Power Optimization on display
1,911 次查看
ajita02
Hi all,
We are using IMX8MM with LCD display over MIPI-DSI. I want to perform power optimization.
We are using Boot2QT package with kernel version 5.4.147. We have gone through few things. Please help us/ Confirm below findings.
1. Currently weston is offloading rendering to 2D GPU as default. Can we check for how much GPU % getting used like htop? How to be sure 3D GPU is not using? can we offload rendering on CPU so that GPU can be disabled to save power. When I tried to use "pixman" renderer for CPU, weston 8.0.0 does not support it. Any alternate way to do so?
2. Current weston's default shell is desktop-shell. As read online, Kiosk shell is suitable for more power optimization but it seems that Current Yocto setup does not support it.
3. When we setting static screen on display, we want display/MIPI-DSI/weston should not refresh display/DDR memory until any display related activity happens.
4. We have changed display-panel drivers configuration from 60FPS to 30FPS. Will it reflect on power optimization? As we are not seeing difference in current consumption.
Ajita
#IMX8MM #WESTON #LINUX #power_optimization #MIPI-DSI
标记 (3)
5 回复数
1,910 次查看
ajita02
Is there any document for performing power optimization on linux/IMX8MM for reference.? Is anything else we can try to reduce current consumption?
1,886 次查看
Rita_Wang
We only have supply this AN you can refer to i.MX 8M Mini Power Consumption Measurement
1,883 次查看
ajita02
HI Rita,
Thanks for this document. Can you help me with weston/display related query?
1,854 次查看
Rita_Wang
Hi @ajita02 ,
Sorry we do not have this doucment for it. We only supply the AN I upload to you above.
Wish you have a nice day
Best Regards
Rita
1,804 次查看
ajita02
Hi @Rita_Wang ,
Ajita
标记 (1)
%3CLINGO-SUB%20id%3D%22lingo-sub-2207485%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%B1%95%E7%A4%BA%E7%94%B5%E6%BA%90%E4%BC%98%E5%8C%96%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2207485%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E9%80%9A%E8%BF%87%20MIPI-DSI%20%E4%BD%BF%E7%94%A8%E5%B8%A6%E6%9C%89%20LCD%20%E6%98%BE%E7%A4%BA%E5%B1%8F%E7%9A%84%20IMX8MM%E3%80%82%E6%88%91%E6%83%B3%E8%BF%9B%E8%A1%8C%E5%8A%9F%E7%8E%87%E4%BC%98%E5%8C%96%E3%80%82%3CBR%20%2F%3E%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%E4%B8%BA%205.4.147%20%E7%9A%84%20Boot2QT%20%E4%BB%A3%E7%A0%81%E5%8C%85%E3%80%82%E6%88%91%E4%BB%AC%E7%BB%8F%E5%8E%86%E4%BA%86%E4%B8%80%E4%BA%9B%E4%BA%8B%E6%83%85%E3%80%82%E8%AF%B7%E5%B8%AE%E5%8A%A9%E6%88%91%E4%BB%AC%2F%E7%A1%AE%E8%AE%A4%E4%BB%A5%E4%B8%8B%E5%8F%91%E7%8E%B0%E3%80%82%3C%2FP%3E%3CP%3E1.