After i fixed some strange errors in gzipped sources (flex and others), configured kernel and so on, ./ltib (from 4.1.0 source) still fails to build base_libs:
cp -a /opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi-gcc//include/c++ /home/eugene/LTIB/ltib/tmp/base_libs//opt/freescale/rootfs/arm/usr/include
cp: cannot stat '/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi-gcc//include/c++': Not a directory
error: Bad exit status from /home/eugene/LTIB/ltib/tmp/rpm-tmp.3188 (%install)
RPM build errors:
Failed building base_libs
Build time for base_libs: 1 seconds
f_buildrpms() returned an error, exiting
Of course, "/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi-gcc//include/c++" is not a directory, it doesn't even exist!
I guess, this is just a typo in some of the scripts, but i cant figure where and what.
