LPDDR4x memory size configuration
3,778件の閲覧回数
bora
I use imx93 for my custom board and with MT53E256M16D1 LPDDR4X RAM. I changed in the device tree
reserved-memory {
		#address-cells = <2>;
		#size-cells = <2>;
		ranges;
		linux,cma {
			compatible = "shared-dma-pool";
			reusable;
			alloc-ranges = <0 0x80000000 0 0x20000000>;
			size = <0 0x02000000>;
			linux,cma-default;
		ethosu_mem: ethosu_region@80000000 {
			reusable;
			reg = <0x0 0x80000000 0x0 0x02000000>;
		vdev0vring0: vdev0vring0@84000000 {
			reg = <0 0x84000000 0 0x8000>;
			no-map;
		vdev0vring1: vdev0vring1@84008000 {
			reg = <0 0x84008000 0 0x8000>;
			no-map;
		vdev1vring0: vdev1vring0@84010000 {
			reg = <0 0x84010000 0 0x8000>;
			no-map;
		vdev1vring1: vdev1vring1@84018000 {
			reg = <0 0x84018000 0 0x8000>;
			no-map;
		rsc_table: rsc-table@2021e000 {
			reg = <0 0x2021e000 0 0x1000>;
			no-map;
		vdevbuffer: vdevbuffer@84020000 {
			reg = <0 0x84020000 0 0x100000>;
			no-map;
		ele_reserved: ele-reserved@84120000 {
			reg = <0 0x84120000 0 0x100000>;
			no-map;
and in the u-boot I use this header file imx93_evk.h and changed only define PHYS_SDRAM_SIZE
but some how I still get memory errors. do I need to change anything ?
ラベル(2)
3,524件の閲覧回数
Chavira
Hi @bora,
We have installed the MT53E1G16D1FW-046 memory module on the FRDM board.
I've configured both U-Boot and the Linux Kernel to utilize 512MB of memory.
Chavira
7 返答(返信)
3,739件の閲覧回数
Chavira
Hi @bora,
Thank you for contacting NXP Support!
The original custom configuration is wrong because it defines CMA’s alloc-ranges to cover the entire DDR (0x80000000–0x9FFFFFFF) while also reserving Ethos-U at 0x80000000–0x81FFFFFF and ELE at 0x84120000, creating overlaps. Additionally, Ethos-U is marked as reusable without no-map, allowing the kernel to reuse that memory, and ELE is not explicitly linked to its driver via memory-region. This breaks memory isolation, can cause corruption and DMA errors, and does not follow NXP’s best practices, which always separate CMA from dedicated pools and place ELE in a safe block outside CMA.
Try the next recommendation:
    reserved-memory {
        #size-cells   = <2>;
        ranges;
            reg = <0 0x80000000 0 0x02000000>;
            no-map;
        linux,cma {
            reusable;
            alloc-ranges = <0 0x82000000 0 0x1E000000>;
			size = <0 0x04000000>;
            linux,cma-default;
        vdev0vring0: vdev0vring0@84000000 { reg = <0 0x84000000 0 0x00008000>; no-map; }; /* 32KB */
        vdev0vring1: vdev0vring1@84008000 { reg = <0 0x84008000 0 0x00008000>; no-map; }; /* 32KB */
        vdev1vring0: vdev1vring0@84010000 { reg = <0 0x84010000 0 0x00008000>; no-map; }; /* 32KB */
        vdev1vring1: vdev1vring1@84018000 { reg = <0 0x84018000 0 0x00008000>; no-map; }; /* 32KB */
            reg = <0 0x84020000 0 0x00100000>;
            no-map;
        ele_reserved: ele-reserved@90000000 {
            reg = <0 0x90000000 0 0x00100000>;
            no-map;
If you are using optee you should update the ddr size in the next file too:
https://github.com/nxp-imx/imx-optee-os/blob/e0a3e77735941e6057a1994a576b83a93ea0bdb9/core/arch/arm/...
