Need help installing PHP
4,623件の閲覧回数
intosite
Trying to run a webserver on the imx8mpevk.
Managed to install Nginx and run. But having issues with PHP.
in local.conf, added IMAGE_INSTALL:append = " php"
bitbake imx-image-full with no errors.
Loaded the image onto emmc, but trying to run php -v gives command not found.
In /opt/yocto/imx-6.6.52-2.2.0-build/build_fsl-imx-xwayland/tmp/work/armv8a-poky-linux/php/8.2.20/temp install logs show no errors.
Not sure how to proceed
4,530件の閲覧回数
yipingwang
Please delete php-staticdev from the list.
Please add the following line in file conf/local.conf.
IMAGE_INSTALL:append = " php-dbg php-cli php-cgi php-fpm php-fpm-apache2 php-dev php-doc php"
Then rebuild rootfs filesystem.
$ bitbake imx-image-full
If your problem persists, please provide your build error log.
8 返答(返信)
4,522件の閲覧回数
intosite
This works now and compiles. Flash the image and load it. php -v works. But apache2 still unable to serve .php files
4,504件の閲覧回数
yipingwang
Please check whether this file exist in your system.
/usr/lib/php7/build/run-tests.php
I didn't find other *.php file provided by php package.
4,490件の閲覧回数
intosite
I uploaded my own php file to '/usr/share/apache2/default-site/htdocs'.
// /usr/share/apache2/default-site/htdocs/info.php
<?php
phpinfo();
When I try to access it, browser returns 'File not found.' index.html and plain text .txt files work, so I can confirm apache is server files from the folder.
root@imx8mpevk:/var/files# ls /usr/lib/php7/build/run-tests.php
ls: cannot access '/usr/lib/php7/build/run-tests.php': No such file or directory
Found the file in '/usr/lib/php8/build' and ran it. Below is the output.
root@imx8mpevk:/usr/lib/php8/build# php run-tests.php
PHP         : /usr/bin/php
PHP_SAPI    : cli
PHP_VERSION : 8.2.20
ZEND_VERSION: 4.2.20
PHP_OS      : Linux - Linux imx8mpevk 6.6.52-lts-next-ge0f9e2afd4cf #1 SMP PREEMPT Tue Nov 19 23:01:49 UTC 2024 aarch64
INI actual  : /etc/php/apache2-php8/php.ini
More .INIs  :
PHP         : /usr/bin/php-cgi
PHP_SAPI    : cgi-fcgi
More .INIs  :
CWD         : /usr/lib/php8/build
Extra dirs  :
VALGRIND    : Not used
TIME START 2025-03-13 05:46:32
No tests were run.
4,485件の閲覧回数
yipingwang
Would you please create a new thread to address the apache2 server running problem?
4,525件の閲覧回数
intosite
Yes this works now. Flashed the image and in console php -v works. But the apache2 server cannot serve any .php files. It returns 'File not found. '
In my conf/local.conf i have set this
PACKAGECONFIG:append:pn-php = " apache2 mysql sqlite3"
4,552件の閲覧回数
yipingwang
IMAGE_INSTALL:append = " php-dbg php-cli php-cgi php-fpm php-fpm-apache2 php-dev php-staticdev php-doc php"
4,548件の閲覧回数
intosite
Does not work.
Get error and it stops there.
Reading package lists...
Building dependency tree...
Reading state information...
E: Unable to locate package php-staticdev
If i try to bitbake them individually, i get all the same errors.
bitbake php-dbg
ERROR: Nothing PROVIDES 'php-dbg'. Close matches:
  php RPROVIDES php-dbg
bitbake php-cli
ERROR: Nothing PROVIDES 'php-cli'. Close matches:
  php RPROVIDES php-cli
bitbake php-cgi
ERROR: Nothing PROVIDES 'php-cgi'. Close matches:
  php RPROVIDES php-cgi
bitbake php-fpm
ERROR: Nothing PROVIDES 'php-fpm'. Close matches:
  php RPROVIDES php-fpm
bitbake php-fpm-apache2
ERROR: Nothing PROVIDES 'php-fpm-apache2'. Close matches:
  php RPROVIDES php-fpm-apache2
bitbake php-dev
ERROR: Nothing PROVIDES 'php-dev'. Close matches:
  php RPROVIDES php-dev
bitbake php-doc
ERROR: Nothing PROVIDES 'php-doc'. Close matches:
  php RPROVIDES php-doc
Only bitbake php works and completes.
