MX7D ddr stress test fail
1,061 次查看
llliu
I use this tool to test MX7D.The calibration can be tested success.But when I click the stress test,it will report error.
How I can solve this problem.Is it due to a mistake in my .ds file?
标签 (2)
标记 (1)
965 次查看
Yuri
  Check carefully memory parameters settings in the init (.ds) script.
Results of calibration should be inserted in the script.
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
966 次查看
Yuri
Yuri
button. Thank you!
