I use the camera (AR0144) and it supports two resolutions, 1280x800 and 1280x720. When I open the camera use the command:
gst-launch-1.0 v4l2src ! "video/x-raw, format=YUY2, width=1280, height=800" ! waylandsink sync=false
Firstly I open the camera and it can work and display on the screen. However, it cannot work when I run the same command again.
I tried to enable the debug message for imx8_mipi_csi, and I got the messages:
First open:
# gst-launch-1.0 v4l2src ! "video/x-raw, format=YUY2, width=1280, height=800" ! waylandsink sync=false --no-position
[ 1476.418575] mxc-mipi-csi2.1: unsupported csi-sam command -1068476902.
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
[ 1500.131243] bypass csc
[ 1500.134005] input fmt YUV4
[ 1500.136711] output fmt YUYV
Redistribute latency...
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:00:04.035551916
Setting pipeline to NULL ...
[ 1504.326200] mxc-mipi-csi2.1: Frame End events: 112
[ 1504.330995] mxc-mipi-csi2.1: Frame Start events: 113
[ 1504.335959] mxc-mipi-csi2.1: Non-image data after odd frame events: 0
[ 1504.342398] mxc-mipi-csi2.1: Non-image data before odd frame events: 0
[ 1504.348924] mxc-mipi-csi2.1: Non-image data after even frame events: 0
[ 1504.355451] mxc-mipi-csi2.1: Non-image data before even frame events: 0
[ 1504.362064] mxc-mipi-csi2.1: Unknown Error events: 0
[ 1504.367028] mxc-mipi-csi2.1: CRC Error events: 0
[ 1504.371644] mxc-mipi-csi2.1: ECC Error events: 0
[ 1504.376260] mxc-mipi-csi2.1: FIFO Overflow Error events: 2732
[ 1504.382007] mxc-mipi-csi2.1: Lost Frame End Error events: 0
[ 1504.387580] mxc-mipi-csi2.1: Lost Frame Start Error events: 0
[ 1504.393324] mxc-mipi-csi2.1: SOT Error events: 0
Total showed frames (111), playing for (0:00:04.035533792), fps (27.506).
Freeing pipeline ...
Then I open camera again:
New clock: Gst[ 1507.418234] bypass csc
SystemClock
[ 1507.421390] input fmt YUV4
[ 1507.425235] output fmt YUYV
Execution ended after 0:00:01.810321782
[ 1509.390289] mxc-mipi-csi2.1: Frame End events: 0
[ 1509.394910] mxc-mipi-csi2.1: Frame Start events: 1
[ 1509.399700] mxc-mipi-csi2.1: Non-image data after odd frame events: 0
[ 1509.406140] mxc-mipi-csi2.1: Non-image data before odd frame events: 0
[ 1509.412667] mxc-mipi-csi2.1: Non-image data after even frame events: 0
[ 1509.419193] mxc-mipi-csi2.1: Non-image data before even frame events: 0
[ 1509.425806] mxc-mipi-csi2.1: Unknown Error events: 0
[ 1509.430770] mxc-mipi-csi2.1: CRC Error events: 0
[ 1509.435387] mxc-mipi-csi2.1: ECC Error events: 0
[ 1509.440003] mxc-mipi-csi2.1: FIFO Overflow Error events: 145787
[ 1509.445922] mxc-mipi-csi2.1: Lost Frame End Error events: 0
[ 1509.451492] mxc-mipi-csi2.1: Lost Frame Start Error events: 0
[ 1509.457235] mxc-mipi-csi2.1: SOT Error events: 0
There are FIFO Overflow Error events.
If I open the camera with 1280x720. It always can work without any FIFO Overflow Error.
# gst-launch-1.0 v4l2src ! "video/x-raw, format=YUY2, width=1280, height=720" ! waylandsink sync=false --no-position
New clock: GstSy[ 73.264703] bypass csc
stemClock
[ 73.268061] input fmt YUV4
[ 73.271726] output fmt YUYV
Execution ended after 0:00:02.606334875
[ 76.021912] mxc-mipi-csi2.1: Frame End events: 134
[ 76.026706] mxc-mipi-csi2.1: Frame Start events: 134
[ 76.031671] mxc-mipi-csi2.1: Non-image data after odd frame events: 0
[ 76.038111] mxc-mipi-csi2.1: Non-image data before odd frame events: 0
[ 76.044637] mxc-mipi-csi2.1: Non-image data after even frame events: 0
[ 76.051162] mxc-mipi-csi2.1: Non-image data before even frame events: 0
[ 76.057775] mxc-mipi-csi2.1: Unknown Error events: 0
[ 76.062738] mxc-mipi-csi2.1: CRC Error events: 0
[ 76.067354] mxc-mipi-csi2.1: ECC Error events: 0
[ 76.071969] mxc-mipi-csi2.1: FIFO Overflow Error events: 0
[ 76.077453] mxc-mipi-csi2.1: Lost Frame End Error events: 0
[ 76.083023] mxc-mipi-csi2.1: Lost Frame Start Error events: 0
[ 76.088768] mxc-mipi-csi2.1: SOT Error events: 0
Total showed frames (132), playing for (0:00:02.606324125), fps (50.646).
WHY it occurred FIFO Overflow Error when I open the camera with 1280x800?
How can I solve the problem?
By the way, there is the device tree setting for mipi csi:
fragment@0 {
target = <&mipi_csi_0>;
__overlay__ {
#address-cells = <1>;
#size-cells = <0>;
clock-frequency = <500000000>;
status = "okay";
port@0 {
reg = <0>;
mipi_csi0_ep: endpoint {
remote-endpoint = <&tevi_ap1302_0_ep>;
data-lanes = <4>;
csis-hs-settle = <19>;
csis-clk-settle = <2>;
csis-wclk;
The result:
# v4l2-ctl -d /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture Multiplanar
[0]: 'RGBP' (16-bit RGB 5-6-5)
Interval: Discrete 0.017s (60.000 fps)
[1]: 'RGB3' (24-bit RGB 8-8-8)
[2]: 'BGR3' (24-bit BGR 8-8-8)
[3]: 'YUYV' (YUYV 4:2:2)
[4]: 'YUV4' (32-bit A/XYUV 8-8-8-8)
[5]: 'NV12' (Y/CbCr 4:2:0)
[6]: 'NM12' (Y/CbCr 4:2:0 (N-C))
[7]: 'YM24' (Planar YUV 4:4:4 (N-C))
[8]: 'XR24' (32-bit BGRX 8-8-8-8)
[9]: 'AR24' (32-bit BGRA 8-8-8-8)
