How to via MFG tool do security boot on the i.mx7d
已解决
跳至解决方案
1,804 次查看
felixhsu
Hi all
Follow the AN4581,
The customer use MFG tool still fail execute security boot, as below is related log.
local\mfgtool\Profiles\linux\OS Firmware\firmware\u-boot-imx7dsabresd_sd.imx
ModuleID[2] LevelID[1]: HAB type mismatch: 0x332233!!!
ModuleID[2] LevelID[10]: *********MxHidDevice[030096B0] Jump to Ramkernel successfully!**********
ModuleID[2] LevelID[1]: MxHidDevice::Write() Error writing to device 0x79.
ModuleID[2] LevelID[1]: RunPlugIn(): TransData(0x877FBFD4, 0x6BBC8,0x0) failed.
Could you provide document for i.mx7D?
Thanks.
Original Attachment has been moved to: csf_u-boot_yocto_mfg_3.10.53.txt.zip
Original Attachment has been moved to: MfgTool.log.zip
标签 (4)
1 解答
1,486 次查看
Yuri
  It is needed also to sign u-boot for mfgtools firmware and sign mfgtool firmware zImage,
if use the MFG with closed i.MX device.
  Please create request to get more information.
Support|NXP
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
在原帖中查看解决方案
1 回复
1,487 次查看
Yuri
Support|NXP
Yuri
button. Thank you!