%E7%9B%AE%E5%89%8D%EF%BC%8Cweston%20%E9%BB%98%E8%AE%A4%E5%B0%86%E6%B8%B2%E6%9F%93%E5%8D%B8%E8%BD%BD%E5%88%B0%202D%20GPU%E3%80%82%E6%88%91%E4%BB%AC%E8%83%BD%E5%90%A6%E5%83%8F%20htop%20%E4%B8%80%E6%A0%B7%E6%A3%80%E6%9F%A5%20GPU%25%20%E7%9A%84%E4%BD%BF%E7%94%A8%E6%83%85%E5%86%B5%EF%BC%9F%E5%A6%82%E4%BD%95%E7%A1%AE%E5%AE%9A%203D%20GPU%20%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8%EF%BC%9F%E6%88%91%E4%BB%AC%E8%83%BD%E5%90%A6%E5%9C%A8%20CPU%20%E4%B8%8A%E5%8D%B8%E8%BD%BD%E6%B8%B2%E6%9F%93%EF%BC%8C%E4%BB%8E%E8%80%8C%E7%A6%81%E7%94%A8%20GPU%20%E4%BB%A5%E8%8A%82%E7%9C%81%E7%94%B5%E8%83%BD%EF%BC%9F%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E5%9C%A8%20CPU%20%E4%B8%8A%E4%BD%BF%E7%94%A8%22pixman%22%20%E6%B8%B2%E6%9F%93%E5%99%A8%E6%97%B6%EF%BC%8Cweston%208.0.0%20%E4%B8%8D%E6%94%AF%E6%8C%81%E5%AE%83%E3%80%82%E6%9C%89%E5%85%B6%E4%BB%96%E5%8A%9E%E6%B3%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E2.%E5%BD%93%E5%89%8D%20weston%20%E7%9A%84%E9%BB%98%E8%AE%A4%20shell%20%E6%98%AF%20desktop-shell%E3%80%82%E4%BB%8E%E7%BD%91%E4%B8%8A%E4%BA%86%E8%A7%A3%E5%88%B0%EF%BC%8CKiosk%20shell%20%E9%80%82%E7%94%A8%E4%BA%8E%E6%9B%B4%E5%A4%A7%E5%8A%9F%E7%8E%87%E7%9A%84%E4%BC%98%E5%8C%96%EF%BC%8C%E4%BD%86%E7%9B%AE%E5%89%8D%E7%9A%84%20Yocto%20%E8%AE%BE%E7%BD%AE%E4%BC%BC%E4%B9%8E%E4%B8%8D%E6%94%AF%E6%8C%81%E5%AE%83%E3%80%82%3C%2FP%3E%3CP%3E3.%E5%BD%93%E6%88%91%E4%BB%AC%E5%9C%A8%E6%98%BE%E7%A4%BA%E5%99%A8%E4%B8%8A%E8%AE%BE%E7%BD%AE%E9%9D%99%E6%80%81%E5%B1%8F%E5%B9%95%E6%97%B6%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B8%8C%E6%9C%9B%E6%98%BE%E7%A4%BA%E5%99%A8%2FMIPI-DSI%2FWeston%20%E4%B8%8D%E5%88%B7%E6%96%B0%E6%98%BE%E7%A4%BA%E5%99%A8%2FDDR%20%E5%86%85%E5%AD%98%EF%BC%8C%E7%9B%B4%E5%88%B0%E5%8F%91%E7%94%9F%E4%BB%BB%E4%BD%95%E4%B8%8E%E6%98%BE%E7%A4%BA%E7%9B%B8%E5%85%B3%E7%9A%84%E6%B4%BB%E5%8A%A8%E3%80%82%3C%2FP%3E%3CP%3E4.%E6%88%91%E4%BB%AC%E5%B7%B2%E5%B0%86%E6%98%BE%E7%A4%BA%E9%9D%A2%E6%9D%BF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%85%8D%E7%BD%AE%E4%BB%8E%2060FPS%20%E6%94%B9%E4%B8%BA%2030FPS%E3%80%82%E8%BF%99%E6%98%AF%E5%90%A6%E4%BC%9A%E5%BD%B1%E5%93%8D%E5%8A%9F%E7%8E%87%E4%BC%98%E5%8C%96%EF%BC%9F%E5%9B%A0%E4%B8%BA%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%E7%9C%8B%E5%88%B0%E7%94%B5%E6%B5%81%E6%B6%88%E8%80%97%E6%9C%89%E4%BB%80%E4%B9%88%E4%B8%8D%E5%90%8C%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3EAjita%3CBR%20%2F%3E%3CBR%20%2F%3E%23IMX8MM%20%23WESTON%20%23LINUX%20%23power_optimization%20%23MIPI-DSI%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2230289%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Power%20Optimization%20on%20display%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2230289%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F57740%22%20target%3D%22_blank%22%3E%40Rita_Wang%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E7%9B%AE%E5%89%8D%EF%BC%8Cweston%20%E9%BB%98%E8%AE%A4%E5%B0%86%E6%B8%B2%E6%9F%93%E5%8D%B8%E8%BD%BD%E5%88%B0%202D%20GPU%E3%80%82%E6%88%91%E4%BB%AC%E8%83%BD%E5%90%A6%E5%83%8F%20htop%20%E4%B8%80%E6%A0%B7%E6%A3%80%E6%9F%A5%20GPU%25%20%E7%9A%84%E4%BD%BF%E7%94%A8%E6%83%85%E5%86%B5%EF%BC%9F%E5%A6%82%E4%BD%95%E7%A1%AE%E5%AE%9A%203D%20GPU%20%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8%EF%BC%9F%E6%88%91%E4%BB%AC%E8%83%BD%E5%90%A6%E5%9C%A8%20CPU%20%E4%B8%8A%E5%8D%B8%E8%BD%BD%E6%B8%