OV5640 camera not detected
10,971 次查看
aravinthkumarja
Senior Contributor II
Hi All,
I'm using OV5640 mipi camera in imx6 and I'm getting below error.
[ 2.004525] ov564x_mipi 3-003c: found pwm2, period=0
[ 2.296520] ov5640_read_reg:write reg error:reg=300a
[ 2.296522] camera ov5640_mipi is not found
What is the reason for this error.?
How to fix this.
Aravinth
标签 (4)
7 回复数
9,988 次查看
igorpadykov
Hi Aravinth
issue may be related to i2c problems, one can try to debug it using
Chapter 19 OmniVision Camera Driver attached Linux manual.
i2c also can be tested using baremetal sdk found on SMP Enable in IMX6
9,988 次查看
aravinthkumarja
Hi igor,
Thanks for your response. I have configured as mentioned in document. But I don't know why I'm facing this issue.?
Aravinth
9,988 次查看
igorpadykov
Hi Aravinth
reason may be that i2c is not working
9,988 次查看
aravinthkumarja
Hi igor,
I2C interface and camera both are working, I have validated in linux BSP and camera driver as module (.ko).
If I make it as inbuilt it's not working in linunx BSP. In Android BSP camera not at all working in both module and inbuilt build.
Regards.
Aravinth
9,988 次查看
igorpadykov
Hi Aravinth
if i2c is working one can try to debug it in camera driver described in sect.6.1.8
Source Code Structure attached Linux Manual.
9,988 次查看
aravinthkumarja
Thanks igor, It's default driver code.
Finally I have fixed that issue.
Aravinth
9,988 次查看
leeshuai
Hi Aravinth
          How do you fixed that issue?
