MIPI CSI Clock questions
ソリューションへジャンプ
2,755件の閲覧回数
Eddy1
Contributor V
Hi:
Recently, I was testing the ov5640 camera on the imx8mm platform, but using an oscilloscope to test the 5640 MIPI clock, only 18M was found. How can I modify the mipi clock? The drive path I used is:drivers/media/platform/mxc/capture/ov5640_mipi_v2.c
2,523件の閲覧回数
Eddy1
Contributor V
HI:
I have resolved this issue and re ported the driver. Thank you for your support
4 返答(返信)
2,730件の閲覧回数
joanxie
what bsp version do you use? did you use nxp board or your customized board? did you use your own bsp or nxp demo images?
2,719件の閲覧回数
Eddy1
Contributor V
Hi:
The board I customized, I'm using the 4.14 kernel.my own bsp(yocto)
2,707件の閲覧回数
joanxie
what dtb do you use? pls share it and share the logfile too, after board boot up d, pls dump the clock too,
2,524件の閲覧回数
Eddy1
Contributor V
HI:
