I'm developing an i.MX6Q with Android 7.1. I'm trying to change the network information by reading a saved text file, but I'm trying to change it to an adb shell instead of an ethernet application. If I can change it, I'm fine with the adb command, shell script, java, whatever.
Thanks.
