Question flexbuild error - i.MX Debian Linux SDK User Guide
2,942 次查看
jskim169
I am following the i.MX Debian Linux SDK User Guide for Rev. IDLSDK_24.12 — 30 December 2024 version. However, I encounter an error during the flexbuild process, which causes the build to stop. I would like to inquire about the possible causes of this issue. I have attached the log file related to this.
[Build Step]
$ git clone -b LSDK-24.12_DEBIAN-12_LF-6.6.36 https://github.com/nxp/flexbuild
$ cd flexbuild
$ . setup.env (in host environment)
$ bld docker
(create or attach to docker)
$ . setup.env (in docker environment)
$ bld host-dep (install host dependent packages)
$ bld -m imx93frdm
[Build Error Log]
/home/jskim/Project/imx-flex-sdk/flexbuild/build_lsdk2412/apps/apps_arm64_debian_desktop/usr/include/tvm/runtime/packed_func.h:1026:63: required from 'static void tvm::runtime::detail::for_each_dispatcher<stop, I, F>::run(const F&, T&&, Args&& ...) [with T = unsigned int&; Args = {DLTensor*}; bool stop = false; long unsigned int I = 0; F = tvm::runtime::TVMArgsSetter]'
/home/jskim/Project/imx-flex-sdk/flexbuild/build_lsdk2412/apps/apps_arm64_debian_desktop/usr/include/tvm/runtime/packed_func.h:1037:55: required from 'void tvm::runtime::detail::for_each(const F&, Args&& ...) [with F = tvm::runtime::TVMArgsSetter; Args = {unsigned int&, DLTensor*}]'
/home/jskim/Project/imx-flex-sdk/flexbuild/build_lsdk2412/apps/apps_arm64_debian_desktop/usr/include/tvm/runtime/packed_func.h:1192:19: required from 'tvm::runtime::TVMRetValue tvm::runtime::PackedFunc::operator()(Args&& ...) const [with Args = {unsigned int&, DLTensor*}]'
/home/jskim/Project/imx-flex-sdk/flexbuild/components_lsdk2412/apps/ml/nnstreamer/ext/nnstreamer/tensor_filter/tensor_filter_tvm.cc:385:29: required from here
/home/jskim/Project/imx-flex-sdk/flexbuild/build_lsdk2412/apps/apps_arm64_debian_desktop/usr/include/tvm/runtime/packed_func.h:1032:28: warning: unused parameter 'f' [-Wunused-parameter]
ninja: build stopped: subcommand failed.
make[1]: *** [/home/jskim/Project/imx-flex-sdk/flexbuild/src/apps/ml/nnstreamer.mk:10: nnstreamer] Error 1
make[1]: Leaving directory '/home/jskim/Project/imx-flex-sdk/flexbuild/src/apps'
make: *** [Makefile:11: apps] Error 2
make: Leaving directory '/home/jskim/Project/imx-flex-sdk/flexbuild/src'
[root@fbdebian flexbuild]$
2,860 次查看
Chavira
Hi @jskim169!
According to this post.
If you need ML feature, you need use docker under Ubuntu22.04.
Ubuntu22.04----->without ML
Ubuntu22.04+Debian12 docker------>ML/non-ML
Are you compiling on Ubuntu 22.04?
4 回复数
2,890 次查看
Chavira
HI @jskim169!
Thank you for contacting NXP Support!
Regarding the docker version issue, it is recommended to uninstall docker and reinstall it according to the guide. You don't need to specify the version when reinstalling. They have tested it on ubuntu 20.04 and 22.04 and it works properly.
https://docs.nxp.com/bundle/UG10155/page/topics/building_an_image_in_flexbuild.html
Best Regards!
Chavira
2,873 次查看
jskim169
Thank you for your response. After reinstalling Docker as per your suggestion and running it again, the issue remains the same. Upon checking the detailed build error, it seems there is an issue with the ML-related TensorFlow shared memory reference. I am attaching the logs related to this
[Executed the following command]
-> bld ml
lter_tensorflow_lite.cc
In file included from /home/jskim/Project/imx93-flexbuild/flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/core/subgraph.h:39,
from /home/jskim/Project/imx93-flexbuild/flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/core/async/async_subgraph.h:27,
from /home/jskim/Project/imx93-flexbuild/flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/core/async/async_signature_runner.h:24,
from /home/jskim/Project/imx93-flexbuild/flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/core/interpreter.h:45,
from /home/jskim/Project/imx93-flexbuild/flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/core/interpreter_builder.h:38,
from /home/jskim/Project/imx93-flexbuild/flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/core/model.h:26,
from /home/jskim/Project/imx93-flexbuild/flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/core/kernels/register.h:22,
from /home/jskim/Project/imx93-flexbuild/flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/lite/kernels/register.h:20,
from /home/jskim/Project/imx93-flexbuild/flexbuild/components_lsdk2412/apps/ml/nnstreamer/ext/nnstreamer/tensor_filter/tensor_filter_tensorflow_lite.cc:47:
/home/jskim/Project/imx93-flexbuild/flexbuild/build_lsdk2412/apps/apps_arm64_debian_desktop/usr/include/tensorflow/lite/graph_info.h:125:1: warning: multi-line comment [-Wcomment]
125 | // /------------\
/home/jskim/Project/imx93-flexbuild/flexbuild/build_lsdk2412/apps/apps_arm64_debian_desktop/usr/include/tensorflow/lite/graph_info.h:137:1: warning: multi-line comment [-Wcomment]
137 | // /------------\
In file included from /home/jskim/Project/imx93-flexbuild/flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/core/platform/bfloat16.h:20,
from /home/jskim/Project/imx93-flexbuild/flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/core/platform/types.h:19,
from /home/jskim/Project/imx93-flexbuild/flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/core/platform/logging.h:19,
from /home/jskim/Project/imx93-flexbuild/flexbuild/build_lsdk2412/apps/apps_arm64_debian_desktop/usr/include/tensorflow/lite/model.h:30,
from /home/jskim/Project/imx93-flexbuild/flexbuild/components_lsdk2412/apps/ml/nnstreamer/ext/nnstreamer/tensor_filter/tensor_filter_tensorflow_lite.cc:48:
/home/jskim/Project/imx93-flexbuild/flexbuild/components_lsdk2412/apps/ml/tflite/tensorflow/core/platform/byte_order.h:19:10: fatal error: tsl/platform/byte_order.h: No such file or directory
19 | #include "tsl/platform/byte_order.h"
compilation terminated.
