Need help installing PHP
2,849 次查看
intosite
Trying to run a webserver on the imx8mpevk.
Managed to install Nginx and run. But having issues with PHP.
in local.conf, added IMAGE_INSTALL:append = " php"
bitbake imx-image-full with no errors.
Loaded the image onto emmc, but trying to run php -v gives command not found.
In /opt/yocto/imx-6.6.52-2.2.0-build/build_fsl-imx-xwayland/tmp/work/armv8a-poky-linux/php/8.2.20/temp install logs show no errors.
Not sure how to proceed
2,756 次查看
yipingwang
Please delete php-staticdev from the list.
Please add the following line in file conf/local.conf.
IMAGE_INSTALL:append = " php-dbg php-cli php-cgi php-fpm php-fpm-apache2 php-dev php-doc php"
Then rebuild rootfs filesystem.
$ bitbake imx-image-full
If your problem persists, please provide your build error log.
8 回复数
2,748 次查看
intosite
This works now and compiles. Flash the image and load it. php -v works. But apache2 still unable to serve .php files
2,730 次查看
yipingwang
Please check whether this file exist in your system.
/usr/lib/php7/build/run-tests.php
I didn't find other *.php file provided by php package.
2,716 次查看
intosite
I uploaded my own php file to '/usr/share/apache2/default-site/htdocs'.
// /usr/share/apache2/default-site/htdocs/info.php
<?php
phpinfo();
When I try to access it, browser returns 'File not found.' index.html and plain text .txt files work, so I can confirm apache is server files from the folder.
root@imx8mpevk:/var/files# ls /usr/lib/php7/build/run-tests.php
ls: cannot access '/usr/lib/php7/build/run-tests.php': No such file or directory
Found the file in '/usr/lib/php8/build' and ran it. Below is the output.
root@imx8mpevk:/usr/lib/php8/build# php run-tests.php
PHP         : /usr/bin/php
PHP_SAPI    : cli
PHP_VERSION : 8.2.20
ZEND_VERSION: 4.2.20
PHP_OS      : Linux - Linux imx8mpevk 6.6.52-lts-next-ge0f9e2afd4cf #1 SMP PREEMPT Tue Nov 19 23:01:49 UTC 2024 aarch64
INI actual  : /etc/php/apache2-php8/php.ini
More .INIs  :
PHP         : /usr/bin/php-cgi
PHP_SAPI    : cgi-fcgi
More .INIs  :
CWD         : /usr/lib/php8/build
Extra dirs  :
VALGRIND    : Not used
TIME START 2025-03-13 05:46:32
No tests were run.
2,711 次查看
yipingwang
Would you please create a new thread to address the apache2 server running problem?
2,751 次查看
intosite
Yes this works now. Flashed the image and in console php -v works. But the apache2 server cannot serve any .php files. It returns 'File not found. '
In my conf/local.conf i have set this
PACKAGECONFIG:append:pn-php = " apache2 mysql sqlite3"
2,778 次查看
yipingwang
IMAGE_INSTALL:append = " php-dbg php-cli php-cgi php-fpm php-fpm-apache2 php-dev php-staticdev php-doc php"
2,774 次查看
intosite
Does not work.
Get error and it stops there.
Reading package lists...
Building dependency tree...
Reading state information...
E: Unable to locate package php-staticdev
If i try to bitbake them individually, i get all the same errors.
bitbake php-dbg
ERROR: Nothing PROVIDES 'php-dbg'. Close matches:
  php RPROVIDES php-dbg
bitbake php-cli
ERROR: Nothing PROVIDES 'php-cli'. Close matches:
  php RPROVIDES php-cli
bitbake php-cgi
ERROR: Nothing PROVIDES 'php-cgi'. Close matches:
  php RPROVIDES php-cgi
bitbake php-fpm
ERROR: Nothing PROVIDES 'php-fpm'. Close matches:
  php RPROVIDES php-fpm
bitbake php-fpm-apache2
ERROR: Nothing PROVIDES 'php-fpm-apache2'. Close matches:
  php RPROVIDES php-fpm-apache2
bitbake php-dev
ERROR: Nothing PROVIDES 'php-dev'. Close matches:
  php RPROVIDES php-dev
bitbake php-doc
ERROR: Nothing PROVIDES 'php-doc'. Close matches:
  php RPROVIDES php-doc
Only bitbake php works and completes.