Chavira
3,714件の閲覧回数
bora
Thank you for the configuration now gallium softpipe works for the qt6, but how can I make it work via llvmpipe ? I still get segmentation fault, do you know maybe the packages I need to install?
3,693件の閲覧回数
Chavira
Hi @bora,
I haven’t used LLVMpipe personally, but based on what I found online, the limited amount of RAM on your board might be the issue. Since LLVMpipe performs 3D rendering using the CPU instead of a GPU, it typically requires more memory to handle the workload efficiently. With low RAM, the system may struggle to render graphics smoothly.
3,629件の閲覧回数
bora
I get this error :
root@imx93-11x11-lpddr4x-evk:/usr/share/examples/widgets/widgets/calendarwidget/bin# dmesg | grep fdt
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'ethosu_region@80000000': base 0x0000000080000000, size 32 MiB
is it relevant ?
3,576件の閲覧回数
Chavira
Hi @bora,
I tested the following Device Tree configuration using the iMX93-FRDM board:
	reserved-memory {
        #size-cells   = <2>;
        ranges;
        linux,cma {
            reg = <0 0x88000000 0 0x04000000>;   /* 64 MB @ 0x8800_0000 */
            reusable;
            linux,cma-default;
        /* Ethos-U: mover lejos del arranque del kernel (32 MB) */
        ethosu_mem: ethosu_region@8c000000 {
            reg = <0 0x8c000000 0 0x02000000>;
            no-map;
        rsc_table: rsc-table@2021e000 { reg = <0 0x2021e000 0 0x00001000>; no-map; }; /* OCRAM */
            reg = <0 0x84020000 0 0x00100000>;   /* 1 MB */
            no-map;
            reg = <0 0x90000000 0 0x00100000>;   /* 1 MB @ 0x9000_0000 */
            no-map;
No errors are observed:
Chavira
3,533件の閲覧回数
bora
3,525件の閲覧回数
Chavira
Hi @bora,
Chavira
%3CLINGO-SUB%20id%3D%22lingo-sub-2190760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPDDR4x%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%B5%E3%82%A4%E3%82%BA%E6%A7%8B%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%20imx93%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81MT53E256M16D1%20LPDDR4X%20RAM%20%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ereserved-memory%20%7B%0A%09%09%23address-cells%20%3D%20%26lt%3B2%26gt%3B%3B%0A%09%09%23size-cells%20%3D%20%26lt%3B2%26gt%3B%3B%0A%09%09ranges%3B%0A%0A%09%09linux%2Ccma%20%7B%0A%09%09%09compatible%20%3D%20%22shared-dma-pool%22%3B%0A%09%09%09reusable%3B%0A%09%09%09alloc-ranges%20%3D%20%26lt%3B0%200x80000000%200%200x20000000%26gt%3B%3B%0A%09%09%09size%20%3D%20%26lt%3B0%200x02000000%26gt%3B%3B%0A%09%09%09linux%2Ccma-default%3B%0A%09%09%7D%3B%0A%0A%09%09ethosu_mem%3A%20ethosu_region%4080000000%20%7B%0A%09%09%09compatible%20%3D%20%22shared-dma-pool%22%3B%0A%09%09%09reusable%3B%0A%09%09%09reg%20%3D%20%26lt%3B0x0%200x80000000%200x0%200x02000000%26gt%3B%3B%0A%09%09%7D%3B%0A%0A%09%09vdev0vring0%3A%20vdev0vring0%4084000000%20%7B%0A%09%09%09reg%20%3D%20%26lt%3B0%200x84000000%200%200x8000%26gt%3B%3B%0A%09%09%09no-map%3B%0A%09%09%7D%3B%0A%0A%09%09vdev0vring1%3A%20vdev0vring1%4084008000%20%7B%0A%09%09%09reg%20%3D%20%26lt%3B0%200x84008000%200%200x8000%26gt%3B%3B%0A%09%09%09no-map%3B%0A%09%09%7D%3B%0A%0A%09%09vdev1vring0%3A%20vdev1vring0%4084010000%20%7B%0A%09%09%09reg%20%3D%20%26lt%3B0%200x84010000%200%200x8000%26gt%3B%3B%0A%09%09%09no-map%3B%0A%09%09%7D%3B%0A%0A%09%09vdev1vring1%3A%20vdev1vring1%4084018000%20%7B%0A%09%09%09reg%20%3D%20%26lt%3B0%200x84018000%200%200x8000%26gt%3B%3B%0A%09%09%09no-map%3B%0A%09%09%7D%3B%0A%0A%09%09rsc_table%3A%20rsc-table%402021e000%20%7B%0A%09%09%09reg%20%3D%20%26lt%3B0%200x2021e000%200%200x1000%26gt%3B%3B%0A%09%09%09no-map%3B%0A%09%09%7D%3B%0A%0A%09%09vdevbuffer%3A%20vdevbuffer%4084020000%20%7B%0A%09%09%09compatible%20%3D%20%22shared-dma-pool%22%3B%0A%09%09%09reg%20%3D%20%26lt%3B0%200x84020000%200%200x100000%26gt%3B%3B%0A%09%09