Remap secure bootloader flow chart seems wrong
7,034件の閲覧回数
pm_2552
It appears that the Remap flow chart for SBL has some typos and is not the updated one. Can you please provide the correct flow chart?
6,937件の閲覧回数
pm_2552
Please check the highlighted part in the above flow chart. I have marked all blocks where Remap is enabled with "++" and where Remap is disabled to "--"
The enable Remap block in the above flow should be before verification and that is indeed the case in the SBL code.
4 返答(返信)
6,938件の閲覧回数
pm_2552
6,992件の閲覧回数
pm_2552
@kerry zhou Can you please help?
7,001件の閲覧回数
hector_delgado
Hi @pm_2552 ,
I hope you're doing well!
What device are you using?
Thank you.
Hector.
6,993件の閲覧回数
pm_2552
Hello I am using RT1060 and this are the docs I am referring to: AN13460
