OV2659 has split image on iMX6ULL
4,015 次查看
Blackrose
Fresh Out Contributor
Hi, everyone.I use ov2659 camera sensor connects with my custom iMX6ULL board.I directly used driver/media/i2c/ov2659.c code on linux kernel.The image has been displayed.But the image has two problems:
1.It has a bar on left
2.the image been split
I use ov5640 to test the hardware bus.The ov5640's picture is correct.
The below picture is snapshot form ov2659.Is it timing wrong on ov2659 driver of other thing?
标签 (4)
5 回复数
3,509 次查看
joanxie
how about the result by using unit test? any log file to share?
3,509 次查看
Blackrose
I found it.I modify to only test camera on file autorun-v4l2.sh.The below is result.
==== v4l2 capture test: 640 X 480 @ 30 ====
==== save frame count: 5 ====
Running test case: ./mxc_v4l2_capture.out -640 -ih 480 -ow 640 -oh 480 -fr 30 -m 0 -c 5 test.yuv
in_width = 176, in_height = 480
out_width = 640, out_height = 480
top = 0, left = 0
VIDIOC_DBG_G_CHIP_IDENT failed.
get format failed
test-camera.sh: FAIL test case: ./mxc_v4l2_capture.out -640 -ih 480 -ow 640 -oh 480 -fr 30 -m 0 -c 5 test.yuv
==== save frame count: 10 ====
Running test case: ./mxc_v4l2_capture.out -640 -ih 480 -ow 640 -oh 480 -fr 30 -m 0 -c 10 test.yuv
top = 0, left = 0
get format failed
test-camera.sh: FAIL test case: ./mxc_v4l2_capture.out -640 -ih 480 -ow 640 -oh 480 -fr 30 -m 0 -c 10 test.yuv
3,509 次查看
joanxie
we haven't tested this driver you use, I don't know if the driver has any issue or not, you can refer to the driver of ov5642, I post the topic about this camera, but the customer don't share the experience there, but you can refer to it.
https://community.nxp.com/message/540788
3,509 次查看
Blackrose
Thanks again.And I also happened another problem on ov5640.I got a new ov5640 camera and connect it with my imx6ull board.I found only 800x600 resolution is correct.Other resolutions have difference issue, such as picture has spilled four picture, a bar on left of the picture.
3,509 次查看
Blackrose
Which unit test? I had test more resolutions by driver supported.The 800x600 is right and others are same issue on that.
