Query on Power consumption on I.MX7 dual
3,538 次查看
dineshguni
Is there any document or tool to calculate the I.MX7 dual/solo power consumption based on the use case or the interfaces enabled.
Dinesh
标记 (2)
5 回复数
3,080 次查看
Hi Dinesh
unfortunately such power calculator tool is not available.
3,080 次查看
dineshguni
Hi Igor,
Thanks for your quick response. Is there any use case power consumption document (like I.MX6 has one, http://www.nxp.com/files/32bit/doc/app_note/AN4715.pdf ) which could give approximate operating power details?
We are trying to get the realistic power consumption values for our custom product, is there any other way to get these details for I.MX7 dual?
Dinesh
3,080 次查看
Hi Dinesh
unfortunately such app note is not available.
You can try to create service request for obtaining more data.
3,080 次查看
infanneraysh
Hi Igor,
I'm looking for the same details now "Is there any document or tool to calculate the I.MX7 dual/solo power consumption based on the use case or the interfaces enabled ? And Is there any use case power consumption document (like I.MX6 has one, http://www.nxp.com/files/32bit/doc/app_note/AN4715.pdf ) which could give approximate operating power details? "
As it is one year now since this question is raised, is there any tool/document available now ?
3,080 次查看
Hi Infan
