MCIMX8M-EVK board is not booting after flashing
1,783 次查看
althafahammed
I downloaded the BSP for Android 12, built it successfully without any errors, and flashed it using the UUU command. The flashing process indicated success, but the board is not booting.
I also tested with a pre-built image, but it exhibited the same behavior.
1,384 次查看
althafahammed
This issue cause due to invalid power supply. Even proper power adapter is connected it was working fine
Previously we try to power up using usb cable through PC
标记 (1)
7 回复数
1,385 次查看
althafahammed
标记 (1)
1,755 次查看
Rita_Wang
Do you download the images to sd card or emmc? Have you set the proper boot mode for it? At the same time, which version MCIMX8M-EVK board are you using? Could you share to us?
1,747 次查看
althafahammed
I tried booting with both emmc and sdk card and also boot pin are made as per the documentation
Also i don't kno the exact version of the board
1,745 次查看
Rita_Wang
Coudl you share your setting for both EMMC and SD card, I can check it for you.
1,740 次查看
althafahammed
we have used the SW801 switch configuration for boot mode as
SD card 1100
EMMC  0010
SW802 switch as  10
标记 (1)
1,688 次查看
Rita_Wang
What is the board version? Could you share the picture to us?
1,689 次查看
Rita_Wang