%09no-map%3B%0A%09%09%7D%3B%0A%0A%09%09ele_reserved%3A%20ele-reserved%4084120000%20%7B%0A%09%09%09compatible%20%3D%20%22shared-dma-pool%22%3B%0A%09%09%09reg%20%3D%20%26lt%3B0%200x84120000%200%200x100000%26gt%3B%3B%0A%09%09%09no-map%3B%0A%09%09%7D%3B%0A%09%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3Eu-boot%E3%81%A7%E3%81%AF%E3%81%93%E3%81%AE%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%ABimx93_evk.h%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99PHYS_SDRAM_SIZE%E3%81%AE%E5%AE%9A%E7%BE%A9%E3%81%AE%E3%81%BF%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E7%90%86%E7%94%B1%E3%81%A7%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E3%81%BE%E3%81%A0%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BD%95%E3%81%8B%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2190760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195126%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPDDR4x%20memory%20size%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195126%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245887%22%20target%3D%22_blank%22%3E%40bora%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EFRDM%20%E3%83%9C%E3%83%BC%E3%83%89%3C%2FSTRONG%3E%E3%81%AB%3CSTRONG%3EMT53E1G16D1FW-046%3C%2FSTRONG%3E%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EU-Boot%3C%2FSTRONG%3E%E3%81%A8%3CSTRONG%3ELinux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%3C%2FSTRONG%3E%E4%B8%A1%E6%96%B9%E3%82%92%3CSTRONG%3E512MB%3C%2FSTRONG%3E%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%83%81%E3%83%A3%E3%83%93%E3%83%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194812%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPDDR4x%20memory%20size%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194812%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81Chavira%E3%81%95%E3%82%93%E3%80%82%E3%81%A9%E3%81%AE%20RAM%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E7%A7%81%E3%81%AF%E3%81%93%E3%82%8C%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E8%BC%89%E3%81%9B%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.micron.com%2Fproducts%2Fmemory%2Fdram-components%2Flpddr4%2Fpart-catalog%2Fpart-detail%2Fmt53e256m16d1ds-046-wt-b%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.micron.com%2Fproducts%2Fmemory%2Fdram-components%2Flpddr4%2Fpart-catalog%2Fpart-detail%2Fmt53e256m16d1ds-046-wt-b%3C%2FA%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194413%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPDDR4x%20memory%20size%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194413%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245887%22%20target%3D%22_blank%22%3E%40bora%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EiMX93-FRDM%20%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E6%AC%A1%E3%81%AE%3CSTRONG%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%E6%A7%8B%E6%88%90%3C%2FSTRONG%3E%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%09reserved-memory%20%7B%0A%20%20%20%20%20%20%20%20%23address-cells%20%3D%20%26lt%3B2%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%23size-cells%20%20%20%3D%20%26lt%3B2%26gt%3B%3B%0A%20%20%20%20%20%20%20%20ranges%3B%0A%0A%20%20%20%20%20%20%20%20linux%2Ccma%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20compatible%20%3D%20%22shared-dma-pool%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B0%200x88000000%200%200x04000000%26gt%3B%3B%20%20%20%2F*%2064%20MB%20%40%200x8800_0000%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20reusable%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20linux%2Ccma-default%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%0A%20%20%20%20%20%20%20%20%2F*%20Ethos-U%3A%20mover%20lejos%20del%20arranque%20del%20kernel%20(32%20MB)%20*%2F