OTA-requestor-app issue on NXP i.MX8MM
2,240件の閲覧回数
yinliangren
I met the following problems when I was working on the project matter with NXP i.MX8MM board.
Current state
1.    I ran OTA-requestor-app on the YOCTO system to upgrade the thermostat-app.  44,384 packets were received and used for more than three hours.
2.   After I used gzip compression, I used OTA-requestor-app to upgrade   the thermostat-app  .16,319 packets. 36 minutes.
3 . The upgrade files received by the preceding two methods can run properly.
Present problems :
1.  How to solve the problem of long OTA upgrade time
2.  I changed the thermostat-app  software version number(/connectedhomeip/src/include/platform/CHIPDeviceConfig.h)
2.  I run the thermostat-app  at YOCTO.What Can I do if the OAT upgrade command fails to be executed?The information is as follows:
Execute a command:
sudo ./connectedhomeip/out/standalone/chip-tool  otasoftwareupdaterequestor announce-otaprovider 5678 0 0 0 8888  0
Receive the message:
[1712041578.206873][3710:3712] CHIP:IN: (S) Sending msg 237563467 on secure session with LSID: 3224
[1712041578.207262][3710:3712] CHIP:EM: Flushed pending ack for MessageCounter:244084226 on exchange 9381i
[1712041578.208019][3710:3710] CHIP:CTL: Shutting down the commissioner
[1712041578.208160][3710:3710] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1712041578.208589][3710:3710] CHIP:CTL: Shutting down the controller
[1712041578.208675][3710:3710] CHIP:IN: Expiring all sessions for fabric 0x1!!
[1712041578.208858][3710:3710] CHIP:IN: SecureSession[0xffff7800b4f0]: MarkForEviction Type:2 LSID:3224
[1712041578.208938][3710:3710] CHIP:SC: SecureSession[0xffff7800b4f0]: Moving from state 'kActive' --> 'kPendingEviction'
[1712041578.209014][3710:3710] CHIP:IN: SecureSession[0xffff7800b4f0]: Released - Type:2 LSID:3224
[1712041578.209091][3710:3710] CHIP:FP: Forgetting fabric 0x1
[1712041578.209197][3710:3710] CHIP:TS: Pending Last Known Good Time: 2023-05-08T17:09:28
[1712041578.209704][3710:3710] CHIP:TS: Previous Last Known Good Time: 2023-05-08T17:09:28
[1712041578.209785][3710:3710] CHIP:TS: Reverted Last Known Good Time to previous value
[1712041578.209950][3710:3710] CHIP:CTL: Shutting down the commissioner
[1712041578.210023][3710:3710] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1712041578.210487][3710:3710] CHIP:CTL: Shutting down the controller
[1712041578.210566][3710:3710] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
[1712041578.212047][3710:3710] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
[1712041578.212442][3710:3710] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
[1712041578.212578][3710:3710] CHIP:FP: Shutting down FabricTable
[1712041578.212673][3710:3710] CHIP:TS: Pending Last Known Good Time: 2023-05-08T17:09:28
[1712041578.213232][3710:3710] CHIP:TS: Previous Last Known Good Time: 2023-05-08T17:09:28
[1712041578.213311][3710:3710] CHIP:TS: Reverted Last Known Good Time to previous value
[1712041578.214035][3710:3710] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-CEwe0s)
[1712041578.216682][3710:3710] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1712041578.217104][3710:3710] CHIP:DL: NVS set: chip-counters/total-operational-hours = 1 (0x1)
[1712041578.217189][3710:3710] CHIP:DL: Inet Layer shutdown
[1712041578.217262][3710:3710] CHIP:DL: BLE shutdown
[1712041578.217336][3710:3710] CHIP:DL: System Layer shutdown
[1712041578.218125][3710:3710] CHIP:TOO: Run command failure: IM Error 0x00000581: General error: 0x81 (UNSUPPORTED_COMMAND)
タグ(1)
2,210件の閲覧回数
Bio_TICFSL
Make sure you are using the CHIP thermostat example for the MX8MM, the matter examples will be upgraded but so far is the only examples it provides.
2,211件の閲覧回数
Bio_TICFSL
2,206件の閲覧回数
yinliangren
Got it. Thanks.
