LPDDR4 Calibration Fail on IMX8MP
4,118 次查看
prashanthk_k
I am using 4GB LPDDR4 (MT53E1G32D2FW-046 IT:C) on iMX8MP custom board.
While performing DDR calibration with MSCALE tool, I am facing below issue.
Download is complete
Waiting for the target board boot...
===================hardware_init=====================
********Found PMIC PCA9450**********
hardware_init exit
MX8 DDR Stress Test V3.30
Built on Nov 24 2021 13:52:12
Waiting for board configuration from PC-end...
--Set up the MMU and enable I and D cache--
- This is the Cortex-A53 core
- Check if I cache is enabled
- Enabling I cache since it was disabled
- Push base address of TTB to TTBR0_EL3
- Config TCR_EL3
- Config MAIR_EL3
- Enable MMU
- Data Cache has been enabled
- Check system memory register, only for debug
- VMCR Check:
- ttbr0_el3: 0x97d000
- tcr_el3: 0x2051c
- mair_el3: 0x774400
- sctlr_el3: 0xc01815
- id_aa64mmfr0_el1: 0x1122
- MMU and cache setup complete
ARM clock(CA53) rate: 1800MHz
DDR Clock: 2000MHz
DDR configuration
DDR type is LPDDR4
Data width: 32, bank num: 8
Row size: 17, col size: 10
One chip select is used
Number of DDR controllers used on the SoC: 1
Density per chip select: 4096MB
Density per controller is: 4096MB
Total density detected on the board is: 4096MB
MX8M-plus: Cortex-A53 is found
============ Step 1: DDRPHY Training... ============
---DDR 1D-Training @2000Mhz...
[Process] End of CA training
[Process] End of initialization
[Process] End of read enable training
[Process] End of fine write leveling
[Process] End of read DQ deskew training
[Process] End of MPR read delay center optimization
[Process] End of Write Leveling coarse delay
[Process] End of write delay center optimization
[Process] End of read delay center optimization
[Process] End of max read latency training
[Result] PASS
---DDR 1D-Training @200Mhz...
[Result] PASS
---DDR 1D-Training @50Mhz...
[Result] PASS
---DDR 2D-Training @2000Mhz...
[Process] End of 2D write delay/voltage center optimization
[Process] End of 2D read delay/voltage center optimization
[Result] PASS
============ Step 2: DDR memory accessing... ============
Verifying DDR frequency [email protected] of failure: 0x0000000040080000
Data read was: 0x0000000040000010
But pattern was: 0x0000000040000000
Failed
Please modify DDRC/DFI parameters!!!
NXP iMX/MSCALE tool Version - 3.31
iMX8MP RPA Tool version - v9
The DDR configuration updated on RPA tool as below for reference.
Please someone can help how to fix 'Please modify DDRC/DFI parameters' for LPDDR4 on IMX8MPLUS board.
Prashanth K
4,093 次查看
pengyong_zhang
Hi, @prashanthk_k
 i will support your this problem on your case https://nxp.lightning.force.com/lightning/r/Case/5002p00002zp06EAAQ/view, So please close this ticket, and  see the reply on case 00626079.
B.R
4 回复数
3,511 次查看
bozsahin
Hello, I’m getting the same fail. I'm using THE MT53E1G32D2FW . Could you please share how you resolved it? I’d appreciate your help.
Data read was: 0x0000000040000020
Failed
4,094 次查看
pengyong_zhang
Hi, @prashanthk_k
B.R
3,299 次查看
Zhirong_Yang
Hi @pengyong_zhang
I am facing the same failure on DDR calibration, and I can not access below link https://nxp.lightning.force.com/lightning/r/Case/5002p00002zp06EAAQ/view, is there any way to view this link?