[17/76] Compiling C++ object ext/nnstreamer/tensor_filter/libnnstreamer_filter_tensorflow2-lite.a.p/...ed68a89643dd45a97b7a829d1_nnstreamer_ext_nnstreamer_tensor_filter_tensor_filter_tensorflow_lite.cc.o
FAILED: ext/nnstreamer/tensor_filter/libnnstreamer_filter_tensorflow2-lite.a.p/4352dea8bd0ee59ed68a89643dd45a97b7a829d1_nnstreamer_ext_nnstreamer_tensor_filter_tensor_filter_tensorflow_lite.cc.o
aarch64-linux-gnu-g++ -march=armv8-a+crc+crypto -fstack-protector-strong -O2 --sysroot=/home/jskim/Project/imx93-flexbuild/flexbuild/build_lsdk2412/rfs/rootfs_lsdk2412_debian_desktop_arm64 -Iext/nnstreamer/tensor_filter/libnnstreamer_filter_tensorflow2-lite.a.p -Iext/nnstreamer/tensor_filter -I../ext/nnstreamer/tensor_filter -Igst/nnstreamer -I../gst/nnstreamer -Igst/nnstreamer/include -I../gst/nnstreamer/include -I/home/jskim/Project/imx93-flexbuild/flexbuild/build_lsdk2412/rfs/rootfs_lsdk2412_debian_desktop_arm64/usr/include -I/home/jskim/Project/imx93-flexbuild/flexbuild/build_lsdk2412/rfs/rootfs_lsdk2412_debian_desktop_arm64/usr/include/glib-2.0 -I/home/jskim/Project/imx93-flexbuild/flexbuild/build_lsdk2412/rfs/rootfs_lsdk2412_debian_desktop_arm64/usr/lib/aarch64-linux-gnu/glib-2.0/include -I/home/jskim/Project/imx93-flexbuild/flexbuild/build_lsdk2412/apps/apps_arm64_debian_desktop/usr/include -I/home/jskim/Project/imx93-flexbuild/flexbuild/components_lsdk2412/apps/ml/tvm/3rdparty/dmlc-core/include -I/home/jskim/Project/imx93-flexbuild/flexbuild/components_lsdk2412/apps/ml/tflite/build_debian_arm64/abseil-cpp -I/home/jskim/Project/imx93-flexbuild/flexbuild/components_lsdk2412/apps/ml/tflite -fdiagnostics-color=always -D_FILE_OFFSET_BITS=64 -Wall -Winvalid-pch -Wextra -Werror -std=c++17 -O3 '-DVERSION="2.2.0"' '-DVERSION_MAJOR="2"' '-DVERSION_MINOR="2"' '-DVERSION_MICRO="0"' -Wmissing-braces -Wmaybe-uninitialized -Wwrite-strings -Wformat -Wformat-nonliteral -Wformat-security -Winit-self -Waddress -Wno-multichar -Wvla -Wpointer-arith -DGLIB_USE_G_MEMDUP2 -DENABLE_TENSORFLOW2_LITE=1 -DHAVE_ORC=1 -DENABLE_TVM=1 -DENABLE_NNSTREAMER_EDGE=1 -Wredundant-decls -DFLOAT16_SUPPORT -Wno-error=comment -Wno-sign-compare -Wno-error=unused-parameter -Wno-error=redundant-decls -fPIC -DTFLITE_VERSION=2.16.2 -DTFLITE_VERSION_MAJOR=2 -DTFLITE_VERSION_MINOR=16 -DTFLITE_VERSION_MICRO=2 -DTFLITE_INT8=1 -DTFLITE_INT16=1 -DTFLITE_FLOAT16=1 -DTFLITE_COMPLEX64=1 -DTFLITE_XNNPACK_DELEGATE_SUPPORTED -DTFLITE_NNAPI_DELEGATE_SUPPORTED -DTFLITE_EXTERNAL_DELEGATE_SUPPORTED '-DTFLITE_SUBPLUGIN_NAME="tensorflow2-lite"' -pthread -MD -MQ ext/nnstreamer/tensor_filter/libnnstreamer_filter_tensorflow2-lite.a.p/4352dea8bd0ee59ed68a89643dd45a97b7a829d1_nnstreamer_ext_nnstreamer_tensor_filter_tensor_filter_tensorflow_lite.cc.o -MF ext/nnstreamer/tensor_filter/libnnstreamer_filter_tensorflow2-lite.a.p/4352dea8bd0ee59ed68a89643dd45a97b7a829d1_nnstreamer_ext_nnstreamer_tensor_filter_tensor_filter_tensorflow_lite.cc.o.d -o ext/nnstreamer/tensor_filter/libnnstreamer_filter_tensorflow2-lite.a.p/4352dea8bd0ee59ed68a89643dd45a97b7a829d1_nnstreamer_ext_nnstreamer_tensor_filter_tensor_filter_tensorflow_lite.cc.o -c /home/jskim/Project/imx93-flexbuild/flexbuild/components_lsdk2412/apps/ml/nnstreamer/ext/nnstreamer/tensor_filter/tensor_filter_tensorflow_lite.cc
[34/76] Compiling C++ object tests/unittest_sink.p/nnstreamer_sink_unittest_sink.cc.o
make[1]: *** [/home/jskim/Project/imx93-flexbuild/flexbuild/src/apps/ml/nnstreamer.mk:10: nnstreamer] Error 1
make: *** [Makefile:21: ml] Error 2
2,861 次查看
Chavira
Hi @jskim169!
