At present, I have encountered a problem that the ov5640 camera displays a green color. By comparing with our other boards, I have made data-lanes modifications, which are as follows
// data-lanes = <2>;
data-lanes = <1 2>;
At this time, the camera color display is normal, but there are other problems, the camera preview probability can not be successfully previewed as shown in the following figure
I can't find any other ideas at present. Could you please help me check the configuration of my device tree? Thank you very much
Just from the top of my head, you need to adjust the clock for the camera and the device tree.
I also think it should be a question of adjusting the clock. Can you give me some suggestions on which parameters to adjust
