Question, i.MX8M schematic design
3,120 次查看
SLICE
Dear team,
(1)
I would like to ask about HDMI_REFCLK_P/N ports of i.MX8M.
Could you show me whether these pins are used only for HDMI circuitry inside of i.MX?
If these pins are used for other circuitry, please let me know.
My customer saw that your Hardware Developer’s Guide says that those pins can be left open when unused, but they want to know those pins are really used ONLY for HDMI.
(2)
Could you show me the way to treat PCIe_RXN_P/N pins of i.MX8M if PCIe is unused?
Miyamoto
2,793 次查看
Yuri
  The fact, that HDMI_REFCLK clock may be left floating, when HDMI is not used,
without any additional comments in the Hardware Guide, means, that only HDMI
module is affected by this clock.
2.
  According to Table 30 (i.MX8M Unused Signal Strapping Recommendations)
of the Hardware Guide, PCIe_RXN_P/N are commented to leave unconnected.
https://www.nxp.com/docs/en/user-guide/IMX8MDQLQHDG.pdf
Yuri
6 回复数
2,794 次查看
Yuri
2.
Yuri
2,793 次查看
SLICE
Hi Yuri‌
Thanks for your prompt reply.
2.
Actually, we could not find the description about PCIE_RXNxx in your Developer's Guide.
Is it really OK for these pins to leave open?
Miyamoto
2,793 次查看
Yuri
Yes.
2,793 次查看
SLICE
Hi Yuri‌
Thanks for your support, but this is final confirmation.
We cannot find the description of PCIE_RXN_P/N in your Hardware Developer’s Guide’(IMX8MDQLQHDG,Rev.0).
Can I understand that this is just an omission?
Miyamoto
2,793 次查看
Yuri
  Yes, just an omission.
Yuri,
2,793 次查看
SLICE
Hi Yuri‌
Noted with thanks !
BR,
Miyamoto
