LPDDR4 settings for iMX8M
2,672 次查看
ani10c89
We have changed LPDDR4 part from MT53B512M32D2NP-062 WT:D to MT53D512M32D2DS-053 WT for iMX8M design.
We are getting below error log.
U-Boot SPL 2018.03-imx_v2018.03_4.14.78_1.0.0_ga+g11b4e6e (Jun 18 2019 - 08:18:38 +0000)
PMIC:  PFUZE100 ID=0x10
check ddr4_pmu_train_imem code
check ddr4_pmu_train_imem code pass
check ddr4_pmu_train_dmem code
check ddr4_pmu_train_dmem code pass
Training FAILED
Training FAILED
Training FAILED
Normal Boot
Trying to boot from MMC2
MMC Device 1 not found
spl: could not find mmc device. error: -19
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
Training FAILED
Training FAILED
Training FAILED
Normal Boot
Training FAILED
Training FAILED
Training FAILED
Normal Boot
Can you share LPDDR4 settings with the new part as we suspect the LPDDR4 settings only.
We are trying the DDRtool in parallel for configurations but it would be helpful if you can share the settings for this as this new part is supported for iMX8M.
Anirudha
标签 (1)
标记 (1)
3 回复数
2,346 次查看
Hi Anirudha
for new board or memory it is necessary to follow steps described in
Chapter 4 How to bring up a new MX8MSCALE board MSCALE_DDR_Tool_User_Guide.pdf
included in package
i.MX8 MSCALE SERIES DDR Tool Release (V2.10)
use latest uboot
imx8mq_evk\freescale\board - uboot-imx - i.MX U-Boot
2,346 次查看
ani10c89
Thanks for response.
Can you please confirm if MT53D1024M32D4DT-053 WT:D is tested with iMX8M and the quad die is not issue.
Anirudha
2,346 次查看
yes it is recommended for usage:
