Please help me out...Getting build issue
1,102 次查看
rakeshpatil
I am trying to make image:
Commands:
$ source build/envsetup.sh
$ lunch sabresd_6dq-user
$ make systemimage
Getting error as:
make: *** No rule to make target `out/target/product/sabresd_6dq/obj/SHARED_LIBRARIES/libRS_intermediates/export_includes', needed by `out/target/product/sabresd_6dq
/obj/SHARED_LIBRARIES/libhwui_intermediates/import_includes'.  Stop.
Attached the full log for reference.
Android source code base : android-4.4.3_r1
i.MX Android release package : android_KK4.4.3_2.0.0-ga_core
Ubuntu 14.04, 64bit
Please let me know the solution for this issue.
Thanks a lot.
Rakesh
Original Attachment has been moved to: build_sabresd_6dq_android.log.zip
标签 (3)
839 次查看
gusarambula
Hello Rakesh Patil,
I’m sorry to hear you’re having trouble building the Android BSP.
Which image are you building? If you want to build the SABRE 6D/Q User image you should run just make after setting the specs with lunch.
$ cd ~/myandroid
$ make 2>&1 | tee build_sabresd_6dq_android.log
Let us know if these commands help.
