No Support for H.264 Encoder and MJPEG(Encoder & Decoder) in IMX multimedia Codec Library
adityanagal
Hi  ,
I am working on the IMX6 solo based platform and using IMX Multimedia Codec library (imx-codec-4.0.9) , but  it seems this library does not support H.264 encoding and MJPEG encoding & decoding. API document for H.264 encoding and MJPEG encoding & decoding is missing in the docs folder . Does this library supports these codecs , otherwise
how to implement encoder for H.264 and encoder and decoder for MJPEG.
Aditya Nagal
Labels (2)
Hi Aditya
please check attached Release Notes sect.6.5 Multimedia feature matrix, included in each bsp documentation
package from below link
http://www.nxp.com/products/microcontrollers-and-processors/arm-processors/i.mx-applications-process...
Note, not all i.MX processors have vpu so one needs to check chip full part number.
rogerio_silva
Hi Aditya,
Have you tried the VPU unit test? In images generated by NXP BSP, the VPU unit test is located at /unit_tests/mxc_vpu_test.out. It can encode and decode the formats you need. If you have problems, please let me know.
Rogerio
