LVDS not working as per datasheet timing-parameter with TechNexion EDM-G-IMX8MM and WB baseboard
ajaysinh9484
Hello to NXP Community,
i am trying to Bring-up  Digiwise's 13-070WMLBIAG1- C  7" display with TechNexion EDM-G-IMX8MM and WB baseboard  custom board.
The changes i did in .dts and panel-simple.c as per datasheet mentioned here. The source code is Android - 11 by https://github.com/technexion-android/.
DTS file : ... / dts/freescale/overlays/imx8mm-edm-g-wb-sn65dsi84-vl10112880-overlay.dts
    fragment@1 {
        target = <&mipi_dsi>;
        __overlay__ {
            status = "okay";
            #address-cells = <1>;
            #size-cells = <0>;
            panel@0 {
                reg = <0>;
                compatible = "tn,dsi2lvds-panel";
                backlight = <&lvds_backlight>;
                power-supply = <&reg_lvds_pwr>;
                dsi,flags = <0x0007>;
                dsi,format = <2>;
                dsi,lanes = <4>;
                panel-width-mm  = <152>;
                panel-height-mm = <91>;
                bus-format = <0x1009>;  /* MEDIA_BUS_FMT_RGB666_1X18 */
                bus-flags = <1>;
                refresh-rate = <60>;
                rotate = <0>;
                /* horz-flip; */
                /* vert-flip; */
                panel-timing {
                    clock-frequency = <33300000>;
                    hactive = <800>;
                    vactive = <480>;
                    hfront-porch = <204>;
                    hsync-len = <6>;
                    hback-porch = <46>;
                    vfront-porch = <22>;
                    vsync-len = <3>;
                    vback-porch = <23>;
                    /* flags = DISPLAY_FLAGS_HSYNC_HIGH | DISPLAY_FLAGS_VSYNC_HIGH */
                    vsync-active = <1>;
                    hsync-active = <1>;
And in .... / drivers/gpu/drm/panel/panel-simple.c
static const struct display_timing dsi2lvds_panel_timing = {
    .pixelclock = { 26400000, 33300000, 46800000},
    .hactive = { 800, 800, 800},
    .hfront_porch = { 16, 204, 354 },
    .hback_porch = { 46, 46, 46 },
    .hsync_len = { 1, 6, 40 },
    .vactive = { 480, 480, 480 },
    .vfront_porch = { 7, 22, 147 },
    .vback_porch = { 23, 23, 23 },
    .vsync_len = { 1, 3, 20 },
    .flags = DISPLAY_FLAGS_HSYNC_HIGH | DISPLAY_FLAGS_VSYNC_HIGH,
 * @modes: Pointer to array of fixed modes appropriate for this panel.  If
 *         only one mode then this can just be the address of this the mode.
 *         NOTE: cannot be used with "timings" and also if this is specified
 *         then you cannot override the mode in the device tree.
 * @num_modes: Number of elements in modes array.
 * @timings: Pointer to array of display timings.  NOTE: cannot be used with
 *           "modes" and also these will be used to validate a device tree
 *           override if one is present.
 * @num_timings: Number of elements in timings array.
 * @bpc: Bits per color.
 * @size: Structure containing the physical size of this panel.
 * @delay: Structure containing various delay values for this panel.
 * @bus_format: See MEDIA_BUS_FMT_... defines.
 * @bus_flags: See DRM_BUS_FLAG_... defines.
