LPDDR4x memory size configuration
1,065 次查看
bora
I use imx93 for my custom board and with MT53E256M16D1 LPDDR4X RAM. I changed in the device tree
reserved-memory {
		#address-cells = <2>;
		#size-cells = <2>;
		ranges;
		linux,cma {
			compatible = "shared-dma-pool";
			reusable;
			alloc-ranges = <0 0x80000000 0 0x20000000>;
			size = <0 0x02000000>;
			linux,cma-default;
		ethosu_mem: ethosu_region@80000000 {
			reusable;
			reg = <0x0 0x80000000 0x0 0x02000000>;
		vdev0vring0: vdev0vring0@84000000 {
			reg = <0 0x84000000 0 0x8000>;
			no-map;
		vdev0vring1: vdev0vring1@84008000 {
			reg = <0 0x84008000 0 0x8000>;
			no-map;
		vdev1vring0: vdev1vring0@84010000 {
			reg = <0 0x84010000 0 0x8000>;
			no-map;
		vdev1vring1: vdev1vring1@84018000 {
			reg = <0 0x84018000 0 0x8000>;
			no-map;
		rsc_table: rsc-table@2021e000 {
			reg = <0 0x2021e000 0 0x1000>;
			no-map;
		vdevbuffer: vdevbuffer@84020000 {
			reg = <0 0x84020000 0 0x100000>;
			no-map;
		ele_reserved: ele-reserved@84120000 {
			reg = <0 0x84120000 0 0x100000>;
			no-map;
and in the u-boot I use this header file imx93_evk.h and changed only define PHYS_SDRAM_SIZE
but some how I still get memory errors. do I need to change anything ?
标签 (2)
810 次查看
Chavira
Hi @bora,
We have installed the MT53E1G16D1FW-046 memory module on the FRDM board.
I've configured both U-Boot and the Linux Kernel to utilize 512MB of memory.
Chavira
7 回复数
1,026 次查看
Chavira
Hi @bora,
Thank you for contacting NXP Support!
The original custom configuration is wrong because it defines CMA’s alloc-ranges to cover the entire DDR (0x80000000–0x9FFFFFFF) while also reserving Ethos-U at 0x80000000–0x81FFFFFF and ELE at 0x84120000, creating overlaps. Additionally, Ethos-U is marked as reusable without no-map, allowing the kernel to reuse that memory, and ELE is not explicitly linked to its driver via memory-region. This breaks memory isolation, can cause corruption and DMA errors, and does not follow NXP’s best practices, which always separate CMA from dedicated pools and place ELE in a safe block outside CMA.
Try the next recommendation:
    reserved-memory {
        #size-cells   = <2>;
        ranges;
            reg = <0 0x80000000 0 0x02000000>;
            no-map;
        linux,cma {
            reusable;
            alloc-ranges = <0 0x82000000 0 0x1E000000>;
			size = <0 0x04000000>;
            linux,cma-default;
        vdev0vring0: vdev0vring0@84000000 { reg = <0 0x84000000 0 0x00008000>; no-map; }; /* 32KB */
        vdev0vring1: vdev0vring1@84008000 { reg = <0 0x84008000 0 0x00008000>; no-map; }; /* 32KB */
        vdev1vring0: vdev1vring0@84010000 { reg = <0 0x84010000 0 0x00008000>; no-map; }; /* 32KB */
        vdev1vring1: vdev1vring1@84018000 { reg = <0 0x84018000 0 0x00008000>; no-map; }; /* 32KB */
            reg = <0 0x84020000 0 0x00100000>;
            no-map;
        ele_reserved: ele-reserved@90000000 {
            reg = <0 0x90000000 0 0x00100000>;
            no-map;
If you are using optee you should update the ddr size in the next file too:
https://github.com/nxp-imx/imx-optee-os/blob/e0a3e77735941e6057a1994a576b83a93ea0bdb9/core/arch/arm/...
Chavira
1,001 次查看
bora
Thank you for the configuration now gallium softpipe works for the qt6, but how can I make it work via llvmpipe ? I still get segmentation fault, do you know maybe the packages I need to install?