3,327 次查看
Zhirong_Yang
%3CLINGO-SUB%20id%3D%22lingo-sub-1886645%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8MP%20%E4%B8%8A%E7%9A%84%20LPDDR4%20%E6%A0%A1%E5%87%86%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1886645%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%20iMX8MP%20%E5%AE%9A%E5%88%B6%E6%9D%BF%E4%B8%8A%E4%BD%BF%E7%94%A8%204GB%20LPDDR4%EF%BC%88MT53E1G32D2FW-046%20IT%3AC%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E4%BD%BF%E7%94%A8%20MSCALE%20%E5%B7%A5%E5%85%B7%E6%89%A7%E8%A1%8C%20DDR%20%E6%A0%A1%E5%87%86%E6%97%B6%EF%BC%8C%E6%88%91%E9%81%87%E5%88%B0%E4%BB%A5%E4%B8%8B%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSTRONG%3E%E4%B8%8B%E8%BD%BD%E5%AE%8C%E6%88%90%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E7%AD%89%E5%BE%85%E7%9B%AE%E6%A0%87%E6%9D%BF%E5%90%AF%E5%8A%A8...%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3Dhardware_init%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSTRONG%3E********%E6%89%BE%E5%88%B0PMIC%20PCA9450**********%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3Ehardware_init%E9%80%80%E5%87%BA%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E*************************************************************************%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E*************************************************************************%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E*************************************************************************%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3EMX8%20DDR%E5%8E%8B%E5%8A%9B%E6%B5%8B%E8%AF%95V3.30%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E6%9E%84%E5%BB%BA%E4%BA%8E%202021%20%E5%B9%B4%2011%20%E6%9C%88%2024%20%E6%97%A5%2013%3A52%3A12%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3E*************************************************************************%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E7%AD%89%E5%BE%85%20PC%20%E7%AB%AF%E7%9A%84%E6%9D%BF%E9%85%8D%E7%BD%AE...%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E--%E8%AE%BE%E7%BD%AEMMU%E5%B9%B6%E5%90%AF%E7%94%A8I%E5%92%8CD%E7%BC%93%E5%AD%98--%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20%E8%BF%99%E6%98%AF%20Cortex-A53%20%E6%A0%B8%E5%BF%83%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20%E6%A3%80%E6%9F%A5%E7%BC%93%E5%AD%98%E6%98%AF%E5%90%A6%E5%B7%B2%E5%90%AF%E7%94%A8%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20%E5%90%AF%E7%94%A8%20I%20%E7%BC%93%E5%AD%98%EF%BC%88%E4%B9%8B%E5%89%8D%E5%B7%B2%E7%A6%81%E7%94%A8%EF%BC%89%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3E-%20%E5%B0%86%20TTB%20%E7%9A%84%E5%9F%BA%E5%9C%B0%E5%9D%80%E6%8E%A8%E9%80%81%E5%88%B0%20TTBR0_EL3%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3E-%20%E9%85%8D%E7%BD%AETCR_EL3%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3E-%20%E9%85%8D%E7%BD%AE%20MAIR_EL3%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3E-%20%E5%90%AF%E7%94%A8MMU%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3E-%20%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98%E5%B7%B2%E5%90%AF%E7%94%A8%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20%E6%A3%80%E6%9F%A5%E7%B3%BB%E7%BB%9F%E5%86%85%E5%AD%98%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E4%BB%85%E7%94%A8%E4%BA%8E%E8%B0%83%E8%AF%95%