Need SDK or code to reset the RTC for imx6q
2,221 次查看
Aravinthkumar
Hi Team,
I want to know how to reset the RTC from nxp SDK. We have some existing setup using to reset the RTC and other hardware testing. I'm attaching the tera tera response here. Can you please share SDK related to that and how to flash to the device.
Aravinth
标记 (4)
3 回复数
2,149 次查看
Aravinthkumar
Hi Team,
As I checked the issue, In the RTC month (07h Century_months) register value become 0. As per datasheet it never goes to 0.
Can you please provide the reason for this issue.
Aravinth
2,120 次查看
Sanket_Parekh
Hi @Aravinthkumar
I hope you are doing well
=> Kindly mention which register you are trying to read. Please mention how you are reading that register.
=> Please add more details, i.e., register name and where it is mentioned in the datasheet.
Thanks & Regards
Sanket Parekh
2,193 次查看
Sanket_Parekh
For the SDK for the IMX6 series, Please refer to the below thread.
Thanks & Regards,
Sanket Parekh
