Regarding timer on IMX8MM-LPDDR4
avikum
According to "i.MX Linux Reference Manual" , i.MX 8M Mini usages system counter timer (driver/clocksource/timer-imx-sysctr.c ), but I couldn't fine any APIs  which I can integrate in our driver , can you let me know the which system counter timer APIs (pls do share the file path) we can use to enable the timer (one shot and periodic  timer)? please do share the developer document regarding timer, if any.
avikum
avikum
we are using 5.15.71 kernel.
avikum
Released notes attached for 5.15.71 kernel and BSP version.
Rita_Wang
Which version BSP are you using? I will help confirm.
avikum
Hi, Can you please update on this ?
Rita_Wang
The timers on this chip include:
• One local generic timer integrated into each Cortex-A53 CPU
• Global system counter with timer bus interface to Cortex-A53 MPCore generic
timers
• One local system timer (SysTick) integrated into the Cortex-M4 CPU
• Six general purpose timer (GPT) modules
• Three watchdog timer (WDOG) modules
• Four pulse width modulation (PWM) modules
You can see in our RM
