Network info change Android on i.MX6Q
DaengCheong
I'm developing an i.MX6Q with Android 7.1. I'm trying to change the network information by reading a saved text file, but I'm trying to change it to an adb shell instead of an ethernet application. If I can change it, I'm fine with the adb command, shell script, java, whatever.
Thanks.
Manuel_Salas
Hello @DaengCheong
Could you please share more details? What do you refer with "trying to change network information by reading a saved text file"?
Is there a way to replicate it?
Best regards.
Salas.
DaengCheong
For example, in a networkInfo.txt file
Ipv4=192.168.100.100
Gateway=192.168.100.254
SubnetMask=255.255.255.0
If there is any content, I would like to read this information and apply it to eth0.
