Power optimisation in imx8mp
1,797 次查看
karthicknarayanan
I am trying to do power optimisation in imx8mp processor, its application is to capture data from camera sensor and displaying it. I tried it with changing CPU frequency governors by following
How to reduce the CPU Frequency on iMX8M
 observed different results in power like
  • 3.8W in default frequency governor (Frequency 1.6 Ghz) with no compromise on performance
  •  3.45W to 3.65W with other frequencies ranging from (100Mhz - 1.2Ghz) but experiencing frame drops while capturing data.
  • I need optimal power consumption around 3W.
I am looking for possibilities in by adjusting ddr frequency and disabling any one of the 4 CPUs,but still cannot find proper method of doing it.
And my question is
Will reducing CPU frequency or DDR frequency or disabling CPU core results in similar observation which I have mentioned above with compromise on performance ?
And using VPU instead of using CPU to capture frames will result in better performance and power consumption ?
1,766 次查看
Zhiming_Liu
Hi @karthicknarayanan
Please refer the AN13054 i.MX 8M Plus Power Consumption Measurement.
-->Of course,
-->VPU is used for decode or encode, not read frame.