2,757 次查看
yipingwang
%3CLINGO-SUB%20id%3D%22lingo-sub-2055384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E9%9C%80%E8%A6%81%E5%B8%AE%E5%8A%A9%E5%AE%89%E8%A3%85%20PHP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2055384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%B0%9D%E8%AF%95%E5%9C%A8%20imx8mpevk%20%E4%B8%8A%E8%BF%90%E8%A1%8C%E7%BD%91%E7%BB%9C%E6%9C%8D%E5%8A%A1%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%90%E5%8A%9F%E5%AE%89%E8%A3%85%20Nginx%20%E5%B9%B6%E8%BF%90%E8%A1%8C%E3%80%82%E4%BD%86%20PHP%20%E5%AD%98%E5%9C%A8%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8local.conf%E4%B8%AD%EF%BC%8C%E6%B7%BB%E5%8A%A0%20IMAGE_INSTALL%3Aappend%20%3D%20%22%20php%22%3C%2FP%3E%3CP%3Ebitbake%20imx-image-full%20%E6%B2%A1%E6%9C%89%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E5%B0%86%E5%9B%BE%E5%83%8F%E5%8A%A0%E8%BD%BD%E5%88%B0%20emmc%EF%BC%8C%E4%BD%86%E5%B0%9D%E8%AF%95%E8%BF%90%E8%A1%8C%20php%20-v%20%E6%97%B6%E5%8D%B4%E6%89%BE%E4%B8%8D%E5%88%B0%E5%91%BD%E4%BB%A4%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%9C%A8%20%2Fopt%2Fyocto%2Fimx-6.6.52-2.2.0-build%2Fbuild_fsl-imx-xwayland%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fphp%2F8.2.20%2Ftemp%20%E5%AE%89%E8%A3%85%E6%97%A5%E5%BF%97%E4%B8%AD%E6%B2%A1%E6%9C%89%E6%98%BE%E7%A4%BA%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%B8%8D%E7%A1%AE%E5%AE%9A%E5%A6%82%E4%BD%95%E7%BB%A7%E7%BB%AD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2055384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20%E7%B3%BB%E5%88%97%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2060957%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%9C%80%E8%A6%81%E5%B8%AE%E5%8A%A9%E5%AE%89%E8%A3%85%20PHP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2060957%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E7%BA%BF%E7%A8%8B%E6%9D%A5%E8%A7%A3%E5%86%B3%3CSPAN%3Eapache2%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E8%BF%90%E8%A1%8C%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2060953%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%9C%80%E8%A6%81%E5%B8%AE%E5%8A%A9%E5%AE%89%E8%A3%85%20PHP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2060953%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%B0%86%E8%87%AA%E5%B7%B1%E7%9A%84%20php%20%E6%96%87%E4%BB%B6%E4%B8%8A%E4%BC%A0%E5%88%B0%E2%80%9C%2Fusr%2Fshare%2Fapache2%2Fdefault-site%2Fhtdocs%E2%80%9D%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%2F%2F%20%2Fusr%2Fshare%2Fapache2%2Fdefault-site%2Fhtdocs%2Finfo.php%0A%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E8%AE%BF%E9%97%AE%E5%AE%83%E6%97%B6%EF%BC%8C%E6%B5%8F%E8%A7%88%E5%99%A8%E8%BF%94%E5%9B%9E%E2%80%9C%E6%9C%AA%E6%89%BE%E5%88%B0%E6%96%87%E4%BB%B6%E2%80%9D%E3%80%82index.html%20%E5%92%8C%E7%BA%AF%E6%96%87%E6%9C%AC%20.txt%E6%96%87%E4%BB%B6%E5%8F%AF%E4%BB%A5%E5%B7%A5%E4%BD%9C%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E5%8F%AF%E4%BB%A5%E7%A1%AE%E8%AE%A4%20apache%20%E6%98%AF%E6%9D%A5%E8%87%AA%E8%AF%A5%E6%96%87%E4%BB%B6%E5%A4%B9%E7%9A%84%E6%9C%8D%E5%8A%A1%E5%99%A8%