4,531件の閲覧回数
yipingwang
%3CLINGO-SUB%20id%3D%22lingo-sub-2055384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPHP%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E5%BF%85%E8%A6%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2055384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eimx8mpevk%E3%81%A7Web%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ENginx%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81PHP%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Elocal.conf%20%E3%81%A7%E3%80%81%E8%BF%BD%E5%8A%A0%20IMAGE_INSTALL%3Aappend%20%3D%20%22%20php%22%3C%2FP%3E%3CP%3Ebitbake%20imx-image-full%20%E3%82%92%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AA%E3%81%97%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92emmc%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81php%20-v%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%2Fopt%2Fyocto%2Fimx-6.6.52-2.2.0-build%2Fbuild_fsl-imx-xwayland%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fphp%2F8.2.20%2Ftemp%20%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%83%AD%E3%82%B0%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%80%B2%E3%82%81%E6%96%B9%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2055384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%20%7C%20i.MX%208QuadMax%E2%80%AF(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2060957%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PHP%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E5%BF%85%E8%A6%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2060957%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3Eapache2%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AE%E5%AE%9F%E8%A1%8C%E5%95%8F%E9%A1%8C%E3%81%AB%E5%AF%BE%E5%87%A6%3C%2FSPAN%3E%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2060953%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PHP%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E5%BF%85%E8%A6%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2060953%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AF%E8%87%AA%E5%88%86%E3%81%AEPHP%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%20'%2Fusr%2Fshare%2Fapache2%2Fdefault-site%2Fhtdocs'%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%2F%2F%20%2Fusr%2Fshare%2Fapache2%2Fdefault-site%2Fhtdocs%2Finfo.php%0A%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%96%E3%83%A9%E3%82%A6%E3%82%B6%E3%81%8C%E3%80%8C%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%8D%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82index.html%E3%81%A8%E3%83%97%E3%83%AC%E3%83%BC%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%AE.txt%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%8B%E3%82%89apache%E3%81%8C%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx8mpevk%3A%2Fvar%2Ffiles%23%20ls%20%2Fusr%2Flib%2Fphp7%2Fbuild%2Frun-tests.php%0Als%3A%20cannot%20access%20'%2Fusr%2Flib%2Fphp7%2Fbuild%2Frun-tests.php'%3A%20No%20such%20file%20or%20directory%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E'%2Fusr%2Flib%2Fphp8%2Fbuild'%E3%81%A7%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AF%E5%87%BA%E5%8A%9B%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx8mpevk%3A%2Fusr%2Flib%2Fphp8%2Fbuild%23%20php%20run-tests.php%0A%0A%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%0APHP%20%20%20%20%20%20%20%20%20%3A%20%2Fusr%2Fbin%2Fphp%0APHP_SAPI%20%20%20%20%3A%20cli%0APHP_VERSION%20%3A%208.2.20%0AZEND_VERSION%3A%204.2.20%0APHP_OS%20%20%20%20%20%20%3A%20Linux%20-%20Linux%20imx8mpevk%206.6.52-lts-next-ge0f9e2afd4cf%20%231%20SMP%20PREEMPT%20Tue%20Nov%2019%2023%3A01%3A49%20UTC%202024%20aarch64%0AINI%20actual%20%20%3A%20%2Fetc%2Fphp%2Fapache2-php8%2Fphp.ini%0AMore%20.INIs%20%20%3A%0A---------------------------------------------------------------------%0APHP%20%20%20%20%20%20%20%20%20%3A%20%2Fusr%2Fbin%2Fphp-cgi%0APHP_SAPI%20%20%20%20%3A%20cgi-fcgi%0APHP_VERSION%20%3A%208.2.20%0AZEND_VERSION%3A%204.2.20%0APHP_OS%20%20%20%20%20%20%3A%20Linux%20-%20Linux%20imx8mpevk%206.6.52-lts-next-ge0f9e2afd4cf%20%231%20SMP%20PREEMPT%20Tue%20Nov%2019%2023%3A01%3A49%20UTC%202024%20aarch64%0AINI%20actual%20%20%3A%20%2Fetc%2Fphp%2Fapache2-php8%2Fphp.ini%0AMore%20.INIs%20%20%3A%0A---------------------------------------------------------------------%0ACWD%20%20%20%20%20%20%20%20%20%3A%20%2Fusr%2Flib%2Fphp8%2Fbuild%0AExtra%20dirs%20%20%3A%0AVALGRIND%20%20%20%20%3A%20Not%20used%0A%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%0ATIME%20START%202025-03-13%2005%3A46%3A32%0A%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%0ANo%20tests%20were%20run.