2,808 次查看
jskim169
%3CLINGO-SUB%20id%3D%22lingo-sub-2034280%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eflexbuild%20%E9%94%99%E8%AF%AF%E9%97%AE%E9%A2%98%20-%20i.MX%20Debian%20Linux%20SDK%20%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2034280%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E9%81%B5%E5%BE%AA%20i.MX%20Debian%20Linux%20SDK%20%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%20Rev.%20IDLSDK_24.12%20%E2%80%94%202024%20%E5%B9%B4%2012%20%E6%9C%88%2030%20%E6%97%A5%E7%89%88%E6%9C%AC%E3%80%82%E7%84%B6%E8%80%8C%EF%BC%8C%E6%88%91%E5%9C%A8%20flexbuild%20%E8%BF%87%E7%A8%8B%E4%B8%AD%E9%81%87%E5%88%B0%E9%94%99%E8%AF%AF%EF%BC%8C%E5%AF%BC%E8%87%B4%E6%9E%84%E5%BB%BA%E5%81%9C%E6%AD%A2%E3%80%82%E6%88%91%E6%83%B3%E8%AF%A2%E9%97%AE%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E7%9A%84%E5%8F%AF%E8%83%BD%E5%8E%9F%E5%9B%A0%E3%80%82%E6%88%91%E5%B7%B2%E9%99%84%E4%B8%8A%E4%B8%8E%E6%AD%A4%E7%9B%B8%E5%85%B3%E7%9A%84%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%5B%E6%9E%84%E5%BB%BA%E6%AD%A5%E9%AA%A4%5D%3C%2FP%3E%3CP%3E%24%20git%20clone%20-b%20LSDK-24.12_DEBIAN-12_LF-6.6.36%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp%2Fflexbuild%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp%2Fflexbuild%3C%2FA%3E%3C%2FP%3E%3CP%3E%24%20cd%20flexbuild%3CBR%20%2F%3E%20%24%20%E3%80%82setup.env%EF%BC%88%E5%9C%A8%E4%B8%BB%E6%9C%BA%E7%8E%AF%E5%A2%83%E4%B8%AD%EF%BC%89%3CBR%20%2F%3E%20%24%20bld%20docker%3CBR%20%2F%3E%20%EF%BC%88%E5%88%9B%E5%BB%BA%E6%88%96%E9%99%84%E5%8A%A0%E5%88%B0docker%EF%BC%89%3CBR%20%2F%3E%20%24%20%E3%80%82setup.env%EF%BC%88%E5%9C%A8docker%E7%8E%AF%E5%A2%83%E4%B8%AD%EF%BC%89%3CBR%20%2F%3E%20%24%20bld%20host-dep%EF%BC%88%E5%AE%89%E8%A3%85%E4%B8%BB%E6%9C%BA%E7%9B%B8%E5%85%B3%E5%8C%85%EF%BC%89%3C%2FP%3E%3CP%3E%24%20bld%20-m%20imx93frdm%3C%2FP%3E%3CP%3E%5B%E6%9E%84%E5%BB%BA%E9%94%99%E8%AF%AF%E6%97%A5%E5%BF%97%5D%3C%2FP%3E%3CP%3E....%3C%2FP%3E%3CP%3E....%3C%2FP%3E%3CP%3E%2Fhome%2Fjskim%2FProject%2Fimx-flex-sdk%2Fflexbuild%2Fbuild_lsdk2412%2Fapps%2Fapps_arm64_debian_desktop%2Fusr%2Finclude%2Ftvm%2Fruntime%2Fpacked_func.h%3A1026%3A63%3A%20%E9%9C%80%E8%A6%81%E6%9D%A5%E8%87%AA%E2%80%98static%20void%20tvm%3A%3Aruntime%3A%3Adetail%3A%3Afor_each_dispatcher%3CSTOP%3E%3A%3Arun(const%20F%26amp%3B%2C%20T%26amp%3B%26amp%3B%2C%20Args%26amp%3B%26amp%3B%20...)%20%5Bwith%20T%20%3D%20unsigned%20int%26amp%3B%3B%20Args%20%3D%20%7BDLTensor*%7D%3B%20bool%20stop%20%3D%20false%3B%20long%20unsigned%20int%20I%20%3D%200%3B%20F%20%3D%20tvm%3A%3Aruntime%3A%3ATVMArgsSetter%5D%E2%80%99%3CBR%20%2F%3E%20%2Fhome%2Fjskim%2FProject%2Fimx-flex-sdk%2Fflexbuild%2Fbuild_lsdk2412%2Fapps%2Fapps_arm64_debian_desktop%2Fusr%2Finclude%2Ftvm%2Fruntime%2Fpacked_func.h%3A1037%3A55%EF%BC%9A'void%20tvm%3A%3Aruntime%3A%3Adetail%3A%3Afor_each(const%20F%26amp%3B%2C%20Args%26amp%3B%26amp%3B%20...)%20%5B%E5%85%B6%E4%B8%AD%20F%20%3D%20tvm%3A%3Aruntime%3A%3ATVMArgsSetter%3B%20Args%20%3D%20%7Bunsigned%20int%26amp%3B%2C%20DLTensor*%7D%5D'%20%E5%BF%85%E9%9C%80%3CBR%20%2F%3E%2Fhome%2Fjskim%2FProject%2Fimx-flex-sdk%2Fflexbuild%2Fbuild_lsdk2412%2Fapps%2Fapps_arm64_debian_desktop%2Fusr%2Finclude%2Ftvm%2Fruntime%2Fpacked_func.h%3A1192%3A19%3A%20%E9%9C%80%E8%A6%81%E6%9D%A5%E8%87%AA'tvm%3A%3Aruntime%3A%3ATVMRetValue%20tvm%3A%3Aruntime%3A%3APackedFunc%3A%3Aoperator()(Args%26amp%3B%26amp%3B%20...)