MIPI Camera capture on ubuntu
3,302 次查看
ahmedtolba
Hi All,
I would like to ask if its possible to use/ capture the data from the mipi-csi2 port on ubuntu using your current driver and mx6?
I would like to just capture it  without v4l2, just want to capture pure packets then use SDL or any OpenGL to render the data
标签 (2)
2,284 次查看
daiane_angolini
I would start trying unit_test capture test.
Do you have the folder /unit_test?
find for some test with capture within the name.
Then you can try to capture something using your camera. What camera are you using?
2,284 次查看
ahmedtolba
I don't have a unit test.
I'm using  Samsung 5Mpixel K5ECG MIPI CSI sensor
2,284 次查看
daiane_angolini
So, find the unit_test and use ti.
I think you would need to install it. (sorry, I´m not used with Ubuntu rootfs)