%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2060884%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PHP%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E5%BF%85%E8%A6%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2060884%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%2Fusr%2Flib%2Fphp7%2Fbuild%2Frun-tests.php%3C%2FP%3E%0A%3CP%3Ephp%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%82%8B%E4%BB%96%E3%81%AE*.php%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2060386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PHP%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E5%BF%85%E8%A6%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2060386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E7%8F%BE%E5%9C%A8%E6%A9%9F%E8%83%BD%E3%81%97%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E7%94%BB%E5%83%8F%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%A6%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82php%20-v%20%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81apache2%20%E3%81%AF%E3%81%BE%E3%81%A0%20.php%20%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2060320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PHP%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E5%BF%85%E8%A6%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2060320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E4%BB%8A%E3%81%AF%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E7%94%BB%E5%83%8F%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%A7php%20-v%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81apache2%20%E3%82%B5%E3%83%BC%E3%83%90%E3%81%AF%E4%BD%95%E3%82%82%E6%8F%90%E4%BE%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93.php%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%E3%80%8C%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82'%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AEconf%20%2F%20local.conf%E3%81%A7%E3%81%93%E3%82%8C%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EPACKAGECONFIG%3Aappend%3Apn-php%20%3D%20%22%20apache2%20mysql%20sqlite3%22%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2059971%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PHP%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E5%BF%85%E8%A6%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2059971%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81%E3%81%9D%E3%81%93%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EReading%20package%20lists...%0ABuilding%20dependency%20tree...%0AReading%20state%20information...%0AE%3A%20Unable%20to%20locate%20package%20php-staticdev%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92%E5%80%8B%E5%88%A5%E3%81%AB%E3%83%93%E3%83%83%E3%83%88%E3%83%99%E3%82%A4%E3%82%AF%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E5%90%8C%E3%81%98%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ebitbake%20php-dbg%0AERROR%3A%20Nothing%20PROVIDES%20'php-dbg'.%20Close%20matches%3A%0A%20%20php%20RPROVIDES%20php-dbg%0A%0Abitbake%20php-cli%0AERROR%3A%20Nothing%20PROVIDES%20'php-cli'.%20Close%20matches%3A%0A%20%20php%20RPROVIDES%20php-cli%0A%0Abitbake%20php-cgi%0AERROR%3A%20Nothing%20PROVIDES%20'php-cgi'.%20Close%20matches%3A%0A%20%20php%20RPROVIDES%20php-cgi%0A%0Abitbake%20php-fpm%0AERROR%3A%20Nothing%20PROVIDES%20'php-fpm'.%20Close%20matches%3A%0A%20%20php%20RPROVIDES%20php-fpm%0A%0Abitbake%20php-fpm-apache2%0AERROR%3A%20Nothing%20PROVIDES%20'php-fpm-apache2'.%20Close%20matches%3A%0A%20%20php%20RPROVIDES%20php-fpm-apache2%0A%0Abitbake%20php-dev%0AERROR%3A%20Nothing%20PROVIDES%20'php-dev'.%20Close%20matches%3A%0A%20%20php%20RPROVIDES%20php-dev%0A%0Abitbake%20php-doc%0AERROR%3A%20Nothing%20PROVIDES%20'php-doc'.%20Close%20matches%3A%0A%20%20php%20RPROVIDES%20php-doc%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3Ebitbake%20php%E3%81%AE%E3%81%BF%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%80%81%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