%20const%20%5Bwith%20Args%20%3D%20%7Bunsigned%20int%26amp%3B%2C%20DLTensor*%7D%5D'%3CBR%20%2F%3E%20%2Fhome%2Fjskim%2FProject%2Fimx-flex-sdk%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Fnnstreamer%2Fext%2Fnnstreamer%2Ftensor_filter%2Ftensor_filter_tvm.cc%3A385%3A29%3A%20%E4%BB%8E%E8%BF%99%E9%87%8C%E9%9C%80%E8%A6%81%3CBR%20%2F%3E%2Fhome%2Fjskim%2FProject%2Fimx-flex-sdk%2Fflexbuild%2Fbuild_lsdk2412%2Fapps%2Fapps_arm64_debian_desktop%2Fusr%2Finclude%2Ftvm%2Fruntime%2Fpacked_func.h%3A1032%3A28%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%9C%AA%E4%BD%BF%E7%94%A8%E7%9A%84%E5%8F%82%E6%95%B0%E2%80%9Cf%E2%80%9D%5B-Wunused-parameter%5D%3CBR%20%2F%3E%20ninja%EF%BC%9A%E6%9E%84%E5%BB%BA%E5%B7%B2%E5%81%9C%E6%AD%A2%EF%BC%9A%E5%AD%90%E5%91%BD%E4%BB%A4%E5%A4%B1%E8%B4%A5%E3%80%82%3CBR%20%2F%3E%E4%BD%BF%5B1%5D%EF%BC%9A***%5B%2Fhome%2Fjskim%2FProject%2Fimx-flex-sdk%2Fflexbuild%2Fsrc%2Fapps%2Fml%2Fnnstreamer.mk%3A10%EF%BC%9Annstreamer%5D%E9%94%99%E8%AF%AF1%3CBR%20%2F%3E%20make%5B1%5D%3A%E7%A6%BB%E5%BC%80%E7%9B%AE%E5%BD%95%E2%80%98%2Fhome%2Fjskim%2FProject%2Fimx-flex-sdk%2Fflexbuild%2Fsrc%2Fapps%E2%80%99%3CBR%20%2F%3E%20make%EF%BC%9A***%20%5BMakefile%EF%BC%9A11%EF%BC%9A%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%5D%20%E9%94%99%E8%AF%AF%202%3CBR%20%2F%3E%20make%3A%E7%A6%BB%E5%BC%80%E7%9B%AE%E5%BD%95'%2Fhome%2Fjskim%2FProject%2Fimx-flex-sdk%2Fflexbuild%2Fsrc'%3CBR%20%2F%3E%20%5Broot%40fbdebian%20flexbuild%5D%24%3C%2FSTOP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2037005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%97%AE%E9%A2%98%20flexbuild%20%E9%94%99%E8%AF%AF%20-%20i.MX%20Debian%20Linux%20SDK%20%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2037005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2035793%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%97%AE%E9%A2%98%20flexbuild%20%E9%94%99%E8%AF%AF%20-%20i.MX%20Debian%20Linux%20SDK%20%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2035793%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245751%22%20target%3D%22_blank%22%3E%40jskim169%3C%2FA%3E!%3C%2FP%3E%0A%3CP%3E%E6%A0%B9%E6%8D%AE%E8%BF%99%E7%AF%87%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FDebian-build-fail-tflite-ethosu-delegate-Error-2-in-flexbuild%2Fm-p%2F2022337%22%20target%3D%22_self%22%3E%E6%96%87%E7%AB%A0%E3%80%82%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E9%9C%80%E8%A6%81ML%E5%8A%9F%E8%83%BD%EF%BC%8C%E9%9C%80%E8%A6%81%E5%9C%A8Ubuntu22.04%E4%B8%8B%E4%BD%BF%E7%94%A8docker%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3EUbuntu22.04-----%26gt%3B%E6%97%A0ML%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EUbuntu22.04%2BDebian12%20docker------%26gt%3BML%2Fnon-ML%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%82%A8%E6%98%AF%E5%9C%A8%20Ubuntu%2022.04%20%E4%B8%8A%E7%BC%96%E8%AF%91%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2035564%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%97%AE%E9%A2%98%20flexbuild%20%E9%94%99%E8%AF%AF%20-%20i.MX%20Debian%20Linux%20SDK%20%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2035564%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%E6%8C%89%E7%85%A7%E6%82%A8%E7%9A%84%E5%BB%BA%E8%AE%AE%E9%87%8D%E6%96%B0%E5%AE%89%E8%A3%85%20Docker%20%E5%B9%B6%E5%86%8D%E6%AC%A1%E8%BF%90%E8%A1%8C%E5%90%8E%EF%BC%8C%E9%97%AE%E9%A2%98%E4%BB%8D%E7%84%B6%E5%AD%98%E5%9C%A8%E3%80%82%E6%A3%80%E6%9F%A5%E8%AF%A6%E7%BB%86%E7%9A%84%E6%9E%84%E5%BB%BA%E9%94%99%E8%AF%AF%E5%90%8E%EF%BC%8C%E4%BC%BC%E4%B9%8E%E4%B8%8E%20ML%20%E7%9B%B8%E5%85%B3%E7%9A%84%20TensorFlow%20%E5%85%B1%E4%BA%AB%E5%86%85%E5%AD%98%E5%BC%95%E7%94%A8%E5%AD%98%E5%9C%A8%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E9%99%84%E4%B8%8A%E4%BA%86%E4%B8%8E%E6%AD%A4%E7%9B%B8%E5%85%B3%E7%9A%84%E6%97%A5%E5%BF%97%3C%2FP%3E%3CP%3E%5B%E6%89%A7%E8%A1%8C%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%5D%3C%2FP%3E%3CP%3E-%26gt%3B%20bld%20ml%3C%2FP%3E%3CP%3E...