B2%E6%9F%93%EF%BC%8C%E4%BB%8E%E8%80%8C%E7%A6%81%E7%94%A8%20GPU%20%E4%BB%A5%E8%8A%82%E7%9C%81%E7%94%B5%E8%83%BD%EF%BC%9F%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E5%9C%A8%20CPU%20%E4%B8%8A%E4%BD%BF%E7%94%A8%22pixman%22%20%E6%B8%B2%E6%9F%93%E5%99%A8%E6%97%B6%EF%BC%8Cweston%208.0.0%20%E4%B8%8D%E6%94%AF%E6%8C%81%E5%AE%83%E3%80%82%E6%9C%89%E5%85%B6%E4%BB%96%E5%8A%9E%E6%B3%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E9%98%BF%E5%90%89%E5%A1%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2217177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Power%20Optimization%20on%20display%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2217177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F217485%22%20target%3D%22_blank%22%3E%40ajita02%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E5%BE%88%E6%8A%B1%E6%AD%89%EF%BC%8C%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%E8%BF%99%E6%96%B9%E9%9D%A2%E7%9A%84%E8%B5%84%E6%96%99%E3%80%82%E6%88%91%E4%BB%AC%E5%8F%AA%E6%8F%90%E4%BE%9B%E6%88%91%E5%9C%A8%E4%B8%8A%E9%9D%A2%E4%B8%8A%E4%BC%A0%E7%9A%84%20AN%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%9C%89%E7%BE%8E%E5%A5%BD%E7%9A%84%E4%B8%80%E5%A4%A9%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3ERita%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2208142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Power%20Optimization%20on%20display%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2208142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHI%20Rita%2C%3CBR%20%2F%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E8%BF%99%E4%BB%BD%E6%96%87%E4%BB%B6%E3%80%82%E6%82%A8%E8%83%BD%E5%B8%AE%E6%88%91%E8%A7%A3%E5%86%B3%20Weston%2F%E6%98%BE%E7%A4%BA%E5%B1%8F%E7%9B%B8%E5%85%B3%E7%9A%84%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2207807%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Power%20Optimization%20on%20display%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2207807%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BB%AC%E4%BB%85%E6%8F%90%E4%BE%9B%E6%AD%A4%20AN%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com.cn%2Fdocs%2Fen%2Fapplication-note%2FAN12410.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ei.MX%208M%20Mini%20%E5%8A%9F%E8%80%97%E6%B5%8B%E9%87%8F%3C%2FA%3E%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2207487%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Power%20Optimization%20on%20display%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2207487%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E4%BB%BB%E4%BD%95%E5%85%B3%E4%BA%8E%E5%9C%A8%20Linux%2FIMX8mm%20%E4%B8%8A%E8%BF%9B%E8%A1%8C%E5%8A%9F%E8%80%97%E4%BC%98%E5%8C%96%E7%9A%84%E6%96%87%E6%A1%A3%E5%8F%AF%E4%BE%9B%E5%8F%82%E8%80%83%EF%BC%9F%E6%88%91%E4%BB%AC%E8%BF%98%E6%9C%89%E4%BB%80%E4%B9%88%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E5%87%8F%E5%B0%91%E7%94%B5%E6%B5%81%E6%B6%88%E8%80%97%E7%9A%84%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