980 次查看
Chavira
Hi @bora,
I haven’t used LLVMpipe personally, but based on what I found online, the limited amount of RAM on your board might be the issue. Since LLVMpipe performs 3D rendering using the CPU instead of a GPU, it typically requires more memory to handle the workload efficiently. With low RAM, the system may struggle to render graphics smoothly.
916 次查看
bora
I get this error :
root@imx93-11x11-lpddr4x-evk:/usr/share/examples/widgets/widgets/calendarwidget/bin# dmesg | grep fdt
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'ethosu_region@80000000': base 0x0000000080000000, size 32 MiB
is it relevant ?
863 次查看
Chavira
Hi @bora,
I tested the following Device Tree configuration using the iMX93-FRDM board:
	reserved-memory {
        #size-cells   = <2>;
        ranges;
        linux,cma {
            reg = <0 0x88000000 0 0x04000000>;   /* 64 MB @ 0x8800_0000 */
            reusable;
            linux,cma-default;
        /* Ethos-U: mover lejos del arranque del kernel (32 MB) */
        ethosu_mem: ethosu_region@8c000000 {
            reg = <0 0x8c000000 0 0x02000000>;
            no-map;
        rsc_table: rsc-table@2021e000 { reg = <0 0x2021e000 0 0x00001000>; no-map; }; /* OCRAM */
            reg = <0 0x84020000 0 0x00100000>;   /* 1 MB */
            no-map;
            reg = <0 0x90000000 0 0x00100000>;   /* 1 MB @ 0x9000_0000 */
            no-map;
No errors are observed:
Chavira
819 次查看
bora
811 次查看
Chavira
Hi @bora,
Chavira
%3CLINGO-SUB%20id%3D%22lingo-sub-2190760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPDDR4x%20%E5%86%85%E5%AD%98%E5%A4%A7%E5%B0%8F%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%20imx93%20%E4%BD%9C%E4%B8%BA%E6%88%91%E7%9A%84%E8%87%AA%E5%AE%9A%E4%B9%89%E6%9D%BF%E5%92%8C%20MT53E256M16D1%20LPDDR4X%20RAM%E3%80%82%E6%88%91%E5%9C%A8%E8%AE%BE%E5%A4%87%E6%A0%91%E4%B8%AD%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%9B%B4%E6%94%B9%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ereserved-memory%20%7B%0A%09%09%23address-cells%20%3D%20%26lt%3B2%26gt%3B%3B%0A%09%09%23size-cells%20%3D%20%26lt%3B2%26gt%3B%3B%0A%09%09ranges%3B%0A%0A%09%09linux%2Ccma%20%7B%0A%09%09%09compatible%20%3D%20%22shared-dma-pool%22%3B%0A%09%09%09reusable%3B%0A%09%09%09alloc-ranges%20%3D%20%26lt%3B0%200x80000000%200%200x20000000%26gt%3B%3B%0A%09%09%09size%20%3D%20%26lt%3B0%200x02000000%26gt%3B%3B%0A%09%09%09linux%2Ccma-default%3B%0A%09%09%7D%3B%0A%0A%09%09ethosu_mem%3A%20ethosu_region%4080000000%20%7B%0A%09%09%09compatible%20%3D%20%22shared-dma-pool%22%3B%0A%09%09%09reusable%3B%0A%09%09%09reg%20%3D%20%26lt%3B0x0%200x80000000%200x0%200x02000000%26gt%3B%3B%0A%09%09%7D%3B%0A%0A%09%09vdev0vring0%3A%20vdev0vring0%4084000000%20%7B%0A%09%09%09reg%20%3D%20%26lt%3B0%200x84000000%200%200x8000%26gt%3B%3B%0A%09%09%09no-map%3B%0A%09%09%7D%3B%0A%0A%09%09vdev0vring1%3A%20vdev0vring1%4084008000%20%7B%0A%09%09%09reg%20%3D%20%26lt%3B0%200x84008000%200%200x8000%26gt%3B%3B%0A%09%09%09no-map%3B%0A%09%09%7D%3B%0A%0A%09%09vdev1vring0%3A%20vdev1vring0%4084010000%20%7B%0A%09%09%09reg%20%3D%20%26lt%3B0%200x84010000%200%200x8000%26gt%3