 * @refresh_rate: Refresh rate, e.g. 60MHz
 * @rotate: Rotation, e.g. 0, 90, 180, 270 degrees
 * @hflip: Horizontal flip, e.g. flip horizontally
 * @vflip: Vertical flip, e.g. flip vertically
static const struct panel_desc_dsi dsi2lvds_panel = {
    .desc = {
        .timings = &dsi2lvds_panel_timing,
        .num_timings = 1,
        .bpc = 6,
        .size = {
        .width = 152,
        .height = 91,},
        .bus_flags = DRM_BUS_FLAG_DE_LOW,
    .flags = MIPI_DSI_MODE_VIDEO | MIPI_DSI_CLOCK_NON_CONTINUOUS,
    .format = MIPI_DSI_FMT_RGB666,
    .lanes = 4,
in result adb shell  >> dmesg
edm_g_imx8mm:/ # dmesg | grep -i dsi
[ 0.625461] imx_sec_dsim_drv 32e10000.mipi_dsi: failed to get blk_ctl
[ 0.625627] imx_sec_dsim_drv 32e10000.mipi_dsi: version number is 0x1060200
[ 0.625913] imx_sec_dsim_drv 32e10000.mipi_dsi: Failed to attach bridge: 32e10000.mipi_dsi
[ 0.634275] imx_sec_dsim_drv 32e10000.mipi_dsi: failed to bind sec dsim bridge: -517
[ 0.916209] sn65dsi84 0-002d: Valid sn65dsi84 chip id
[ 0.952430] sn65dsi84 0-002d: Soft reset to default
[ 1.080725] imx_sec_dsim_drv 32e10000.mipi_dsi: failed to get blk_ctl
[ 1.080853] imx_sec_dsim_drv 32e10000.mipi_dsi: version number is 0x1060200
[ 1.081031] panel-simple-dsi 32e10000.mipi_dsi.0: >>>>Initial DSI config: flags = 1025, format = 1, lanes = 4
[ 1.081040] panel-simple-dsi 32e10000.mipi_dsi.0: >>>>Final DSI config: flags = 7, format = 2, lanes = 4
[ 1.081045] panel-simple-dsi 32e10000.mipi_dsi.0: panel-desc-dsi setting overridden from dt
[ 1.081057] panel-simple-dsi 32e10000.mipi_dsi.0: panel-desc setting overridden from dt
[ 1.081187] panel-simple-dsi 32e10000.mipi_dsi.0: Found suitable override.
[ 1.081251] imx-drm soc@0:bus@32c00000:display-subsystem: bound 32e10000.mipi_dsi (ops imx_sec_dsim_ops)
[ 1.084469] imx_sec_dsim_drv 32e10000.mipi_dsi: >>>DSI format: 4105, DSI clock = 33300
[ 1.084479] imx_sec_dsim_drv 32e10000.mipi_dsi: Chirag ==> imx_sec_dsim_encoder_helper_atomic_check:144 display_info->bus_formats[i]: 4105 bus_format:4105 num_bus_formats: 1
[ 1.106707] imx_sec_dsim_drv 32e10000.mipi_dsi: >>>DSI format: 4105, DSI clock = 33300
[ 1.106713] imx_sec_dsim_drv 32e10000.mipi_dsi: Chirag ==> imx_sec_dsim_encoder_helper_atomic_check:144 display_info->bus_formats[i]: 4105 bus_format:4105 num_bus_formats: 1
[ 14.191421] imx_sec_dsim_drv 32e10000.mipi_dsi: >>>DSI format: 4105, DSI clock = 33300
[ 14.191432] imx_sec_dsim_drv 32e10000.mipi_dsi: Chirag ==> imx_sec_dsim_encoder_helper_atomic_check:144 display_info->bus_formats[i]: 4105 bus_format:4105 num_bus_formats: 1
[ 15.078433] imx_sec_dsim_drv 32e10000.mipi_dsi: >>>DSI format: 4105, DSI clock = 33300
[ 15.078442] imx_sec_dsim_drv 32e10000.mipi_dsi: Chirag ==> imx_sec_dsim_encoder_helper_atomic_check:144 display_info->bus_formats[i]: 4105 bus_format:4105 num_bus_formats: 1
[ 15.528918] imx_sec_dsim_drv 32e10000.mipi_dsi: >>>DSI format: 4105, DSI clock = 33300
[ 15.528927] imx_sec_dsim_drv 32e10000.mipi_dsi: Chirag ==> imx_sec_dsim_encoder_helper_atomic_check:144 display_info->bus_formats[i]: 4105 bus_format:4105 num_bus_formats: 1
and here is screenshot :
* >>> However below mentioned changes in  panel-simple.c  :
	.desc = {
		.num_timings = 1,
		.bpc = 8,
		.size = {
			.width = 165,
			.height = 105,
			.width = 152,
			.height = 91,
	.format = MIPI_DSI_FMT_RGB888,
	.lanes = 4,
i got this result :
Despite this, I am facing issues with display initialization, and the panel does not seem to power up as expected. Could someone please assist me in reviewing the device tree configuration or suggest any required changes in the driver code (panel-simple.c) or other areas to help resolve this issue?