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E-%20VMCR%20%E6%A3%80%E6%9F%A5%EF%BC%9A%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3E-%20ttbr0_el3%EF%BC%9A0x97d000%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3E-%20tcr_el3%EF%BC%9A0x2051c%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3E-%20mair_el3%EF%BC%9A0x774400%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3E-%20sctlr_el3%EF%BC%9A0xc01815%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3E-id_aa64mmfr0_el1%EF%BC%9A0x1122%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E-%20MMU%20%E5%92%8C%E7%BC%93%E5%AD%98%E8%AE%BE%E7%BD%AE%E5%AE%8C%E6%88%90%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E*************************************************************************%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3EARM%E6%97%B6%E9%92%9F(CA53)%E9%80%9F%E7%8E%87%EF%BC%9A1800MHz%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3EDDR%E6%97%B6%E9%92%9F%EF%BC%9A2000MHz%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3EDDR%E9%85%8D%E7%BD%AE%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EDDR%E7%B1%BB%E5%9E%8B%E4%B8%BALPDDR4%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E6%95%B0%E6%8D%AE%E5%AE%BD%E5%BA%A6%EF%BC%9A32%EF%BC%8Cbank%E6%95%B0%EF%BC%9A8%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E8%A1%8C%E5%A4%A7%E5%B0%8F%EF%BC%9A17%EF%BC%8C%E5%88%97%E5%A4%A7%E5%B0%8F%EF%BC%9A10%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E4%BD%BF%E7%94%A8%E4%B8%80%E4%B8%AA%E7%89%87%E9%80%89%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3ESoC%20%E4%B8%8A%E4%BD%BF%E7%94%A8%E7%9A%84%20DDR%20%E6%8E%A7%E5%88%B6%E5%99%A8%E6%95%B0%E9%87%8F%EF%BC%9A1%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E6%AF%8F%E8%8A%AF%E7%89%87%E5%AF%86%E5%BA%A6%E9%80%89%E6%8B%A9%EF%BC%9A4096MB%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E6%AF%8F%E4%B8%AA%E6%8E%A7%E5%88%B6%E5%99%A8%E7%9A%84%E5%AF%86%E5%BA%A6%E4%B8%BA%EF%BC%9A4096MB%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E4%B8%BB%E6%9D%BF%E4%B8%8A%E6%A3%80%E6%B5%8B%E5%88%B0%E7%9A%84%E6%80%BB%E5%AF%86%E5%BA%A6%E4%B8%BA%EF%BC%9A4096MB%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EMX8M-plus%EF%BC%9A%E5%8F%91%E7%8E%B0Cortex-A53%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E*************************************************************************%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E6%AD%A5%E9%AA%A4%201%EF%BC%9ADDRPHY%20%E8%AE%AD%E7%BB%83...%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3E---DDR%201D%20%E8%AE%AD%E7%BB%83%402000Mhz...%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%20CA%E5%9F%B9%E8%AE%AD%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E5%A4%84%E7%90%86%5D%20%E5%88%9D%E5%A7%8B%E5%8C%96%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%20%E8%AF%BB%E5%8F%96%E4%BD%BF%E8%83%BD%E8%AE%AD%E7%BB%83%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%20%E7%BB%86%E5%86%99%E8%B0%83%E5%B9%B3%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%20%E8%AF%BB%E5%8F%96DQ%E5%8E%BB%E6%AD%AA%E6%96%9C%E8%AE%AD%E7%BB%83%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%20MPR%E8%AF%BB%E5%8F%96%E5%BB%B6%E8%BF%9F%E4%B8%AD%E5%BF%83%E4%BC%98%E5%8C%96%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E8%BF%9B%E7%A8%8B%5D%20%E5%86%99%E5%85%A5%E5%9D%87%E8%A1