NXP IMX8MM Yocto Building Issue
DanielDuJijun
Dear NXP Support Team.
When i try to build a IMX8MM Yocto Building system on Ubuntu20.04.
But i meet some problem as following :
would you please kindly help to check and give some advice?
thanks.
epo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-hardknott -m imx-5.10.72-2.2.0.xml
Downloading Repo source from https://gerrit.googlesource.com/git-repo
fatal: Cannot get https://gerrit.googlesource.com/git-repo/clone.bundle
fatal: error [Errno 110] Connection timed out
fatal: double check your --repo-rev setting.
fatal: cloning the git-repo repository failed, will remove '.repo/repo'
crp@CRP-Ubuntu:~/crp-nxp-imx8mm-yocto-bsp$
Harvey021
It won't be correct. You have to fix the problem of network connection to github from local network as shown.
Harvey
Harvey021
Hi @DanielDuJijun
As the migration from CodeAurora to Github, so please refer to the Github: GitHub - nxp-imx/imx-manifest at imx-linux-hardknott
Harvey
DanielDuJijun
Hi Harvey.
Thanks a lot for your support and advice.
I've reverted to using Github to sync the source code in the repo, but it often fails to link and sync, and the sync rate is slow, is there a way to speed up the sync efficiency?
DanielDuJijun
Hi Harvey.
repo init -u https://github.com/nxp-imx/imx-manifest -b imx-linux-hardknott -m imx-5.10.72-2.2.3.xml
DanielDuJijun
Hi Harvey.
Please help to check the repo sync result and log.
Please help to check if it is success and if not.Please help to give some advice.
thanks.
crp@crp-ubuntu:~/crp-nxp-imx8mm-yocto-bsp$ repo sync -j8
fatal: unable to access 'https://github.com/nxp-imx/imx-manifest/': gnutls_handshake() failed: The TLS connection was non-properly terminated.
manifests: sleeping 4.0 seconds before retrying
fatal: unable to access 'https://github.com/nxp-imx/imx-manifest/': Failed to connect to github.com port 443: Connection timed out
Fetching: 100% (14/14), done in 2m18.691s
repo sync has finished successfully.
The folder of crp-nxp-imx8mm-yocto-bsp  contains about 11,559 items, about totalling 29.6 MB
Harvey021
Harvey
DanielDuJijun
crp@CRP-Ubuntu:~$ sudo apt-get update
crp@CRP-Ubuntu:~$ sudo apt-get install gawk wget git-core diffstat unzip texinfo gcc-multilib \
> build-essential chrpath socat cpio python python3 python3-pip python3-pexpect \
> xz-utils debianutils iputils-ping python3-git python3-jinja2 libegl1-mesa libsdl1.2-dev \
> pylint3 xterm rsync curl
crp@CRP-Ubuntu:~$ mkdir ~/bin
crp@CRP-Ubuntu:~$ curl https://storage.googleapis.com/git-repo-downloads/repo > ~/bin/repo
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 45787 100 45787 0 0 103k 0 --:--:-- --:--:-- --:--:-- 103k
crp@CRP-Ubuntu:~$ chmod a+x ~/bin/repo
crp@CRP-Ubuntu:~$ export PATH=~/bin:$PATH
crp@CRP-Ubuntu:~$ git config --global user.name CRP
crp@CRP-Ubuntu:~$ git config --global user.email [email protected]
crp@CRP-Ubuntu:~$ git config --list
user.name=CRP
[email protected]
crp@CRP-Ubuntu:~$ cd ~
crp@CRP-Ubuntu:~$ mkdir crp-nxp-imx8mm-yocto-bsp
crp@CRP-Ubuntu:~$ cd crp-nxp-imx8mm-yocto-bsp/
crp@CRP-Ubuntu:~/crp-nxp-imx8mm-yocto-bsp$ repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-hardknott -m imx-5.10.72-2.2.0.xml
crp@CRP-Ubuntu:~/crp-nxp-imx8mm-yocto-bsp$ cd ~
DanielDuJijun
DanielDuJijun
crp@CRP-Ubuntu1804:~$ sudo apt-get install repo
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages were automatically installed and are no longer required:
gir1.2-goa-1.0 gir1.2-snapd-1
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
python-kerberos
The following NEW packages will be installed:
python-kerberos repo
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 44.0 kB of archives.
After this operation, 129 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://cn.archive.ubuntu.com/ubuntu bionic/universe amd64 python-kerberos amd64 1.1.14-1 [22.5 kB]
Get:2 http://cn.archive.ubuntu.com/ubuntu bionic/universe amd64 repo all 1.12.37-3ubuntu1 [21.5 kB]
Fetched 44.0 kB in 1s (37.2 kB/s)
Selecting previously unselected package python-kerberos.
(Reading database ... 178915 files and directories currently installed.)
Preparing to unpack .../python-kerberos_1.1.14-1_amd64.deb ...
Unpacking python-kerberos (1.1.14-1) ...
Selecting previously unselected package repo.
Preparing to unpack .../repo_1.12.37-3ubuntu1_all.deb ...
Unpacking repo (1.12.37-3ubuntu1) ...
Setting up python-kerberos (1.1.14-1) ...
Setting up repo (1.12.37-3ubuntu1) ...
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
crp@CRP-Ubuntu1804:~$ mkdir ~/bin
crp@CRP-Ubuntu1804:~$ export PATH=~/bin:$PATH
crp@CRP-Ubuntu1804:~$ git config --global user.name CRPRobot
crp@CRP-Ubuntu1804:~$ git config --global user.email [email protected]
crp@CRP-Ubuntu1804:~$ git config --list
user.name=CRPRobot
[email protected]
crp@CRP-Ubuntu1804:~$ mkdir crp-nxp-imx8mm-yocto-bsp
crp@CRP-Ubuntu1804:~$ cd crp-nxp-imx8mm-yocto-bsp/
crp@CRP-Ubuntu1804:~/crp-nxp-imx8mm-yocto-bsp$ repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-hardknott -m imx-5.10.72-2.2.0.xml
gpg: keybox '/home/crp/.repoconfig/gnupg/pubring.kbx' created
gpg: /home/crp/.repoconfig/gnupg/trustdb.gpg: trustdb created
gpg: key 16530D5E920F5C65: public key "Repo Maintainer <[email protected]>" imported
gpg: key 67B7E448692B382C: public key "Conley Owens <[email protected]>" imported
gpg: Total number processed: 2
gpg: imported: 2