%0A%20%20%20%20%20%20%20%20ethosu_mem%3A%20ethosu_region%408c000000%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20compatible%20%3D%20%22shared-dma-pool%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B0%200x8c000000%200%200x02000000%26gt%3B%3B%20%20%20%0A%20%20%20%20%20%20%20%20%20%20%20%20no-map%3B%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20%7D%3B%0A%0A%20%20%20%20%20%20%20%20vdev0vring0%3A%20vdev0vring0%4084000000%20%7B%20reg%20%3D%20%26lt%3B0%200x84000000%200%200x00008000%26gt%3B%3B%20no-map%3B%20%7D%3B%0A%20%20%20%20%20%20%20%20vdev0vring1%3A%20vdev0vring1%4084008000%20%7B%20reg%20%3D%20%26lt%3B0%200x84008000%200%200x00008000%26gt%3B%3B%20no-map%3B%20%7D%3B%0A%20%20%20%20%20%20%20%20vdev1vring0%3A%20vdev1vring0%4084010000%20%7B%20reg%20%3D%20%26lt%3B0%200x84010000%200%200x00008000%26gt%3B%3B%20no-map%3B%20%7D%3B%0A%20%20%20%20%20%20%20%20vdev1vring1%3A%20vdev1vring1%4084018000%20%7B%20reg%20%3D%20%26lt%3B0%200x84018000%200%200x00008000%26gt%3B%3B%20no-map%3B%20%7D%3B%0A%0A%20%20%20%20%20%20%20%20rsc_table%3A%20rsc-table%402021e000%20%7B%20reg%20%3D%20%26lt%3B0%200x2021e000%200%200x00001000%26gt%3B%3B%20no-map%3B%20%7D%3B%20%2F*%20OCRAM%20*%2F%0A%0A%20%20%20%20%20%20%20%20vdevbuffer%3A%20vdevbuffer%4084020000%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20compatible%20%3D%20%22shared-dma-pool%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B0%200x84020000%200%200x00100000%26gt%3B%3B%20%20%20%2F*%201%20MB%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20no-map%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%0A%20%20%20%20%20%20%20%20ele_reserved%3A%20ele-reserved%4090000000%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20compatible%20%3D%20%22shared-dma-pool%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B0%200x90000000%200%200x00100000%26gt%3B%3B%20%20%20%2F*%201%20MB%20%40%200x9000_0000%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20no-map%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%0A%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E8%A6%B3%E5%AF%9F%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Chavira_0-1761666429986.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chavira_0-1761666429986.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362913i03EFE432D44DB28F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Chavira_0-1761666429986.png%22%20alt%3D%22Chavira_0-1761666429986.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Chavira_1-1761666458518.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Chavira_1-1761666458518.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362914i8D121861DD4CAB3C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Chavira_1-1761666458518.png%22%20alt%3D%22Chavira_1-1761666458518.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%83%A3%E3%83%93%E3%83%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194175%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPDDR4x%20memory%20size%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194175%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%3A%3CBR%20%2F%3E%20root%40imx93-11x11-lpddr4x-evk%3A%2Fusr%2Fshare%2Fexamples%2Fwidgets%2Fwidgets%2Fcalendarwidget%2Fbin%23%20dmesg%20%7C%20grep%20fdt%3CBR%20%2F%3E%20%5B%200.000000%5D%20OF%3A%20fdt%3A%20%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%E3%83%A1%E3%83%A2%E3%83%AA%3A%20%E3%83%8E%E3%83%BC%E3%83%89%20'ethosu_region%4080000000'%20%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E4%BA%88%E7%B4%84%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3A%20%E3%83%99%E3%83%BC%E3%82%B9%200x0000000080000000%E3%80%81%E3%82%B5%E3%82%A4%E3%82%BA%2032%20MiB%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%9D%E3%82%8C%E3%81%AF%E9%96%A2%E9%80%A3