%3C%2FP%3E%3CP%3E...%3C%2FP%3E%3CP%3Elter_tensorflow_lite.cc%3CBR%20%2F%3E%E5%9C%A8%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Ftflite%2Ftensorflow%2Flite%2Fcore%2Fsubgraph.h%3A39%20%E5%8C%85%E5%90%AB%E7%9A%84%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A5%E8%87%AA%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Ftflite%2Ftensorflow%2Flite%2Fcore%2Fasync%2Fasync_subgraph.h%3A27%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A5%E8%87%AA%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Ftflite%2Ftensorflow%2Flite%2Fcore%2Fasync%2Fasync_signature_runner.h%3A24%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A5%E8%87%AA%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Ftflite%2Ftensorflow%2Flite%2Fcore%2Finterpreter.h%3A45%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A5%E8%87%AA%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Ftflite%2Ftensorflow%2Flite%2Fcore%2Finterpreter_builder.h%3A38%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A5%E8%87%AA%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Ftflite%2Ftensorflow%2Flite%2Fcore%2Fmodel.h%3A26%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A5%E8%87%AA%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Ftflite%2Ftensorflow%2Flite%2Fcore%2Fkernels%2Fregister.h%3A22%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A5%E8%87%AA%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Ftflite%2Ftensorflow%2Flite%2Fkernels%2Fregister.h%3A20%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A5%E8%87%AA%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Fnnstreamer%2Fext%2Fnnstreamer%2Ftensor_filter%2Ftensor_filter_tensorflow_lite.cc%3A47%EF%BC%9A%3CBR%20%2F%3E%20%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fbuild_lsdk2412%2Fapps%2Fapps_arm64_debian_desktop%2Fusr%2Finclude%2Ftensorflow%2Flite%2Fgraph_info.h%3A125%3A1%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E5%A4%9A%E8%A1%8C%E6%B3%A8%E9%87%8A%5B-Wcomment%5D%3CBR%20%2F%3E%20125%20%7C%20%2F%2F%20%2F------------%5C%3CBR%20%2F%3E%20%7C%20%5E%3CBR%20%2F%3E%20%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fbuild_lsdk2412%2Fapps%2Fapps_arm64_debian_desktop%2Fusr%2Finclude%2Ftensorflow%2Flite%2Fgraph_info.h%3A137%3A1%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E5%A4%9A%E8%A1%8C%E6%B3%A8%E9%87%8A%5B-Wcomment%5D%3CBR%20%2F%3E%20137%20%7C%20%2F%2F%20%2F------------%5C%3CBR%20%2F%3E%20%7C%20%5E%3CBR%20%2F%3E%E5%9C%A8%20%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Ftflite%2Ftensorflow%2Fcore%2Fplatform%2Fbfloat16.h%3A20%20%E5%8C%85%E5%90%AB%E7%9A%84%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A5%E8%87%AA%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Ftflite%2Ftensorflow%2Fcore%2Fplatform%2Ftypes.h%3A19%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A5%E8%87%AA%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Ftflite%2Ftensorflow%2Fcore%2Fplatform%2Flogging.h%3A19%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A5%E8%87%AA%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fbuild_lsdk2412%2Fapps%2Fapps_arm64_debian_desktop%2Fusr%2Finclude%2Ftensorflow%2Flite%2Fmodel.h%3A30%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A5%E8%87%AA%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Fnnstreamer%2Fext%2Fnnstreamer%2Ftensor_filter%2Ftensor_filter_tensorflow_lite.cc%3A48%EF%BC%9A%3CBR%20%2F%3E%20%