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx8mpevk%3A%2Fvar%2Ffiles%23%20ls%20%2Fusr%2Flib%2Fphp7%2Fbuild%2Frun-tests.php%0Als%3A%20cannot%20access%20'%2Fusr%2Flib%2Fphp7%2Fbuild%2Frun-tests.php'%3A%20No%20such%20file%20or%20directory%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E5%9C%A8%E2%80%9C%2Fusr%2Flib%2Fphp8%2Fbuild%E2%80%9D%E4%B8%AD%E6%89%BE%E5%88%B0%E8%AF%A5%E6%96%87%E4%BB%B6%E5%B9%B6%E8%BF%90%E8%A1%8C%E5%AE%83%E3%80%82%E4%BB%A5%E4%B8%8B%E6%98%AF%E8%BE%93%E5%87%BA%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40imx8mpevk%3A%2Fusr%2Flib%2Fphp8%2Fbuild%23%20php%20run-tests.php%0A%0A%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%0APHP%20%20%20%20%20%20%20%20%20%3A%20%2Fusr%2Fbin%2Fphp%0APHP_SAPI%20%20%20%20%3A%20cli%0APHP_VERSION%20%3A%208.2.20%0AZEND_VERSION%3A%204.2.20%0APHP_OS%20%20%20%20%20%20%3A%20Linux%20-%20Linux%20imx8mpevk%206.6.52-lts-next-ge0f9e2afd4cf%20%231%20SMP%20PREEMPT%20Tue%20Nov%2019%2023%3A01%3A49%20UTC%202024%20aarch64%0AINI%20actual%20%20%3A%20%2Fetc%2Fphp%2Fapache2-php8%2Fphp.ini%0AMore%20.INIs%20%20%3A%0A---------------------------------------------------------------------%0APHP%20%20%20%20%20%20%20%20%20%3A%20%2Fusr%2Fbin%2Fphp-cgi%0APHP_SAPI%20%20%20%20%3A%20cgi-fcgi%0APHP_VERSION%20%3A%208.2.20%0AZEND_VERSION%3A%204.2.20%0APHP_OS%20%20%20%20%20%20%3A%20Linux%20-%20Linux%20imx8mpevk%206.6.52-lts-next-ge0f9e2afd4cf%20%231%20SMP%20PREEMPT%20Tue%20Nov%2019%2023%3A01%3A49%20UTC%202024%20aarch64%0AINI%20actual%20%20%3A%20%2Fetc%2Fphp%2Fapache2-php8%2Fphp.ini%0AMore%20.INIs%20%20%3A%0A---------------------------------------------------------------------%0ACWD%20%20%20%20%20%20%20%20%20%3A%20%2Fusr%2Flib%2Fphp8%2Fbuild%0AExtra%20dirs%20%20%3A%0AVALGRIND%20%20%20%20%3A%20Not%20used%0A%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%0ATIME%20START%202025-03-13%2005%3A46%3A32%0A%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%0ANo%20tests%20were%20run.%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2060884%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%9C%80%E8%A6%81%E5%B8%AE%E5%8A%A9%E5%AE%89%E8%A3%85%20PHP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2060884%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AF%B7%E6%A3%80%E6%9F%A5%E6%82%A8%E7%9A%84%E7%B3%BB%E7%BB%9F%E4%B8%AD%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E8%AF%A5%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CP%3E%2Fusr%2Flib%2Fphp7%2Fbuild%2Frun-tests.php%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%20php%20%E5%8C%85%E6%8F%90%E4%BE%9B%E7%9A%84%E5%85%B6%E4%BB%96%20*.php%20%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2060386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%9C%80%E8%A6%81%E5%B8%AE%E5%8A%A9%E5%AE%89%E8%A3%85%20PHP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2060386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E5%8F%AF%E4%BB%A5%E5%B7%A5%E4%BD%9C%E5%B9%B6%E7%BC%96%E8%AF%91%E3%80%82%E5%88%B7%E6%96%B0%E5%9B%BE%E5%83%8F%E5%B9%B6%E5%8A%A0%E8%BD%BD%E3%80%82php%20-v%20%E6%9C%89%E6%95%88%E3%80%82%E4%BD%86%20apache2%20%