%A1%E7%B2%97%E7%95%A5%E5%BB%B6%E8%BF%9F%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%20%E5%86%99%E5%85%A5%E5%BB%B6%E8%BF%9F%E4%B8%AD%E5%BF%83%E4%BC%98%E5%8C%96%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%20%E8%AF%BB%E5%8F%96%E5%BB%B6%E8%BF%9F%E4%B8%AD%E5%BF%83%E4%BC%98%E5%8C%96%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%20%E6%9C%80%E5%A4%A7%E8%AF%BB%E5%8F%96%E5%BB%B6%E8%BF%9F%E8%AE%AD%E7%BB%83%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E7%BB%93%E6%9E%9C%5D%20%E9%80%9A%E8%BF%87%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E---DDR%201D%20%E8%AE%AD%E7%BB%83%40200Mhz...%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%20CA%E5%9F%B9%E8%AE%AD%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E5%A4%84%E7%90%86%5D%20%E5%88%9D%E5%A7%8B%E5%8C%96%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%20%E8%AF%BB%E5%8F%96%E4%BD%BF%E8%83%BD%E8%AE%AD%E7%BB%83%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%20%E7%BB%86%E5%86%99%E8%B0%83%E5%B9%B3%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%20MPR%E8%AF%BB%E5%8F%96%E5%BB%B6%E8%BF%9F%E4%B8%AD%E5%BF%83%E4%BC%98%E5%8C%96%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E8%BF%9B%E7%A8%8B%5D%20%E5%86%99%E5%85%A5%E5%9D%87%E8%A1%A1%E7%B2%97%E7%95%A5%E5%BB%B6%E8%BF%9F%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%20%E5%86%99%E5%85%A5%E5%BB%B6%E8%BF%9F%E4%B8%AD%E5%BF%83%E4%BC%98%E5%8C%96%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%20%E8%AF%BB%E5%8F%96%E5%BB%B6%E8%BF%9F%E4%B8%AD%E5%BF%83%E4%BC%98%E5%8C%96%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%20%E6%9C%80%E5%A4%A7%E8%AF%BB%E5%8F%96%E5%BB%B6%E8%BF%9F%E8%AE%AD%E7%BB%83%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E7%BB%93%E6%9E%9C%5D%20%E9%80%9A%E8%BF%87%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E---DDR%201D%20%E8%AE%AD%E7%BB%83%4050Mhz...%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%20CA%E5%9F%B9%E8%AE%AD%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E5%A4%84%E7%90%86%5D%20%E5%88%9D%E5%A7%8B%E5%8C%96%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%20%E8%AF%BB%E5%8F%96%E4%BD%BF%E8%83%BD%E8%AE%AD%E7%BB%83%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%20%E7%BB%86%E5%86%99%E8%B0%83%E5%B9%B3%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%20MPR%E8%AF%BB%E5%8F%96%E5%BB%B6%E8%BF%9F%E4%B8%AD%E5%BF%83%E4%BC%98%E5%8C%96%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E8%BF%9B%E7%A8%8B%5D%20%E5%86%99%E5%85%A5%E5%9D%87%E8%A1%A1%E7%B2%97%E7%95%A5%E5%BB%B6%E8%BF%9F%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%20%E5%86%99%E5%85%A5%E5%BB%B6%E8%BF%9F%E4%B8%AD%E5%BF%83%E4%BC%98%E5%8C%96%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%20%E8%AF%BB%E5%8F%96%E5%BB%B6%E8%BF%9F%E4%B8%AD%E5%BF%83%E4%BC%98%E5%8C%96%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%20%E6%9C%80%E5%A4%A7%E8%AF%BB%E5%8F%96%E5%BB%B6%E8%BF%9F%E8%AE%AD%E7%BB%83%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E7%BB%93%E6%9E%9C%5D%20%E9%80%9A%E8%BF%87%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E---DDR%202D%20%E8%AE%AD%E7%BB%83%402000Mhz...