have a physical display connected to it. But I want to run a application with UI and redirect the complete display of the board remotely.
Any kind of leads are appreciated.
Thanks in advance.
1 回复
1,261 次查看
joanxie
you can use VNC, but current bsp doesn't support this, maybe you need add it by yourself, you need to load  rdp-backend
