MFG TOOL STOPS IN Erasing rootfs partition
1,138 次查看
shanmugamsundar
Hi all,
I am using mx6 solo processor with 512mb ram for our customized board, for that i tried to program the u-boot binary to spi nor flash using MFG TOOL, I configured the two config files cfg and UIcfg as below
can any one plz suggest any idea
CFG FILE:
[profiles]
chip = MX6DL Linux Update
[platform]
board = SabreARD
[LIST]
name = MX6SOLO-Sabreauto-SPI_NOR & SD card
UIcfg FILE
[UICfg]
PortMgrDlg=1
It stops in the Erasing rootfs partition, is i missing any thing or i configured anything wrong, i aatched the MFG log file and screen shot of the error
ERROR:
10445_10445.jpgmfg1.jpg10446_10446.jpgmfg2.jpg10447_10447.jpgmfg4.jpg10448_10448.jpgmfg3.jpg
MFG TOOL LOG FILE:
Original Attachment has been moved to: MfgTool.log.zip
标记 (1)
855 次查看
alejandrolozan1
If you boot from the SD card are you able to write and read to the SPI NOR?
Did you modify the ycl2.xml too?
Alejandro