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2192636%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPDDR4x%20memory%20size%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2192636%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245887%22%20target%3D%22_blank%22%3E%40bora%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%AF%E5%80%8B%E4%BA%BA%E7%9A%84%E3%81%AB%20LLVMpipe%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%82%AA%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%9F%E6%83%85%E5%A0%B1%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%E3%81%A8%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%20RAM%20%E3%81%AE%E9%87%8F%E3%81%8C%E9%99%90%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82LLVMpipe%20%E3%81%AF%20GPU%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%20CPU%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%203D%20%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E9%80%9A%E5%B8%B8%E3%80%81%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%89%E3%82%92%E5%8A%B9%E7%8E%87%E7%9A%84%E3%81%AB%E5%87%A6%E7%90%86%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%82%88%E3%82%8A%E5%A4%9A%E3%81%8F%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82RAM%20%E3%81%8C%E5%B0%91%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%92%E3%82%B9%E3%83%A0%E3%83%BC%E3%82%BA%E3%81%AB%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2192394%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPDDR4x%20memory%20size%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2192394%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%A8%AD%E5%AE%9A%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%A7%E3%82%AC%E3%83%AA%E3%82%A6%E3%83%A0%20%E3%82%BD%E3%83%95%E3%83%88%E3%83%91%E3%82%A4%E3%83%97%E3%81%8C%20QT6%20%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%20llvmpipe%20%E7%B5%8C%E7%94%B1%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0CAN%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%BE%E3%81%A0%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E9%81%95%E5%8F%8D%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%81%94%E5%AD%98%E7%9F%A5%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2190963%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPDDR4x%20memory%20size%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190963%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245887%22%20target%3D%22_blank%22%3E%40bora%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3ENXP%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%85%83%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E6%A7%8B%E6%88%90%E3%81%AF%E3%80%81CMA%20%E3%81%AE%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E7%AF%84%E5%9B%B2%E3%82%92%20DDR%20%E5%85%A8%E4%BD%93%20(0x80000000%E2%80%930x9FFFFFFF)%20%E3%82%92%E3%82%AB%E3%83%90%E3%83%BC%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%AE%9A%E7%BE%A9%E3%81%97%E3%80%81%E5%90%8C%E6%99%82%E3%81%AB%20Ethos-U%20%E3%82%92%200x80000000%E2%80%930x81FFFFFF%20%E3%81%AB%E3%80%81ELE%20%E3%82%92%200x84120000%20%E3%81%AB%E4%BA%88%E7%B4%84%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E9%87%8D%E8%A4%87%E3%81%8C%E7%94%9F%E3%81%98%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%95%E3%82%89%E3%81%AB%E3%80%81Ethos-U%20%E3%81%AF%20no-map%20%E3%81%AA%E3%81%97%E3%81%A7%E5%86%8D%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AF%E3%81%9D%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E5%86%8D%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81ELE%20%E3%81%AF%E3%83%A1%E3%83%A2%E3%83%AA%E9%A0%98%E5%9F%9F%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AB%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E3%82%A2%E3%82%A4%E3%82%BD%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