%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3E%5B%E5%A4%84%E7%90%86%5D%20%E5%88%9D%E5%A7%8B%E5%8C%96%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%202D%E5%86%99%E5%85%A5%E5%BB%B6%E8%BF%9F%2F%E7%94%B5%E5%8E%8B%E4%B8%AD%E5%BF%83%E4%BC%98%E5%8C%96%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%202D%E5%86%99%E5%85%A5%E5%BB%B6%E8%BF%9F%2F%E7%94%B5%E5%8E%8B%E4%B8%AD%E5%BF%83%E4%BC%98%E5%8C%96%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%202D%E8%AF%BB%E5%8F%96%E5%BB%B6%E8%BF%9F%2F%E7%94%B5%E5%8E%8B%E4%B8%AD%E5%BF%83%E4%BC%98%E5%8C%96%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E6%B5%81%E7%A8%8B%5D%202D%E8%AF%BB%E5%8F%96%E5%BB%B6%E8%BF%9F%2F%E7%94%B5%E5%8E%8B%E4%B8%AD%E5%BF%83%E4%BC%98%E5%8C%96%E7%BB%93%E6%9D%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%5B%E7%BB%93%E6%9E%9C%5D%20%E9%80%9A%E8%BF%87%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E6%AD%A5%E9%AA%A4%202%EF%BC%9ADDR%20%E5%86%85%E5%AD%98%E8%AE%BF%E9%97%AE...%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E9%AA%8C%E8%AF%81DDR%E9%A2%91%E7%8E%87%E7%82%B90%402000MHz......%E5%A4%B1%E8%B4%A5%E5%9C%B0%E5%9D%80%EF%BC%9A0x0000000040080000%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E8%AF%BB%E5%8F%96%E7%9A%84%E6%95%B0%E6%8D%AE%E4%B8%BA%EF%BC%9A0x0000000040000010%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E4%BD%86%E6%A8%A1%E5%BC%8F%E6%98%AF%EF%BC%9A0x0000000040000000%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E5%A4%B1%E8%B4%A5%E7%9A%84%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E8%AF%B7%E4%BF%AE%E6%94%B9DDRC%2FDFI%E5%8F%82%E6%95%B0%EF%BC%81%EF%BC%81%EF%BC%81%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3ENXP%20iMX%2FMSCALE%20%E5%B7%A5%E5%85%B7%E7%89%88%E6%9C%AC%20-%203.31%3C%2FP%3E%3CP%3EiMX8MP%20RPA%20%E5%B7%A5%E5%85%B7%E7%89%88%E6%9C%AC%20-%20v9%3C%2FP%3E%3CP%3ERPA%20%E5%B7%A5%E5%85%B7%E4%B8%8A%E6%9B%B4%E6%96%B0%E7%9A%84%20DDR%20%E9%85%8D%E7%BD%AE%E5%A6%82%E4%B8%8B%EF%BC%8C%E4%BE%9B%E5%8F%82%E8%80%83%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22rpa_tool.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rpa_tool.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F283871i54B1E25B9CEF0A62%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22rpa_tool.png%22%20alt%3D%22rpa_tool.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%AF%B7%E6%9C%89%E4%BA%BA%E8%83%BD%E5%B8%AE%E5%BF%99%E4%BF%AE%E5%A4%8D%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FIMX8MPLUS%2Fpd-p%2FIMX8MPLUS%22%20class%3D%22lia-product-mention%22%20data-product%3D%2221-1%22%20target%3D%22_blank%22%3E%20IMX8MPLUS%3C%2FA%3E%20%E6%9D%BF%E4%B8%8A%20LPDDR4%3CSTRONG%3E%20%E7%9A%84%E2%80%9C%20%E8%AF%B7%E4%BF%AE%E6%94%B9%20DDRC%2FDFI%20%E5%8F%82%E6%95%B0%E2%80%9D%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%99%AE%E6%8B%89%E5%B0%9A%E7%89%B9%C2%B7K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2067049%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AIMX8MP%20%E4%B8%8A%E7%9A%84%20LPDDR4%20%E6%A0%A1%E5%87%86%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067049%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E5%9C%A8%20DDR%20%E6%A0%A1%E5%87%86%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E5%A4%B1%E8%B4%A5%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%97%A0%E6%B3%95%E8%AE%BF%E9%97%AE%E4%BB%A5%E4%B8%8B%E9%93%BE%E6%8E%A5%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.lightning.force.com%2Flightning%2Fr%2FCase%2F5002p00002zp06EAAQ%2Fview%2C%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