B%3B%0A%09%09%09no-map%3B%0A%09%09%7D%3B%0A%0A%09%09vdev1vring1%3A%20vdev1vring1%4084018000%20%7B%0A%09%09%09reg%20%3D%20%26lt%3B0%200x84018000%200%200x8000%26gt%3B%3B%0A%09%09%09no-map%3B%0A%09%09%7D%3B%0A%0A%09%09rsc_table%3A%20rsc-table%402021e000%20%7B%0A%09%09%09reg%20%3D%20%26lt%3B0%200x2021e000%200%200x1000%26gt%3B%3B%0A%09%09%09no-map%3B%0A%09%09%7D%3B%0A%0A%09%09vdevbuffer%3A%20vdevbuffer%4084020000%20%7B%0A%09%09%09compatible%20%3D%20%22shared-dma-pool%22%3B%0A%09%09%09reg%20%3D%20%26lt%3B0%200x84020000%200%200x100000%26gt%3B%3B%0A%09%09%09no-map%3B%0A%09%09%7D%3B%0A%0A%09%09ele_reserved%3A%20ele-reserved%4084120000%20%7B%0A%09%09%09compatible%20%3D%20%22shared-dma-pool%22%3B%0A%09%09%09reg%20%3D%20%26lt%3B0%200x84120000%200%200x100000%26gt%3B%3B%0A%09%09%09no-map%3B%0A%09%09%7D%3B%0A%09%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E7%84%B6%E5%90%8E%E5%9C%A8%20u-%E5%90%AF%E5%8A%A8%20%E4%B8%AD%E6%88%91%E4%BD%BF%E7%94%A8%E8%BF%99%E4%B8%AA%E5%A4%B4%E6%96%87%E4%BB%B6%20imx93_evk.h%E5%B9%B6%E5%8F%AA%E6%9B%B4%E6%94%B9%E4%BA%86%20PHYS_SDRAM_SIZE%20%E7%9A%84%E5%AE%9A%E4%B9%89%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%86%E4%B8%8D%E7%9F%A5%E4%B8%BA%E4%BB%80%E4%B9%88%EF%BC%8C%E6%88%91%E8%BF%98%E6%98%AF%E4%BC%9A%E5%87%BA%E7%8E%B0%E5%86%85%E5%AD%98%E9%94%99%E8%AF%AF%E3%80%82%E6%88%91%E9%9C%80%E8%A6%81%E4%BF%AE%E6%94%B9%E4%BB%80%E4%B9%88%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2190760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195126%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPDDR4x%20memory%20size%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195126%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245887%22%20target%3D%22_blank%22%3E%40bora%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E5%B7%B2%E7%BB%8F%E5%9C%A8%20%3CSTRONG%3EFRDM%20%E6%9D%BF%3C%2FSTRONG%3E%E4%B8%8A%E5%AE%89%E8%A3%85%E4%BA%86%20%3CSTRONG%3EMT53E1G16D1FW-046%3C%2FSTRONG%3E%20%E5%86%85%E5%AD%98%E6%A8%A1%E5%9D%97%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%B0%86%20%3CSTRONG%3EU-%E5%90%AF%E5%8A%A8%3C%2FSTRONG%3E%20%E5%92%8C%20%3CSTRONG%3ELinux%20%E5%86%85%E6%A0%B8%3C%2FSTRONG%3E%E9%83%BD%E9%85%8D%E7%BD%AE%E4%B8%BA%E4%BD%BF%E7%94%A8%20%3CSTRONG%3E512MB%3C%2FSTRONG%3E%20%E7%9A%84%E5%86%85%E5%AD%98%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%EF%BC%8C%3CBR%20%2F%3EChavira%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194812%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPDDR4x%20memory%20size%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194812%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%9F%A5%E7%BB%B4%E6%8B%89%EF%BC%8C%E4%BD%A0%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E7%A7%8D%E5%86%85%E5%AD%98%EF%BC%9F%E6%88%91%E6%8A%8A%E8%BF%99%E4%B8%AA%E6%94%BE%E5%88%B0%E6%88%91%E7%9A%84%E6%9D%BF%E4%B8%8A%E4%BA%86%20%3CBR%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fwww.micron.com%2Fproducts%2Fmemory%2Fdram-components%2Flpddr4%2Fpart-catalog%2Fpart-detail%2Fmt53e256m16d1ds-046-wt-b%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.micron.com%2Fproducts%2Fmemory%2Fdram-components%2Flpddr4%2Fpart-catalog%2Fpart-detail%2Fmt53e256m16d1ds-046-wt-b%3C%2FA%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194413%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPDDR4x%20memory%20size%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194413%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245887%22%20target%3D%22_blank%22%3E%40bora%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%20imx93-FRDM%20%E4%B8%BB%E6%9D%BF%E6%B5%8B%E8%AF%95%E4%BA%86%E4%BB%A5%E4%B8%8B%3CSTRONG%3E%E8%AE%BE%E5%A4%87%E6%A0%91%E9%85%8D%E7%BD%AE%3C%2FSTRONG%3E%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%09reserved-memory%20%7B%0A%20%20%20%20%20%20%20%20%23address-cells%20%3D%20%26lt%3B2%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%23size-cells%20%20%20%3D%20%26lt%3B2%26gt%3B%3B%0A%20%20%20%20%20%20%20%20ranges%3B%0A%0A%20%20%20%20%20%20%20%20linux%2Ccma%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20compatible%20%3D%20%22shared-dma-pool%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B0%200x88000000%200%200x04000000%26gt%3B%3B%20%20%20%2F*%2064%20MB%20%40%200x8800_0000%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20reusable%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20linux%2Ccma-default%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%0A%20%20%20%20%20%20%20%20%2F*%20Ethos-U%3A%20mover%20lejos%20del%20arranque%20del%20kernel%20(32%20MB)%20*%2F%0A%20%20%20%20%20%20%20%20ethosu_mem%3A%20ethosu_region%408c000000%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20compatible%20%3D%20%22shared-dma-pool%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B0%200x8c000000%200%200x02000000%26gt%3B%3B%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20no-map%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%7D%3B%0A%0A%20%20%20%20%20%20%20%20vdev0vring0%3A%20vdev0vring0%4084000000%20%7B%20reg%20%3D%20%26lt%3B0%200x84000000%200%200x00008000%26gt%3B%3B%20no-map%3B%20%7D%3B%0A%20%20%20%20%20%20%20%20vdev0vring1%3A%20vdev0vring1%4084008000%20%7B%20reg%20%3D%20%26lt%3B0%200x84008000%200%200x00008000%26gt%3B%3B%20no-map%3B%20%7D%3B%0A%20%20%20%20%20%20%20%20vdev1vring0%3A%20vdev1vring0%4084010000%20%7B%20reg%20%3D%20%26lt%3B0%200x84010000%200%200x00008000%26gt%3B%3B%20no-map%3B%20%7D%3B%0A%20%20%20%20%20%20%20%20vdev1vring1%3A%20vdev1vring1%4084018000%20%7B%20reg%20%3D%20%26lt%3B0%200x84018000%200%200x00008000%26gt%3B%3B%20no-map%3B%20%7D%3B%0A%0A%20%20%20%20%20%20%20%20rsc_table%3A%20rsc-table%402021e000%20%7B%20reg%20%3D%20%26lt%3B0%200x2021e000%200%200x00001000%26gt%3B%3B%20no-map%3B%20%7D%3B%20%2F*%20OCRAM%20*%2F%0A%0A%20%20%20%20%20%20%20%20vdevbuffer%3A%20vdevbuffer%4084020000%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20compatible%20%3D%20%22shared-dma-pool%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B0%200x84020000%200%200x00100000%26gt%3B%3B%20%20%20%2F*%201%20MB%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20no-map%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%0A%20%20%20%20%20%20%20%20ele_reserved%3A%20ele-reserved%4