Remote display from i.MX8
arunsathvik
Hello Team,
I am working on a i.MX 8M mini SOM, which doesn't have a physical display connected to it. But I want to run a application with UI and redirect the complete display of the board remotely.
Any kind of leads are appreciated.
Thanks in advance.
joanxie
you can use VNC, but current bsp doesn't support this, maybe you need add it by yourself, you need to load  rdp-backend