%8C%E5%B4%A9%E3%82%8C%E3%80%81%E7%A0%B4%E6%90%8D%E3%82%84%20DMA%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81CMA%20%E3%82%92%E5%B0%82%E7%94%A8%E3%83%97%E3%83%BC%E3%83%AB%E3%81%8B%E3%82%89%E5%B8%B8%E3%81%AB%E5%88%86%E9%9B%A2%E3%81%97%E3%80%81ELE%20%E3%82%92%20CMA%20%E5%A4%96%E3%81%AE%E5%AE%89%E5%85%A8%E3%81%AA%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%99%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%20NXP%20%E3%81%AE%E3%83%99%E3%82%B9%E3%83%88%20%E3%83%97%E3%83%A9%E3%82%AF%E3%83%86%E3%82%A3%E3%82%B9%E3%81%AB%E3%82%82%E5%BE%93%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AC%A1%E3%81%AE%E6%8E%A8%E5%A5%A8%E4%BA%8B%E9%A0%85%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%20%20%20%20reserved-memory%20%7B%0A%20%20%20%20%20%20%20%20%23address-cells%20%3D%20%26lt%3B2%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%23size-cells%20%20%20%3D%20%26lt%3B2%26gt%3B%3B%0A%20%20%20%20%20%20%20%20ranges%3B%0A%0A%20%20%20%20%20%20%20%20ethosu_mem%3A%20ethosu_region%4080000000%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20compatible%20%3D%20%22shared-dma-pool%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B0%200x80000000%200%200x02000000%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20no-map%3B%20%20%20%0A%20%20%20%20%20%20%20%20%7D%3B%0A%0A%20%20%20%20%20%20%20%20linux%2Ccma%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20compatible%20%3D%20%22shared-dma-pool%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20reusable%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20alloc-ranges%20%3D%20%26lt%3B0%200x82000000%200%200x1E000000%26gt%3B%3B%0A%09%09%09size%20%3D%20%26lt%3B0%200x04000000%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20linux%2Ccma-default%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%20%20%20%20vdev0vring0%3A%20vdev0vring0%4084000000%20%7B%20reg%20%3D%20%26lt%3B0%200x84000000%200%200x00008000%26gt%3B%3B%20no-map%3B%20%7D%3B%20%2F*%2032KB%20*%2F%0A%20%20%20%20%20%20%20%20vdev0vring1%3A%20vdev0vring1%4084008000%20%7B%20reg%20%3D%20%26lt%3B0%200x84008000%200%200x00008000%26gt%3B%3B%20no-map%3B%20%7D%3B%20%2F*%2032KB%20*%2F%0A%20%20%20%20%20%20%20%20vdev1vring0%3A%20vdev1vring0%4084010000%20%7B%20reg%20%3D%20%26lt%3B0%200x84010000%200%200x00008000%26gt%3B%3B%20no-map%3B%20%7D%3B%20%2F*%2032KB%20*%2F%0A%20%20%20%20%20%20%20%20vdev1vring1%3A%20vdev1vring1%4084018000%20%7B%20reg%20%3D%20%26lt%3B0%200x84018000%200%200x00008000%26gt%3B%3B%20no-map%3B%20%7D%3B%20%2F*%2032KB%20*%2F%0A%0A%20%20%20%20%20%20%20%20vdevbuffer%3A%20vdevbuffer%4084020000%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20compatible%20%3D%20%22shared-dma-pool%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B0%200x84020000%200%200x00100000%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20no-map%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%0A%20%20%20%20%20%20%20%20ele_reserved%3A%20ele-reserved%4090000000%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20compatible%20%3D%20%22shared-dma-pool%22%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B0%200x90000000%200%200x00100000%26gt%3B%3B%20%0A%20%20%20%20%20%20%20%20%20%20%20%20no-map%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3Eoptee%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%82%82%20DDR%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-optee-os%2Fblob%2Fe0a3e77735941e6057a1994a576b83a93ea0bdb9%2Fcore%2Farch%2Farm%2Fplat-imx%2Fconf.mk%23L457%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-optee-os%2Fblob%2Fe0a3e77735941e6057a1994a576b83a93ea0bdb9%2Fcore%2Farch%2Farm%2Fplat-imx%2Fconf.mk%23L457%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%83%81%E3%83%A3%E3%83%93%E3%83%A9%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