Additionally, any insights on changes that may be required in the SN65DSI84 bridge configuration or the DRM driver (panel-simple.c) would be appreciated.
Thank you for your support!
Ajaysinh.
ajaysinh9484
The display issue was resolved by configuring the pixel format to RGB888 and setting the SN65DSI84 bridge register at 0x18 to a value of 0x72. This setup aligned the display's colour depth and timing parameters correctly, providing stable and accurate display output.
thanks to @ Chavira for look at this ticket.
ajaysinh9484
Chavira
Hi @ajaysinh9484!
Thank you for contacting NXP Support!
For this case I recommend to contacting Technexion support they should have a patch or device tree using that display.
Best Regards!
Alejandro
%3CLINGO-SUB%20id%3D%22lingo-sub-1977044%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELVDS%20not%20working%20as%20per%20datasheet%20timing-parameter%20with%20TechNexion%20EDM-G-IMX8MM%20and%20WB%20baseboard%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1977044%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20to%20NXP%20Community%2C%26nbsp%3B%3C%2FP%3E%3CP%3Ei%20am%20trying%20to%20Bring-up%26nbsp%3B%20%3CSTRONG%3EDigiwise's%2013-070WMLBIAG1-%20C%26nbsp%3B%207%22%20display%20%3C%2FSTRONG%3Ewith%26nbsp%3B%3CSTRONG%3ETechNexion%20EDM-G-IMX8MM%20and%20WB%20baseboard%26nbsp%3B%3C%2FSTRONG%3E%20custom%20board.%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EThe%20changes%20i%20did%20in%20.dts%20and%20panel-simple.c%20as%20per%20datasheet%20mentioned%20here.%20The%20source%20code%20is%20Android%20-%2011%20by%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Ftechnexion-android%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Ftechnexion-android%2F.%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3EDTS%20file%20%3A%20...%20%2F%20dts%2Ffreescale%2Foverlays%2Fimx8mm-edm-g-wb-sn65dsi84-vl10112880-overlay.dts%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%3E%20%20%20%20fragment%401%20%7B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20target%20%3D%20%26lt%3B%26amp%3Bmipi_dsi%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20__overlay__%20%7B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20status%20%3D%20%22okay%22%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20panel%400%20%7B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B0%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20compatible%20%3D%20%22tn%2Cdsi2lvds-panel%22%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20backlight%20%3D%20%26lt%3B%26amp%3Blvds_backlight%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20power-supply%20%3D%20%26lt%3B%26amp%3Breg_lvds_pwr%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20dsi%2Cflags%20%3D%20%26lt%3B0x0007%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20dsi%2Cformat%20%3D%20%26lt%3B2%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20dsi%2Clanes%20%3D%20%26lt%3B4%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20panel-width-mm%20%20%3D%20%26lt%3B152%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20panel-height-mm%20%3D%20%26lt%3B91%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20bus-format%20%3D%20%26lt%3B0x1009%26gt%3B%3B%20%20%2F*%20MEDIA_BUS_FMT_RGB666_1X18%20*%2F%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20bus-flags%20%3D%20%26lt%3B1%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20refresh-rate%20%3D%20%26lt%3B60%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20rotate%20%3D%20%26lt%3B0%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20horz-flip%3B%20*%2F%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20vert-flip%3B%20*%2F%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20panel-timing%20%7B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20clock-frequency%20%3D%20%26lt%3B33300000%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20hactive%20%3D%20%26lt%3B800%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20vactive%20%3D%20%26lt%3B480%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20hfront-porch%20%3D%20%26lt%3B204%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20hsync-len%20%3D%20%26lt%3B6%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20hback-porch%20%3D%20%26lt%3B46%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20vfront-porch%20%3D%20%26lt%3B22%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20vsync-len%20%3D%20%26lt%3B3%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20vback-porch%20%3D%20%26lt%3B23%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20flags%20%3D%20DISPLAY_FLAGS_HSYNC_HIGH%20%7C%20DISPLAY_FLAGS_VSYNC_HIGH%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20vsync-active%20%3D%20%26lt%3B1%26gt%3B%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20hsync-active%20%3D%20%26lt%3B1%26gt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nbsp%3B%3CBR%20%2F%3EAnd%20in%20....%20%2F%20drivers%2Fgpu%2Fdrm%2Fpanel%2Fpanel-simple.c%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%3Estatic%20const%20struct%20display_timing%20dsi2lvds_panel_timing%20%3D%20%7B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20.pixelclock%20%3D%20%7B%2026400000%2C%2033300000%2C%2046800000%7D%2C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20.hactive%20%3D%20%7B%20800%2C%20800%2C%20800%7D%2C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20.hfront_porch%20%3D%20%7B%2016%2C%20204%2C%20354%20%7D%2C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20.hback_porch%20%3D%20%7B%2046%2C%2046%2C%2046%20%7D%2C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20.hsync_len%20%3D%20%7B%201%2C%206%2C%2040%20%7D%2C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20.vactive%20%3D%20%7B%20480%2C%20480%2C%20480%20%7D%2C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20.vfront_porch%20%3D%20%7B%207%2C%2022%2C%20147%20%7D%2C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20.vback_porch%20%3D%20%7B%2023%2C%2023%2C%2023%20%7D%2C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20.vsync_len%20%3D%20%7B%201%2C%203%2C%2020%20%7D%2C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20.flags%20%3D%20DISPLAY_FLAGS_HSYNC_HIGH%20%7C%20DISPLAY_FLAGS_VSYNC_HIGH%2C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%7D%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%2F*%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20*%20%40modes%3A%20Pointer%20to%20array%20of%20fixed%20modes%20appropriate%20for%20this%20panel.%20%20If%20%20%20%20%20%20%0A%20*%20%20%20%20%20%20%20%20%20only%20one%20mode%20then%20this%20can%20just%20be%20the%20address%20of%20this%20the%20mode.%20%20%20%20%0A%20*%20%20%20%20%20%20%20%20%20NOTE%3A%20cannot%20be%20used%20with%20%22timings%22%20and%20also%20if%20this%20is%20specified%20%20%20%20%0A%20*%20%20%20%20%20%20%20%20%20then%20you%20cannot%20override%20the%20mode%20in%20the%20device%20tree.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20*%20%40num_modes%3A%20Number%20of%20elements%20in%20modes%20array.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20*%20%40timings%3A%20Pointer%20to%20array%20of%20display%20timings.%20%20NOTE%3A%20cannot%20be%20used%20with%20%20%20%20%0A%20*%20%20%20%20%20%20%20%20%20%20%20%22modes%22%20and%20also%20these%20will%20be%20used%20to%20validate%20a%20device%20tree%20%20%20%20%20%20%0A%20*%20%20%20%20%20%20%20%20%20%20%20override%20if%20one%20is%20present.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20*%20%40num_timings%3A%20Number%20of%20elements%20in%20timings%20array.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20*%20%40bpc%3A%20Bits%20per%20color.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20*%20%40size%3A%20Structure%20containing%20the%20physical%20size%20of%20this%20panel.