%3CLINGO-SUB%20id%3D%22lingo-sub-1841956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ENXP%20i.MX8MM%E3%81%A7%E3%81%AEOTA%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%82%BF%E3%82%A2%E3%83%97%E3%83%AA%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1841956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3ENXP%20i.MX8MM%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E5%95%8F%E9%A1%8C%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81%E6%AC%A1%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%8F%BE%E5%9C%A8%E3%81%AE%E7%8A%B6%E6%85%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E1.%20YOCTO%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7OTA-requestor-app%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%80%81%E3%82%B5%E3%83%BC%E3%83%A2%E3%82%B9%E3%82%BF%E3%83%83%E3%83%88%E3%82%A2%E3%83%97%E3%83%AA%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%8244%2C384%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%81%8C%E5%8F%97%E4%BF%A1%E3%81%95%E3%82%8C%E3%80%813%E6%99%82%E9%96%93%E4%BB%A5%E4%B8%8A%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E2.%20gzip%E5%9C%A7%E7%B8%AE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81OTA-requestor-app%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6thermostat-app%E3%81%AE.16%2C319%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%8236%E5%88%86%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E3%20.%E4%B8%8A%E8%A8%98%E3%81%AE%202%20%E3%81%A4%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A7%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%9F%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81%E6%AD%A3%E3%81%97%E3%81%8F%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%8F%BE%E5%9C%A8%E3%81%AE%E5%95%8F%E9%A1%8C%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E1.OTA%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E6%99%82%E9%96%93%E3%81%8C%E9%95%B7%E3%81%84%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E2.%20thermostat-app%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E7%95%AA%E5%8F%B7(%2Fconnectedhomeip%2Fsrc%2Finclude%2Fplatform%2FCHIPDeviceConfig.h)%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E2.YOCTO%E3%81%A7%E3%82%B5%E3%83%BC%E3%83%A2%E3%82%B9%E3%82%BF%E3%83%83%E3%83%88%E3%82%A2%E3%83%97%E3%83%AA%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82OAT%20%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E5%AE%9F%E8%A1%8C%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%E6%83%85%E5%A0%B1%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Esudo%20.%2Fconnectedhomeip%2Fout%2Fstandalone%2Fchip-toolOTASileUpdateRequestor%20Announce-OTA%E3%83%97%E3%83%AD%E3%83%90%E3%82%A4%E3%83%80%205678%200%200%200%208888%200%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%AC%A1%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.206873%5D%5B3710%3A3712%5DCHIP%3AIN%3A(S)LSID%E3%81%AE%E5%AE%89%E5%85%A8%E3%81%AA%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8237563467%E3%82%92%E9%80%81%E4%BF%A1%3A3224%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.207262%5D%5B3710%3A3712%5DCHIP%3AEM%3AExchange%209381i%E3%81%AEMessageCounter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x1%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%BB%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99!!%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.208858%5D%5B3710%3A3710%5DCHIP%3AIN%3ASecureSession%5B0xffff7800b4f0%5D%3AMarkForEviction%20Type%3A2%20LSID%3A3224%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.208938%5D%5B3710%3A3710%5DCHIP%3ASC%3ASecureSession%5B0xffff7800b4f0%5D%3A%E7%8A%B6%E6%85%8B%20'kActive'%E3%81%8B%E3%82%89%E7%A7%BB%E5%8B%95%E4%B8%AD%20--%26gt%3B%20'kPendingEviction'%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.209014%5D%5B3710%3A3710%5DCHIP%3AIN%3A%20SecureSession%5B0xffff7800b4f0%5D%3A%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20-%20Type%3A2%20LSID%3A3224%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.209091%5D%5B3710%3A3710%5DCHIP%3AFP%3A%E7%94%9F%E5%9C%B0%E3%81%AE0x1%E3%82%92%E5%BF%98%E3%82%8C%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.209197%5D%5B3710%3A3710%5DCHIP%3ATS%3A%20%E4%BF%9D%E7%95%99%E4%B8%AD%20%E6%9C%80%E5%BE%8C%E3%81%AE%E6%97%A2%E7%9F%A5%E3%81%AE%E8%89%AF%E5%A5%BD%E3%81%AA%E6%99%82%E9%96%93%3A%202023-05-08T17%3A09%3A28%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