Mfgtool flashing issue
4,051 次查看
manjunathjoshi
Hello all,
I am seeing a tar error at the very end of a flash which i am attaching. Can anybody guess what's the exact issue?
Has anybody got similar issue ? Please let me know as soon as possible.
Manju
标记 (1)
3,846 次查看
manjunathjoshi
Hello All,
This issue was solved when i renamed rootfs.tar.bz2 to rootfs.tar.
This is a work around but surely worked for me.
Manju
3,846 次查看
b36401
The error itself (invalid tar magic) means that tar does not find archive signature.
It may be caused with damaged image.
Victor
3,846 次查看
manjunathjoshi
Hello victor,
The same image is untarred in many other boards. That's the tricky part.
I want to know when such error might occur? Not one instance of it.
Manju
3,847 次查看
manjunathjoshi
Hello All,
Manju