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20*%20%40delay%3A%20Structure%20containing%20various%20delay%20values%20for%20this%20panel.%20%20%20%20%20%20%20%20%20%20%20%20%0A%20*%20%40bus_format%3A%20See%20MEDIA_BUS_FMT_...%20defines.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20*%20%40bus_flags%3A%20See%20DRM_BUS_FLAG_...%20defines.%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20*%20%40refresh_rate%3A%20Refresh%20rate%2C%20e.g.%2060MHz%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20*%20%40rotate%3A%20Rotation%2C%20e.g.%200%2C%2090%2C%20180%2C%20270%20degrees%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20*%20%40hflip%3A%20Horizontal%20flip%2C%20e.g.%20flip%20horizontally%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20*%20%40vflip%3A%20Vertical%20flip%2C%20e.g.%20flip%20vertically%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A*%2F%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0Astatic%20const%20struct%20panel_desc_dsi%20dsi2lvds_panel%20%3D%20%7B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20.desc%20%3D%20%7B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20.timings%20%3D%20%26amp%3Bdsi2lvds_panel_timing%2C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20.num_timings%20%3D%201%2C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20.bpc%20%3D%206%2C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20.size%20%3D%20%7B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20.width%20%3D%20152%2C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20.height%20%3D%2091%2C%7D%2C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20.bus_flags%20%3D%20DRM_BUS_FLAG_DE_LOW%2C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%7D%2C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20.flags%20%3D%20MIPI_DSI_MODE_VIDEO%20%7C%20MIPI_DSI_CLOCK_NON_CONTINUOUS%2C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20.format%20%3D%20MIPI_DSI_FMT_RGB666%2C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20.lanes%20%3D%204%2C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CBR%20%2F%3Ein%20result%20%3CSTRONG%3Eadb%20shell%3C%2FSTRONG%3E%26nbsp%3B%20%26gt%3B%26gt%3B%20dmesg%26nbsp%3B%3CBR%20%2F%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3E%3CBR%20%2F%3E%3CSTRONG%3Eedm_g_imx8mm%3A%2F%20%23%20dmesg%20%7C%20grep%20-i%20dsi%20%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%200.625461%5D%20imx_sec_dsim_drv%2032e10000.mipi_dsi%3A%20failed%20to%20get%20blk_ctl%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%200.625627%5D%20imx_sec_dsim_drv%2032e10000.mipi_dsi%3A%20version%20number%20is%200x1060200%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%200.625913%5D%20imx_sec_dsim_drv%2032e10000.mipi_dsi%3A%20Failed%20to%20attach%20bridge%3A%2032e10000.mipi_dsi%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%200.634275%5D%20imx_sec_dsim_drv%2032e10000.mipi_dsi%3A%20failed%20to%20bind%20sec%20dsim%20bridge%3A%20-517%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%200.916209%5D%20sn65dsi84%200-002d%3A%20Valid%20sn65dsi84%20chip%20id%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%200.952430%5D%20sn65dsi84%200-002d%3A%20Soft%20reset%20to%20default%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%201.080725%5D%20imx_sec_dsim_drv%2032e10000.mipi_dsi%3A%20failed%20to%20get%20blk_ctl%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%201.080853%5D%20imx_sec_dsim_drv%2032e10000.mipi_dsi%3A%20version%20number%20is%200x1060200%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%201.081031%5D%20panel-simple-dsi%2032e10000.mipi_dsi.0%3A%20%26gt%3B%26gt%3B%26gt%3B%26gt%3BInitial%20DSI%20config%3A%20flags%20%3D%201025%2C%20format%20%3D%201%2C%20lanes%20%3D%204%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%201.081040%5D%20panel-simple-dsi%2032e10000.mipi_dsi.0%3A%20%26gt%3B%26gt%3B%26gt%3B%26gt%3BFinal%20DSI%20config%3A%20flags%20%3D%207%2C%20format%20%3D%202%2C%20lanes%20%3D%204%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%201.081045%5D%20panel-simple-dsi%2032e10000.mipi_dsi.0%3A%20panel-desc-dsi%20setting%20overridden%20from%20dt%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%201.081057%5D%20panel-simple-dsi%2032e10000.mipi_dsi.0%3A%20panel-desc%20setting%20overridden%20from%20dt%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%201.081187%5D%20panel-simple-dsi%2032e10000.mipi_dsi.0%3A%20Found%20suitable%20override.