.209704%5D%5B3710%3A3710%5DCHIP%3ATS%3A%20%E5%89%8D%E5%9B%9E%20%E5%89%8D%E5%9B%9E%20%E8%89%AF%E5%A5%BD%E3%81%AA%E6%99%82%E9%96%93%3A%202023-05-08T17%3A09%3A28%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.209785%5D%5B3710%3A3710%5DCHIP%3ATS%3A%E5%89%8D%E5%9B%9E%E3%81%AE%E6%97%A2%E7%9F%A5%E3%81%AE%E8%89%AF%E5%A5%BD%E3%81%AA%E6%99%82%E9%96%93%E3%82%92%E4%BB%A5%E5%89%8D%E3%81%AE%E5%80%A4%E3%81%AB%E6%88%BB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.209950%5D%5B3710%3A3710%5DCHIP%3ACTL%3A%E3%82%B3%E3%83%9F%E3%83%83%E3%82%B7%E3%83%A7%E3%83%8A%E3%83%BC%E3%81%AE%E3%82%B7%E3%83%A3%E3%83%83%E3%83%88%E3%83%80%E3%82%A6%E3%83%B3%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.210023%5D%5B3710%3A3710%5DCHIP%3ACTL%3ADNS-SD%E7%B5%8C%E7%94%B1%E3%81%AE%E3%82%B3%E3%83%9F%E3%83%83%E3%82%B7%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%E6%A4%9C%E5%87%BA%E3%81%AE%E5%81%9C%E6%AD%A2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.210487%5D%5B3710%3A3710%5DCHIP%3ACTL%3A%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%AE%E3%82%B7%E3%83%A3%E3%83%83%E3%83%88%E3%83%80%E3%82%A6%E3%83%B3%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.210566%5D%5B3710%3A3710%5DCHIP%3ACTL%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E7%8A%B6%E6%85%8B%E3%82%92%E3%82%B7%E3%83%A3%E3%83%83%E3%83%88%E3%83%80%E3%82%A6%E3%83%B3%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81CHIP%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%8C%E7%A0%B4%E6%A3%84%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.212047%5D%5B3710%3A3710%5DCHIP%3ADMG%3A%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEReadHandler%E3%81%AF%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%81%A7%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%AAGlobalDirtySet%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.212442%5D%5B3710%3A3710%5DCHIP%3ABLE%3ABleConnectionDelegate%3A%3ACancelConnection%E3%81%AF%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.212578%5D%5B3710%3A3710%5DCHIP%3AFP%3AFabricTable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tmp%20%2F%20chip_counters.ini-CEwe0s)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.216682%5D%5B3710%3A3710%5DCHIP%3ADL%3Atmp%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%90%8D%E5%89%8D%E3%82%92%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%88%2Ftmp%2Fchip_counters.ini%E3%81%AB%E5%A4%89%E6%9B%B4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.217104%5D%5B3710%3A3710%5DCHIP%3ADL%3A%20NVS%20set%3A%20chip-counters%2Ftotal-operational-hours%20%3D%201%20(0x1)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.217189%5D%5B3710%3A3710%5DCHIP%3ADL%3AInet%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%AE%E3%82%B7%E3%83%A3%E3%83%83%E3%83%88%E3%83%80%E3%82%A6%E3%83%B3%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.217262%5D%5B3710%3A3710%5D%20CHIP%3ADL%3A%20BLE%20shutdown%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.217336%5D%5B3710%3A3710%5DCHIP%3ADL%3A%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%82%B7%E3%83%A3%E3%83%83%E3%83%88%E3%83%80%E3%82%A6%E3%83%B3%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%5B1712041578.218125%5D%5B3710%3A3710%5DCHIP%3ATOO%3A%E5%AE%9F%E8%A1%8C%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E5%A4%B1%E6%95%97%3AIM%E3%82%A8%E3%83%A9%E3%83%BC%200x00000581%3A%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%3A0x81(UNSUPPORTED_COMMAND)%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1841956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ANXP%20i.MX8MM%E3%81%AEOTA-requestor-app%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%84%9F%E8%AC%9D%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1842509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ANXP%20i.MX8MM%E3%81%AEOTA-requestor-app%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1842509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EMX8MM%E3%81%AECHIP%E3%82%B5%E3%83%BC%E3%83%A2%E3%82%B9%E3%82%BF%E3%83%83%E3%83%88%E3%81%AE%E4%BE%8B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AE%E4%BE%8B%E3%81%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%BE%E3%81%A7%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E3%81%9D%E3%82%8C%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E5%94%AF%E4%B8%80%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
