Parallel NOR-Flash of 16bit BUS and IVT data
2,087 次查看
tamotsu
Hellow.
On page 1241 of the i.MX7D reference manual, the IVT header format diagram suggests that the value to be set would be 0xD1-0x0020-0x40 to .word 0xD1002040, but in the 20132 "i.MX6 IVT structure" Anson Huang answers that it should be .word 0x402000D1.
I think the manual says this is
0x400 = 0xD100
0x402 = 0x2040
but is that wrong?
Thank you.
2,031 次查看
Harvey021
The header ivt should be included in image by default, we don't need to modify it.
And we can try to dump it using command od w/t option little or big endian
od -x -N 48 --endian=little u-boot.imx
or
od -x -N 48 --endian=big u-boot.imx
Harvey
2,062 次查看
Harvey021
tag = D1 is the first byte. The difference as Anson's should be caused by display options, like endian.
Harvey
2,050 次查看
tamotsu
Thank you Harvey021.
So Anson explained it in little-endian?
I'm confused because the reference manual says it's big-endian.
2,032 次查看
Harvey021
or
Harvey
%3CLINGO-SUB%20id%3D%22lingo-sub-2000590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E16%E4%BD%8D%E6%80%BB%E7%BA%BF%E5%92%8CIVT%E6%95%B0%E6%8D%AE%E7%9A%84%E5%B9%B6%E8%A1%8CNOR-Flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2000590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%9C%A8%20i.MX7D%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E7%AC%AC%201241%20%E9%A1%B5%E4%B8%8A%EF%BC%8CIVT%20%E5%A4%B4%E6%A0%BC%E5%BC%8F%E5%9B%BE%E8%A1%A8%E6%98%8E%E8%A6%81%E8%AE%BE%E7%BD%AE%E7%9A%84%E5%80%BC%E4%B8%BA%200xD1-0x0020-0x40%20%E5%88%B0%20.word0xD1002040%EF%BC%8C%E4%BD%86%E5%9C%A820132%E5%B9%B4%E2%80%9Ci.MX6%20IVT%E7%BB%93%E6%9E%84%E2%80%9D%E4%B8%ADAnson%20Huang%E5%9B%9E%E7%AD%94%E8%AF%B4%E5%BA%94%E8%AF%A5%E6%98%AF.word0x402000D1%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E6%89%8B%E5%86%8C%E4%B8%8A%E8%AF%B4%E7%9A%84%E6%98%AF%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E0x400%20%3D%200xD100%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E0x402%20%3D%200x2040%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%BD%86%E8%BF%99%E6%98%AF%E9%94%99%E8%AF%AF%E7%9A%84%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2002315%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A16%E4%BD%8D%E6%80%BB%E7%BA%BF%E5%92%8CIVT%E6%95%B0%E6%8D%AE%E7%9A%84%E5%B9%B6%E8%A1%8CNOR%E9%97%AA%E5%AD%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2002315%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%20Harvey021%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%82%A3%E4%B9%88%E5%AE%89%E6%A3%AE%E7%94%A8%E5%B0%8F%E7%AB%AF%E6%96%B9%E5%BC%8F%E8%A7%A3%E9%87%8A%E4%BA%86%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E5%BE%88%E5%9B%B0%E6%83%91%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E8%AF%B4%E5%AE%83%E6%98%AF%E5%A4%A7%E7%AB%AF%E7%9A%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