090000000%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20compatible%20%3D%20%22shared-dma-pool%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B0%200x90000000%200%200x00100000%26gt%3B%3B%20%20%20%2F*%201%20MB%20%40%200x9000_0000%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20no-map%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%0A%3CP%3E%E6%9C%AA%E5%8F%91%E7%8E%B0%E4%BB%BB%E4%BD%95%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Chavira_0-1761666429986.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chavira_0-1761666429986.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362913i03EFE432D44DB28F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Chavira_0-1761666429986.png%22%20alt%3D%22Chavira_0-1761666429986.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Chavira_1-1761666458518.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chavira_1-1761666458518.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362914i8D121861DD4CAB3C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Chavira_1-1761666458518.png%22%20alt%3D%22Chavira_1-1761666458518.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E6%9F%A5%E7%BB%B4%E6%8B%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194175%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPDDR4x%20memory%20size%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194175%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%88%91%E5%BE%97%E5%88%B0%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%20%3A%3CBR%20%2F%3Eroot%40imx93-11x11-lpddr4x-evk%3A%2Fusr%2Fshare%2Fexamples%2Fwidgets%2Fwidgets%2Fcalendarwidget%2Fbin%23%20dmesg%20%7C%20grep%20fdt%3CBR%20%2F%3E%5B%200.000000%5D%20OF%3A%20fdt%EF%BC%9AReserved%20memory%3A%20failed%20to%20reserve%20memory%20for%20node%20'ethosu_region%4080000000'%3A%20base%200x0000000080000000%2C%20size%2032%20MiB%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%9C%89%E5%85%B3%E7%B3%BB%E5%90%97%EF%BC%9F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2192636%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPDDR4x%20memory%20size%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2192636%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245887%22%20target%3D%22_blank%22%3E%40bora%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%B8%AA%E4%BA%BA%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8%E8%BF%87%20LLVMPipe%EF%BC%8C%E4%BD%86%E6%A0%B9%E6%8D%AE%E6%88%91%E5%9C%A8%E7%BD%91%E4%B8%8A%E5%8F%91%E7%8E%B0%E7%9A%84%E6%83%85%E5%86%B5%EF%BC%8C%E4%BD%A0%E7%9A%84%E6%9D%BF%E4%B8%8A%E6%9C%89%E9%99%90%E7%9A%84%20RAM%20%E5%8F%AF%E8%83%BD%E6%98%AF%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%E3%80%82%E7%94%B1%E4%BA%8E%20LLVMpipe%20%E4%BD%BF%E7%94%A8%20CPU%20%E8%80%8C%E9%9D%9E%20GPU%20%E6%89%A7%E8%A1%8C%203D%20%E6%B8%B2%E6%9F%93%EF%BC%8C%E5%9B%A0%E6%AD%A4%E9%80%9A%E5%B8%B8%E9%9C%80%E8%A6%81%E6%9B%B4%E5%A4%9A%E5%86%85%E5%AD%98%E6%89%8D%E8%83%BD%E6%9C%89%E6%95%88%E5%A4%84%E7%90%86%E5%B7%A5%E4%BD%9C%E8%B4%9F%E8%BD%BD%E3%80%82%E5%86%85%E5%AD%98%E4%B8%8D%E8%B6%B3%E6%97%B6%EF%BC%8C%E7%B3%BB%E7%BB%9F%E5%8F%AF%E8%83%BD%E9%9A%BE%E4%BB%A5%E6%B5%81%E7%95%85%E5%9C%B0%E6%B8%B2%E6%9F%93%E5%9B%BE%E5%BD%A2%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2192394%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPDDR4x%20memory%20size%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2192394%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%8C%E7%8E%B0%E5%9C%A8%E9%95%93%E8%BD%AF%E7%AE%A1%E5%8F%AF%E4%BB%A5%E5%9C%A8%20qt6%20%E4%B8%8A%E8%BF%90%E8%A1%8C%EF%BC%8C%E4%BD%86%E5%A6%82%E4%BD%95%E6%89%8D%E8%83%BD%E9%80%9A%E8%BF%87%20llvmpipe%20%E8%BF%90%E8%A1%8C%E5%91%A2%EF%BC%9F%E6%88%91%E8%BF%98%E6%98%AF%E4%BC%9A%E9%81%87%E5%88%B0%E5%88%86%E6%AE%B5%E9%94%99%E8%AF%AF%EF%BC%8C%E4%BD%A0%E7%9F%A5%E9%81%93%E6%88%91%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E5%AE%89%E8%A3%85%E7%9A%84%E4%BB%A3%E7%A0%81%E5%8C%85%E5%90%97%EF%BC%9F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2190963%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPDDR4x%20memory%20size%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190963%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245887%22%20target%3D%22_blank%22%3E%40bora%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E8%81%94%E7%B3%BB%E6%81%A9%E6%99%BA%E6%B5%A6%E6%94%AF%E6%8C%81%E4%B8%AD%E5%BF%83%EF%BC%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%9C%80%E5%88%9D%E7%9A%84%E8%87%AA%E5%AE%9A%E4%B9%89%E9%85%8D%E7%BD%AE%E6%98%AF%E9%94%99%E8%AF%AF%E7%9A%84%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E5%B0%86%20CMA%20%E7%9A%84%E5%88%86%E9%85%8D%E8%8C%83%E5%9B%B4%E5%AE%9A%E4%B9%89%E4%B8%BA%E8%A6%86%E7%9B%96%E6%95%B4%E4%B8%AA%20DDR%20(0x80000000-0x9FFFFFFF)%EF%BC%8C%E5%90%8C%E6%97%B6%E8%BF%98%E5%B0%86%20Ethos-U%20%E4%BF%9D%E7%95%99%E5%9C%A8%200x80000000-0x81FFFFFF%EF%BC%8C%E5%B0%86%20ELE%20%E4%BF%9D%E7%95%99%E5%9C%A8%200x84120000%EF%BC%8C%E8%BF%99%E5%B0%B1%E9%80%A0%E6%88%90%E4%BA%86%E9%87%8D%E5%8F%A0%E3%80%82%E6%AD%A4%E5%A4%96%EF%BC%8CEthos-U%20%E8%A2%AB%E6%A0%87%E8%AE%B0%E4%B8%BA%E5%8F%AF%E9%87%8D%E5%A4%8D%E4%BD%BF%E7%94%A8%EF%BC%8C%E6%97%A0%E9%9C%80%E6%98%A0%E5%B0%84%EF%BC%8C%E5%85%81%E8%AE%B8%E5%86%85%E6%A0%B8%E9%87%8D%E7%94%A8%E8%AF%A5%E5%86%85%E5%AD%98%EF%BC%8C%E8%80%8C%E4%B8%94%20ELE%20%E6%9C%AA%E9%80%9A%E8%BF%87%E5%86%85%E5%AD%98%E5%8C%BA%E5%9F%9F%E6%98%8E%E7%A1%AE%E9%93%BE%E6%8E%A5%E5%88%B0%E5%85%B6%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%82%E8%BF%99%E4%BC%9A%E7%A0%B4%E5%9D%8F%E5%86%85%E5%AD%98%E9%9A%94%E7%A6%BB%EF%BC%8C%E5%8F%AF%E8%83%BD%E5%AF%BC%E8%87%B4%E6%8D%9F%E5%9D%8F%E5%92%8CDMA%E9%94%99%E8%AF%AF%EF%BC%8C%E5%B9%B6%E4%B8%94%E4%B8%8D%E7%AC%A6%E5%90%88%E6%81%A9%E6%99%BA%E6%B5%A6%E7%9A%84%E6%9C%80%E4%BD%B3%E5%AE%9E%E8%B7%B5%EF%BC%8C%E5%8D%B3%E5%A7%8B%E7%BB%88%E5%B0%86CMA%E4%B8%8E%E4%B8%93%E7%94%A8%E7%9A%84%E6%B1%A0%E5%88%86%E5%BC%80%EF%BC%8C%E5%B9%B6%E5%B0%86ELE%E6%94%BE%E5%9C%A8CMA%E4%B9%8B%E5%A4%96%E7%9A%84%E5%AE%89%E5%85%A8%E5%8C%BA%E5%9D%97%E4%B8%AD%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%AF%95%E8%AF%95%E4%B8%8B%E4%B8%80%E4%B8%AA%E5%BB%BA%E8%AE%AE%EF%BC%9A%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%20%20%20%20reserved-memory%20%7B%0