NXP i.MX8M Plus Integration imx686
mateh
Hello nxp team,
My question is about getting images from sensor IMX686.
I use UCM-iMX8M-Plus Evaluations-Kit by Compulab and I built linux system from compulab git https://github.com/compulab-yokneam/meta-bsp-imx8mp/tree/kirkstone-2.2.0
I prepared driver for imx686 based on sources for imx219.
Unfortunately I have not found examples how can I prepared files like imx219.drv and IMX219_8Mi_02_1080p_linear.xml to correct work of the isp_media_server.
Could you guide me where can I find information to prepare .drv and .xml files for IMX686?
Can I get raw images without ISP ?
brian14
Hi @mateh,
Those files are generated by tools provided by company partners. You can contact Basler or contact with our NXP Pro Support service.
Professional Support for Processors and Microcontrollers | NXP Semiconductors
Regarding your question about the RAW Image without ISP. It depends on the interface for MIPI CSI the RAW data is directly connected with ISP.
mateh
@brian14 Thank you for your answer.
Can I get image from sensor without .drv and .xml ISP files? Is it possible to generate these files with default settings? Just for testing work of the sensor.
brian14
Hi @mateh,
No, those files are required to obtain image from sensor.
sinyuk
Hello Mateh,
You can contact me privately for consultation regarding ISP driver integration.
[email protected]
Konstantin.
