New at JTAG
New at JTAG
1,378 次查看
lsionzon
Good Day,
I am new at using JTAG.  Currently I have an NGX jtag.  Do you have any recommendations on what software to use for investigating/accessing IMX6X CPU pins?  I currently have a board right now and I wanted to know/check how the CPU pin works.
Kind Regards,
1,314 次查看
Rita_Wang
Which board are you using? About debug tool you can refer to iMX6 Quad JTAG Debug . The jatg is for debug chip. Here recommend you to run linux or android BSP on your board, in the BSP you can see the pin configue.