%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%201.081251%5D%20imx-drm%20soc%400%3Abus%4032c00000%3Adisplay-subsystem%3A%20bound%2032e10000.mipi_dsi%20(ops%20imx_sec_dsim_ops)%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%201.084469%5D%20imx_sec_dsim_drv%2032e10000.mipi_dsi%3A%20%26gt%3B%26gt%3B%26gt%3BDSI%20format%3A%204105%2C%20DSI%20clock%20%3D%2033300%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%201.084479%5D%20imx_sec_dsim_drv%2032e10000.mipi_dsi%3A%20Chirag%20%3D%3D%26gt%3B%20imx_sec_dsim_encoder_helper_atomic_check%3A144%20display_info-%26gt%3Bbus_formats%5Bi%5D%3A%204105%20bus_format%3A4105%20num_bus_formats%3A%201%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%201.106707%5D%20imx_sec_dsim_drv%2032e10000.mipi_dsi%3A%20%26gt%3B%26gt%3B%26gt%3BDSI%20format%3A%204105%2C%20DSI%20clock%20%3D%2033300%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%201.106713%5D%20imx_sec_dsim_drv%2032e10000.mipi_dsi%3A%20Chirag%20%3D%3D%26gt%3B%20imx_sec_dsim_encoder_helper_atomic_check%3A144%20display_info-%26gt%3Bbus_formats%5Bi%5D%3A%204105%20bus_format%3A4105%20num_bus_formats%3A%201%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%2014.191421%5D%20imx_sec_dsim_drv%2032e10000.mipi_dsi%3A%20%26gt%3B%26gt%3B%26gt%3BDSI%20format%3A%204105%2C%20DSI%20clock%20%3D%2033300%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%2014.191432%5D%20imx_sec_dsim_drv%2032e10000.mipi_dsi%3A%20Chirag%20%3D%3D%26gt%3B%20imx_sec_dsim_encoder_helper_atomic_check%3A144%20display_info-%26gt%3Bbus_formats%5Bi%5D%3A%204105%20bus_format%3A4105%20num_bus_formats%3A%201%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%2015.078433%5D%20imx_sec_dsim_drv%2032e10000.mipi_dsi%3A%20%26gt%3B%26gt%3B%26gt%3BDSI%20format%3A%204105%2C%20DSI%20clock%20%3D%2033300%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%2015.078442%5D%20imx_sec_dsim_drv%2032e10000.mipi_dsi%3A%20Chirag%20%3D%3D%26gt%3B%20imx_sec_dsim_encoder_helper_atomic_check%3A144%20display_info-%26gt%3Bbus_formats%5Bi%5D%3A%204105%20bus_format%3A4105%20num_bus_formats%3A%201%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%2015.528918%5D%20imx_sec_dsim_drv%2032e10000.mipi_dsi%3A%20%26gt%3B%26gt%3B%26gt%3BDSI%20format%3A%204105%2C%20DSI%20clock%20%3D%2033300%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%2015.528927%5D%20imx_sec_dsim_drv%2032e10000.mipi_dsi%3A%20Chirag%20%3D%3D%26gt%3B%20imx_sec_dsim_encoder_helper_atomic_check%3A144%20display_info-%26gt%3Bbus_formats%5Bi%5D%3A%204105%20bus_format%3A4105%20num_bus_formats%3A%201%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSTRONG%3Eand%20here%20is%20screenshot%20%3A%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22shared%20image.jpeg%22%20style%3D%22width%3A%20300px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shared%20image.jpeg%22%20style%3D%22width%3A%20300px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305513iC7AA7B10AF1A31BB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22shared%20image.jpeg%22%20alt%3D%22shared%20image.