A%20%20%20%20%20%20%20%20%23address-cells%20%3D%20%26lt%3B2%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%23size-cells%20%20%20%3D%20%26lt%3B2%26gt%3B%3B%0A%20%20%20%20%20%20%20%20ranges%3B%0A%0A%20%20%20%20%20%20%20%20ethosu_mem%3A%20ethosu_region%4080000000%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20compatible%20%3D%20%22shared-dma-pool%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B0%200x80000000%200%200x02000000%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20no-map%3B%20%20%20%0A%20%20%20%20%20%20%20%20%7D%3B%0A%0A%20%20%20%20%20%20%20%20linux%2Ccma%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20compatible%20%3D%20%22shared-dma-pool%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20reusable%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20alloc-ranges%20%3D%20%26lt%3B0%200x82000000%200%200x1E000000%26gt%3B%3B%0A%09%09%09size%20%3D%20%26lt%3B0%200x04000000%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20linux%2Ccma-default%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%20%20%20%20vdev0vring0%3A%20vdev0vring0%4084000000%20%7B%20reg%20%3D%20%26lt%3B0%200x84000000%200%200x00008000%26gt%3B%3B%20no-map%3B%20%7D%3B%20%2F*%2032KB%20*%2F%0A%20%20%20%20%20%20%20%20vdev0vring1%3A%20vdev0vring1%4084008000%20%7B%20reg%20%3D%20%26lt%3B0%200x84008000%200%200x00008000%26gt%3B%3B%20no-map%3B%20%7D%3B%20%2F*%2032KB%20*%2F%0A%20%20%20%20%20%20%20%20vdev1vring0%3A%20vdev1vring0%4084010000%20%7B%20reg%20%3D%20%26lt%3B0%200x84010000%200%200x00008000%26gt%3B%3B%20no-map%3B%20%7D%3B%20%2F*%2032KB%20*%2F%0A%20%20%20%20%20%20%20%20vdev1vring1%3A%20vdev1vring1%4084018000%20%7B%20reg%20%3D%20%26lt%3B0%200x84018000%200%200x00008000%26gt%3B%3B%20no-map%3B%20%7D%3B%20%2F*%2032KB%20*%2F%0A%0A%20%20%20%20%20%20%20%20vdevbuffer%3A%20vdevbuffer%4084020000%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20compatible%20%3D%20%22shared-dma-pool%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B0%200x84020000%200%200x00100000%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20no-map%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%0A%20%20%20%20%20%20%20%20ele_reserved%3A%20ele-reserved%4090000000%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20compatible%20%3D%20%22shared-dma-pool%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B0%200x90000000%200%200x00100000%26gt%3B%3B%20%0A%20%20%20%20%20%20%20%20%20%20%20%20no-map%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%20optee%EF%BC%8C%E8%BF%98%E5%BA%94%E5%9C%A8%E4%B8%8B%E4%B8%80%E4%B8%AA%E6%96%87%E4%BB%B6%E4%B8%AD%E6%9B%B4%E6%96%B0%20ddr%20%E5%A4%A7%E5%B0%8F%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-optee-os%2Fblob%2Fe0a3e77735941e6057a1994a576b83a93ea0bdb9%2Fcore%2Farch%2Farm%2Fplat-imx%2Fconf.mk%23L457%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-optee-os%2Fblob%2Fe0a3e77735941e6057a1994a576b83a93ea0bdb9%2Fcore%2Farch%2Farm%2Fplat-imx%2Fconf.mk%23L457%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%95%AC%E4%B8%8A%EF%BC%8C%3CBR%20%2F%3EChavira%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