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Ftflite%2Ftensorflow%2Fcore%2Fplatform%2Fbyte_order.h%3A19%3A10%3A%E8%87%B4%E5%91%BD%E9%94%99%E8%AF%AF%EF%BC%9Atsl%2Fplatform%2Fbyte_order.h%EF%BC%9A%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3CBR%20%2F%3E19%20%7C%20%23include%20%E2%80%9Ctsl%2Fplatform%2Fbyte_order.h%E2%80%9D%3CBR%20%2F%3E%7C%20%5E~~~~~~~~~~~~~~~~~~~~~~~~~~~~%3CBR%20%2F%3E%E7%BC%96%E8%AF%91%E7%BB%88%E6%AD%A2%E3%80%82%3CBR%20%2F%3E%5B17%2F76%5D%20%E7%BC%96%E8%AF%91%20C%2B%2B%20%E5%AF%B9%E8%B1%A1%20ext%2Fnnstreamer%2Ftensor_filter%2Flibnnstreamer_filter_tensorflow2-lite.ap%2F...ed68a89643dd45a97b7a829d1_nnstreamer_ext_nnstreamer_tensor_filter_tensor_filter_tensorflow_lite.cc.o%3CBR%20%2F%3E%E5%A4%B1%E8%B4%A5%EF%BC%9Aext%2Fnnstreamer%2Ftensor_filter%2Flibnnstreamer_filter_tensorflow2-lite.ap%2F4352dea8bd0ee59ed68a89643dd45a97b7a829d1_nnstreamer_ext_nnstreamer_tensor_filter_tensor_filter_tensorflow_lite.cc.o%3CBR%20%2F%3E%20aarch64-linux-gnu-g%2B%2B%20-march%3Darmv8-a%2Bcrc%2Bcrypto%20-fstack-protector-strong%20-O2%20--sysroot%3D%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fbuild_lsdk2412%2Frfs%2Frootfs_lsdk2412_debian_desktop_arm64%20-Iext%2Fnnstreamer%2Ftensor_filter%2Flibnnstreamer_filter_tensorflow2-lite.ap%20-Iext%2Fnnstreamer%2Ftensor_filter%20-I..%2Fext%2Fnnstreamer%2Ftensor_filter%20-Igst%2Fnnstreamer%20-I..%2Fgst%2Fnnstreamer%20-Igst%2Fnnstreamer%2Finclude%20-I..%2Fgst%2Fnnstreamer%2Finclude%20-I%2Fhome%2Fjskim%2F%E9%A1%B9%E7%9B%AE%2Fimx93-flexbuild%2Fflexbuild%2Fbuild_lsdk2412%2Frfs%2Frootfs_lsdk2412_debian_desktop_arm64%2Fusr%2Finclude%20-I%2Fhome%2Fjskim%2F%E9%A1%B9%E7%9B%AE%2Fimx93-flexbuild%2Fflexbuild%2Fbuild_lsdk2412%2Frfs%2Frootfs_lsdk2412_debian_desktop_arm64%2Fusr%2Finclude%2Fglib-2.0%20-I%2Fhome%2Fjskim%2F%E9%A1%B9%E7%9B%AE%2Fimx93-flexbuild%2Fflexbuild%2Fbuild_lsdk2412%2Frfs%2Frootfs_lsdk2412_debian_desktop_arm64%2Fusr%2Flib%2Faarch64-linux-gnu%2Fglib-2.0%2Finclude-I%20%2F%20home%20%2F%20jskim%20%2F%20Project%20%2F%20imx93-flexbuild%20%2F%20flexbuild%20%2F%20build_lsdk2412%20%2F%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%2Fapps_arm64_debian_desktop%20%2F%20usr%20%2F%20include%20-I%20%2F%20home%20%2F%20jskim%20%2F%20Project%20%2F%20imx93-flexbuild%20%2F%20flexbuild%20%2F%20components_lsdk2412%20%2F%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%2F%20ml%20%2F%20tvm%20%2F%203rdparty%20%2F%20dmlc-core%20%2F%20include%20-I%20%2F%20home%20%2F%20jskim%20%2F%20Project%20%2F%20imx93-flexbuild%20%2F%20flexbuild%20%2F%20components_lsdk2412%20%2F%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%2F%20ml%20%2F%20tflite%20%2F%20build_debian_arm64%20%2F%20abseil-cpp%20-I%20%2F%20home%20%2F%20jskim%20%2F%20Project%20%2F%20imx93-flexbuild%20%2F%20flexbuild%20%2F%20components_lsdk2412%20%2F%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%2F%20ml%20%2F%20tflite%20-fdiagnostics-color%20%3D%E5%A7%8B%E7%BB%88-D_FILE_OFFSET_BITS%20%3D%2064%20-Wall%20-Winvalid-pch%20-Wextra%20-Werror%20-std%3Dc%2B%2B17%20-O3%20'-DVERSION%3D%222.2.0%22'%20'-DVERSION_MAJOR%3D%222%22'%20'-DVERSION_MINOR%3D%222%22'%20'-DVERSION_MICRO%3D%220%22'%20-Wmissing-braces%20-Wmaybe-uninitialized%20-Wwrite-strings%20-Wformat%20-Wformat-nonliteral%20-Wformat-security%20-Winit-self%20-Waddress%20-Wno-multichar%20-Wvla%20-Wpointer-arith%20-DGLIB_USE_G_MEMDUP2%20-DENABLE_TENSORFLOW2_LITE%3D1%20-DHAVE_ORC%3D1%20-DENABLE_TVM%3D1%20-DENABLE_NNSTREAMER_EDGE%3D1%20-Wredundant-decls%20-DFLOAT16_SUPPORT%20-Wno-error%3Dcomment%20-Wno-sign-compare%20-Wno-error%3Dunused-parameter