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FFONT%3E%3CBR%20%2F%3E*%20%26gt%3B%26gt%3B%26gt%3B%20However%20below%20mentioned%20changes%20in%26nbsp%3B%20panel-simple.c%26nbsp%3B%20%3A%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%3Estatic%20const%20struct%20panel_desc_dsi%20dsi2lvds_panel%20%3D%20%7B%0A%09.desc%20%3D%20%7B%0A%09%09.timings%20%3D%20%26amp%3Bdsi2lvds_panel_timing%2C%0A%09%09.num_timings%20%3D%201%2C%0A%09%09.bpc%20%3D%208%2C%0A%09%09.size%20%3D%20%7B%0A%09%09%09.width%20%3D%20165%2C%0A%09%09%09.height%20%3D%20105%2C%0A%09%09%09.width%20%3D%20152%2C%0A%09%09%09.height%20%3D%2091%2C%0A%09%09%7D%2C%0A%09%09.bus_flags%20%3D%20DRM_BUS_FLAG_DE_LOW%2C%0A%09%7D%2C%0Astatic%20const%20struct%20panel_desc_dsi%20dsi2lvds_panel%20%3D%20%7B%0A%09.format%20%3D%20MIPI_DSI_FMT_RGB888%2C%0A%09.lanes%20%3D%204%2C%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CBR%20%2F%3Ei%20got%20this%20result%20%3A%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22shared%20image%20(1).jpeg%22%20style%3D%22width%3A%20300px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22shared%20image%20(1).jpeg%22%20style%3D%22width%3A%20300px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F305517i6842B18481B76B87%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22shared%20image%20(1).jpeg%22%20alt%3D%22shared%20image%20(1).jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3EDespite%20this%2C%20I%20am%20facing%20issues%20with%20display%20initialization%2C%20and%20the%20panel%20does%20not%20seem%20to%20power%20up%20as%20expected.%20Could%20someone%20please%20assist%20me%20in%20reviewing%20the%20device%20tree%20configuration%20or%20suggest%20any%20required%20changes%20in%20the%20driver%20code%20(panel-simple.c)%20or%20other%20areas%20to%20help%20resolve%20this%20issue%3F%26nbsp%3B%3C%2FP%3E%3CP%3EAdditionally%2C%20any%20insights%20on%20changes%20that%20may%20be%20required%20in%20the%20SN65DSI84%20bridge%20configuration%20or%20the%20DRM%20driver%20(panel-simple.c)%20would%20be%20appreciated.%3C%2FP%3E%3CP%3EThank%20you%20for%20your%20support!%3C%2FP%3E%3CP%3EBest%20regards%2C%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EAjaysinh.%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1977044%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAndroid%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EGraphics%20%26amp%3B%20Display%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EHW-Open-Source%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1982685%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LVDS%20not%20working%20as%20per%20datasheet%20timing-parameter%20with%20TechNexion%20EDM-G-IMX8MM%20and%20WB%20baseboard%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1982685%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20display%20issue%20was%20resolved%20by%20configuring%20the%20pixel%20format%20to%20RGB888%26nbsp%3Band%20setting%20the%20%3CU%3E%3CSTRONG%3ESN65DSI84%3C%2FSTRONG%3E%3C%2FU%3E%20bridge%20register%20at%20%3CU%3E0x18%3C%2FU%3E%26nbsp%3Bto%20a%20value%20of%200x72.%20This%20setup%20aligned%20the%20display's%20colour%20depth%20and%20timing%20parameters%20correctly%2C%20providing%20stable%20and%20accurate%20display%20output.%3CBR%20%2F%3E%3CBR%20%2F%3Ethanks%20to%26nbsp%3B%3CU%3E%40%20Chavira%3C%2FU%3E%26nbsp%3Bfor%20look%20at%20this%20ticket.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1978446%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LVDS%20not%20working%20as%20per%20datasheet%20timing-parameter%20with%20TechNexion%20EDM-G-IMX8MM%20and%20WB%20baseboard%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1978446%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241286%22%20target%3D%22_blank%22%3E%40ajaysinh9484%3C%2FA%3E!%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20contacting%20NXP%20Support!%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3EFor%20this%20case%20I%20recommend%20to%20contacting%20Technexion%20support%20they%20should%20have%20a%20patch%20or%20device%20tree%20using%20that%20display.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20Regards!%3C%2FP%3E%0A%3CP%3EAlejandro%3C%2FP%3E%3C%2FLINGO-BODY%3E