.lightning.force.com%2Flightning%2Fr%2FCase%2F5002p00002zp06EAAQ%2Fview%EF%BC%8C%3C%2FA%3E%3CSPAN%3E%E6%9C%89%E4%BB%80%E4%B9%88%E6%96%B9%E6%B3%95%E5%8F%AF%E4%BB%A5%E6%9F%A5%E7%9C%8B%E6%AD%A4%E9%93%BE%E6%8E%A5%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2066197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AIMX8MP%20%E4%B8%8A%E7%9A%84%20LPDDR4%20%E6%A0%A1%E5%87%86%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2066197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%9C%A8%20DDR%20%E6%A0%A1%E5%87%86%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E5%A4%B1%E8%B4%A5%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%97%A0%E6%B3%95%E8%AE%BF%E9%97%AE%E4%BB%A5%E4%B8%8B%E9%93%BE%E6%8E%A5%3CA%20href%3D%22https%3A%2F%2Fnxp.lightning.force.com%2Flightning%2Fr%2FCase%2F5002p00002zp06EAAQ%2Fview%2C%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.lightning.force.com%2Flightning%2Fr%2FCase%2F5002p00002zp06EAAQ%2Fview%EF%BC%8C%3C%2FA%3E%E6%9C%89%E4%BB%80%E4%B9%88%E6%96%B9%E6%B3%95%E5%8F%AF%E4%BB%A5%E6%9F%A5%E7%9C%8B%E6%AD%A4%E9%93%BE%E6%8E%A5%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2035538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AIMX8MP%20%E4%B8%8A%E7%9A%84%20LPDDR4%20%E6%A0%A1%E5%87%86%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2035538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E5%A4%B1%E8%B4%A5%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20MT53E1G32D2FW%E3%80%82%E6%82%A8%E8%83%BD%E5%88%86%E4%BA%AB%E4%B8%80%E4%B8%8B%E6%82%A8%E6%98%AF%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E7%9A%84%E5%90%97%EF%BC%9F%E6%88%91%E5%B0%86%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E6%AD%A5%E9%AA%A4%202%EF%BC%9ADDR%20%E5%86%85%E5%AD%98%E8%AE%BF%E9%97%AE...%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%E9%AA%8C%E8%AF%81DDR%E9%A2%91%E7%8E%87%E7%82%B90%402000MHz......%E5%A4%B1%E8%B4%A5%E5%9C%B0%E5%9D%80%EF%BC%9A0x0000000040080000%3CBR%20%2F%3E%E8%AF%BB%E5%8F%96%E7%9A%84%E6%95%B0%E6%8D%AE%E4%B8%BA%EF%BC%9A0x0000000040000020%3CBR%20%2F%3E%E4%BD%86%E6%A8%A1%E5%BC%8F%E6%98%AF%EF%BC%9A0x0000000040000000%3CBR%20%2F%3E%E5%A4%B1%E8%B4%A5%E7%9A%84%3CBR%20%2F%3E%E8%AF%B7%E4%BF%AE%E6%94%B9DDRC%2FDFI%E5%8F%82%E6%95%B0%EF%BC%81%EF%BC%81%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1886727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AIMX8MP%20%E4%B8%8A%E7%9A%84%20LPDDR4%20%E6%A0%A1%E5%87%86%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1886727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F234740%22%20target%3D%22_blank%22%3E%40prashanthk_k%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%B0%86%E5%9C%A8%E6%82%A8%E7%9A%84%E6%A1%88%E4%BE%8B%E4%B8%AD%E6%94%AF%E6%8C%81%E6%82%A8%E8%A7%A3%E5%86%B3%E6%AD%A4%E9%97%AE%E9%A2%98%3CA%20href%3D%22https%3A%2F%2Fnxp.lightning.force.com%2Flightning%2Fr%2FCase%2F5002p00002zp06EAAQ%2Fview%2C%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.lightning.force.com%2Flightning%2Fr%2FCase%2F5002p00002zp06EAAQ%2Fview%EF%BC%8C%3C%2FA%3E%E5%9B%A0%E6%AD%A4%E8%AF%B7%E5%85%B3%E9%97%AD%E6%AD%A4%E7%A5%A8%EF%BC%8C%E5%B9%B6%E6%9F%A5%E7%9C%8B%E6%A1%88%E4%BE%8B%3CSPAN%3E00626079%20%E7%9A%84%E7%AD%94%E5%A4%8D%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EB.R%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