%20-Wno-error%3Dredundant-decls%20-fPIC%20-DTFLITE_VERSION%3D2.16.2%20-DTFLITE_VERSION_MAJOR%3D2%20-DTFLITE_VERSION_MINOR%3D16%20-DTFLITE_VERSION_MICRO%3D2%20-DTFLITE_INT8%3D1%20-DTFLITE_INT16%3D1%20-DTFLITE_FLOAT16%3D1%20-DTFLITE_COMPLEX64%3D1%20-DTFLITE_XNNPACK_DELEGATE_SUPPORTED%20-DTFLITE_NNAPI_DELEGATE_SUPPORTED%20-DTFLITE_EXTERNAL_DELEGATE_SUPPORTED%20'-DTFLITE_SUBPLUGIN_NAME%3D%22tensorflow2-lite%22'%20-pthread%20-MD%20-MQ%20ext%2Fnnstreamer%2Ftensor_filter%2Flibnnstreamer_filter_tensorflow2-lite.ap%2F4352dea8bd0ee59ed68a89643dd45a97b7a829d1_nnstreamer_ext_nnstreamer_tensor_filter_tensor_filter_tensorflow_lite.cc.o%20-MF%20ext%2Fnnstreamer%2Ftensor_filter%2Flibnnstreamer_filter_tensorflow2-lite.ap%2F4352dea8bd0ee59ed68a89643dd45a97b7a829d1_nnstreamer_ext_nnstreamer_tensor_filter_tensor_filter_tensorflow_lite.cc.od%20-o%20ext%2Fnnstreamer%2Ftensor_filter%2Flibnnstreamer_filter_tensorflow2-lite.ap%2F4352dea8bd0ee59ed68a89643dd45a97b7a829d1_nnstreamer_ext_nnstreamer_tensor_filter_tensor_filter_tensorflow_lite.cc.o%20-c%20%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Fnnstreamer%2Fext%2Fnnstreamer%2Ftensor_filter%2Ftensor_filter_tensorflow_lite.cc%3CBR%20%2F%3E%E5%9C%A8%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Ftflite%2Ftensorflow%2Flite%2Fcore%2Fsubgraph.h%3A39%20%E5%8C%85%E5%90%AB%E7%9A%84%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A5%E8%87%AA%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Ftflite%2Ftensorflow%2Flite%2Fcore%2Fasync%2Fasync_subgraph.h%3A27%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A5%E8%87%AA%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Ftflite%2Ftensorflow%2Flite%2Fcore%2Fasync%2Fasync_signature_runner.h%3A24%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A5%E8%87%AA%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Ftflite%2Ftensorflow%2Flite%2Fcore%2Finterpreter.h%3A45%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A5%E8%87%AA%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Ftflite%2Ftensorflow%2Flite%2Fcore%2Finterpreter_builder.h%3A38%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A5%E8%87%AA%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Ftflite%2Ftensorflow%2Flite%2Fcore%2Fmodel.h%3A26%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A5%E8%87%AA%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Ftflite%2Ftensorflow%2Flite%2Fcore%2Fkernels%2Fregister.h%3A22%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A5%E8%87%AA%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Ftflite%2Ftensorflow%2Flite%2Fkernels%2Fregister.h%3A20%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A5%E8%87%AA%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Fnnstreamer%2Fext%2Fnnstreamer%2Ftensor_filter%2Ftensor_filter_tensorflow_lite.cc%3A47%EF%BC%9A%3CBR%20%2F%3E%20%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fbuild_lsdk2412%2Fapps%2Fapps_arm64_debian_desktop%2Fusr%2Finclude%2Ftensorflow%2Flite%2Fgraph_info.h%3A125%3A1%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E5%A4%9A%E8%A1%8C%E6%B3%A8%E9%87%8A%5B-Wcomment%5D%3CBR%20%2F%3E%20125%20%7C%20%2F%2F%20%2F------------%5C%3CBR%20%2F%3E%20%7C%20%5E%3CBR%20%2F%3E%20%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fbuild_lsdk2412%2Fapps%2Fapps_arm64_debian_desktop%2Fusr%2Finclude%2Ftensorflow%2Flite%2Fgraph_info.h%3A137%3A1%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%E5%A4%9A%E8%A1%8C%E6%B3%A8%E9%87%8A%5B-Wcomment%5D%3CBR%20%2F%3E%20137%20%7C%20%2F%2F%20%2F------------%5C%3CBR%20%2F%3E%20%7C%20%5E%