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E6%8F%90%E4%BE%9B%20.php%E6%96%87%E4%BB%B6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2060320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%9C%80%E8%A6%81%E5%B8%AE%E5%8A%A9%E5%AE%89%E8%A3%85%20PHP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2060320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E7%8E%B0%E5%9C%A8%E5%8F%AF%E4%BB%A5%E4%BA%86%E3%80%82%E9%97%AA%E7%8E%B0%E5%9B%BE%E5%83%8F%E5%B9%B6%E5%9C%A8%E6%8E%A7%E5%88%B6%E5%8F%B0%E4%B8%AD%20php%20-v%20%E5%B7%A5%E4%BD%9C%E3%80%82%E4%BD%86%E6%98%AF%20apache2%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E6%97%A0%E6%B3%95%E6%8F%90%E4%BE%9B%E4%BB%BB%E4%BD%95%20.php%E6%96%87%E4%BB%B6%E3%80%82%E5%AE%83%E8%BF%94%E5%9B%9E%E2%80%9C%E6%9C%AA%E6%89%BE%E5%88%B0%E6%96%87%E4%BB%B6%E2%80%9D%E3%80%82'%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%88%91%E7%9A%84%20conf%2Flocal.conf%20%E4%B8%AD%E6%88%91%E8%AE%BE%E7%BD%AE%E4%BA%86%E8%BF%99%E4%B8%AA%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EPACKAGECONFIG%3Aappend%3Apn-php%20%3D%20%22%20apache2%20mysql%20sqlite3%22%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2059971%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E9%9C%80%E8%A6%81%E5%B8%AE%E5%8A%A9%E5%AE%89%E8%A3%85%20PHP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2059971%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E5%87%BA%E7%8E%B0%E9%94%99%E8%AF%AF%E5%B9%B6%E5%81%9C%E6%AD%A2%E5%9C%A8%E9%82%A3%E9%87%8C%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EReading%20package%20lists...%0ABuilding%20dependency%20tree...%0AReading%20state%20information...%0AE%3A%20Unable%20to%20locate%20package%20php-staticdev%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E5%B0%9D%E8%AF%95%E5%8D%95%E7%8B%AC%E5%AF%B9%E5%AE%83%E4%BB%AC%E8%BF%9B%E8%A1%8C%E4%BD%8D%E7%83%98%E7%84%99%EF%BC%8C%E6%88%91%E4%BC%9A%E5%BE%97%E5%88%B0%E6%89%80%E6%9C%89%E7%9B%B8%E5%90%8C%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ebitbake%20php-dbg%0AERROR%3A%20Nothing%20PROVIDES%20'php-dbg'.%20Close%20matches%3A%0A%20%20php%20RPROVIDES%20php-dbg%0A%0Abitbake%20php-cli%0AERROR%3A%20Nothing%20PROVIDES%20'php-cli'.%20Close%20matches%3A%0A%20%20php%20RPROVIDES%20php-cli%0A%0Abitbake%20php-cgi%0AERROR%3A%20Nothing%20PROVIDES%20'php-cgi'.%20Close%20matches%3A%0A%20%20php%20RPROVIDES%20php-cgi%0A%0Abitbake%20php-fpm%0AERROR%3A%20Nothing%20PROVIDES%20'php-fpm'.%20Close%20matches%3A%0A%20%20php%20RPROVIDES%20php-fpm%0A%0Abitbake%20php-fpm-apache2%0AERROR%3A%20Nothing%20PROVIDES%20'php-fpm-apache2'.%20Close%20matches%3A%0A%20%20php%20RPROVIDES%20php-fpm-apache2%0A%0Abitbake%20php-dev%0AERROR%3A%20Nothing%20PROVIDES%20'php-dev'.%20Close%20matches%3A%0A%20%20php%20RPROVIDES%20php-dev%0A%0Abitbake%20php-doc%0AERROR%3A%20Nothing%20PROVIDES%20'php-doc'.%20Close%20matches%3A%0A%20%20php%20RPROVIDES%20php-doc%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E4%BB%85%20bitbake%20php%20%E5%8F%AF%E4%BB%A5%E5%B7%A5%E4%BD%9C%E5%B9%B6%E5%AE%8C%E6%88%90%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
