RT6XX svd
RT6XX svd
2,216 次查看
hxp123
Is there a publicly available SVD for RT6XX?
Thank you
标记 (1)
2,200 次查看
jingpan
Hi @hxp123 ,
The svd file is SDK_2_12_0_EVK-MIMXRT685\devices\MIMXRT685S\MIMXRT685S_cm33.xml. You can change .xml to .svd.
Jing
2,201 次查看
jingpan
Hi @hxp123 ,
Jing
2,195 次查看
hxp123
thank you!