3CBR%20%2F%3E%E5%9C%A8%20%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Ftflite%2Ftensorflow%2Fcore%2Fplatform%2Fbfloat16.h%3A20%20%E5%8C%85%E5%90%AB%E7%9A%84%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A5%E8%87%AA%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Ftflite%2Ftensorflow%2Fcore%2Fplatform%2Ftypes.h%3A19%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A5%E8%87%AA%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Ftflite%2Ftensorflow%2Fcore%2Fplatform%2Flogging.h%3A19%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A5%E8%87%AA%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fbuild_lsdk2412%2Fapps%2Fapps_arm64_debian_desktop%2Fusr%2Finclude%2Ftensorflow%2Flite%2Fmodel.h%3A30%EF%BC%8C%3CBR%20%2F%3E%E6%9D%A5%E8%87%AA%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Fnnstreamer%2Fext%2Fnnstreamer%2Ftensor_filter%2Ftensor_filter_tensorflow_lite.cc%3A48%EF%BC%9A%3CBR%20%2F%3E%20%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fcomponents_lsdk2412%2Fapps%2Fml%2Ftflite%2Ftensorflow%2Fcore%2Fplatform%2Fbyte_order.h%3A19%3A10%3A%E8%87%B4%E5%91%BD%E9%94%99%E8%AF%AF%EF%BC%9Atsl%2Fplatform%2Fbyte_order.h%EF%BC%9A%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3CBR%20%2F%3E19%20%7C%20%23include%20%E2%80%9Ctsl%2Fplatform%2Fbyte_order.h%E2%80%9D%3CBR%20%2F%3E%7C%20%5E~~~~~~~~~~~~~~~~~~~~~~~~~~~~%3CBR%20%2F%3E%E7%BC%96%E8%AF%91%E7%BB%88%E6%AD%A2%E3%80%82%3CBR%20%2F%3E%5B34%2F76%5D%20%E7%BC%96%E8%AF%91%20C%2B%2B%20%E5%AF%B9%E8%B1%A1%E6%B5%8B%E8%AF%95%2Funittest_sink.p%2Fnnstreamer_sink_unittest_sink.cc.o%3CBR%20%2F%3E%20ninja%EF%BC%9A%E6%9E%84%E5%BB%BA%E5%B7%B2%E5%81%9C%E6%AD%A2%EF%BC%9A%E5%AD%90%E5%91%BD%E4%BB%A4%E5%A4%B1%E8%B4%A5%E3%80%82%3CBR%20%2F%3E%E4%BD%BF%5B1%5D%EF%BC%9A***%5B%2Fhome%2Fjskim%2FProject%2Fimx93-flexbuild%2Fflexbuild%2Fsrc%2Fapps%2Fml%2Fnnstreamer.mk%3A10%EF%BC%9Annstreamer%5D%E9%94%99%E8%AF%AF1%3CBR%20%2F%3E%20make%EF%BC%9A***%20%5BMakefile%EF%BC%9A21%EF%BC%9Aml%5D%20%E9%94%99%E8%AF%AF%202%3CBR%20%2F%3E%20%5Broot%40fbdebian%20flexbuild%5D%24%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2035245%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%97%AE%E9%A2%98%20flexbuild%20%E9%94%99%E8%AF%AF%20-%20i.MX%20Debian%20Linux%20SDK%20%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2035245%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245751%22%20target%3D%22_blank%22%3E%40jskim169%3C%2FA%3E!%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E8%81%94%E7%B3%BB%20NXP%20%E6%94%AF%E6%8C%81%EF%BC%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%85%B3%E4%BA%8Edocker%E7%89%88%E6%9C%AC%E9%97%AE%E9%A2%98%EF%BC%8C%E5%BB%BA%E8%AE%AE%E5%8D%B8%E8%BD%BDdocker%EF%BC%8C%E6%8C%89%E7%85%A7%E6%8C%87%E5%8D%97%E9%87%8D%E6%96%B0%E5%AE%89%E8%A3%85%E3%80%82%E9%87%8D%E6%96%B0%E5%AE%89%E8%A3%85%E6%97%B6%E4%B8%8D%E9%9C%80%E8%A6%81%E6%8C%87%E5%AE%9A%E7%89%88%E6%9C%AC%E3%80%82%E4%BB%96%E4%BB%AC%E5%B7%B2%E7%BB%8F%E5%9C%A8%20ubuntu%2020.04%20%E5%92%8C%2022.04%20%E4%B8%8A%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%EF%BC%8C%E5%B9%B6%E4%B8%94%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FUG10155%2Fpage%2Ftopics%2Fbuilding_an_image_in_flexbuild.html%3F_gl%3D1*20uc0d*_ga*NjYzMTk1NjA4LjE3MjIwMDU1Mzg.*_ga_WM5LE0KMSH*MTczODA4MjAzMS40NjcuMS4xNzM4MDg3NjA3LjAuMC4w%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fdocs.nxp.com%2Fbundle%2FUG10155%2Fpage%2Ftopics%2Fbuilding_an_image_in_flexbuild.html%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%81%3C%2FP%3E%0A%3CP%3EChavira%3C%2FP%3E%3C%2FLINGO-BODY%3E
