LPDDR4 Calibration Fail on IMX8MP
4,086件の閲覧回数
prashanthk_k
I am using 4GB LPDDR4 (MT53E1G32D2FW-046 IT:C) on iMX8MP custom board.
While performing DDR calibration with MSCALE tool, I am facing below issue.
Download is complete
Waiting for the target board boot...
===================hardware_init=====================
********Found PMIC PCA9450**********
hardware_init exit
MX8 DDR Stress Test V3.30
Built on Nov 24 2021 13:52:12
Waiting for board configuration from PC-end...
--Set up the MMU and enable I and D cache--
- This is the Cortex-A53 core
- Check if I cache is enabled
- Enabling I cache since it was disabled
- Push base address of TTB to TTBR0_EL3
- Config TCR_EL3
- Config MAIR_EL3
- Enable MMU
- Data Cache has been enabled
- Check system memory register, only for debug
- VMCR Check:
- ttbr0_el3: 0x97d000
- tcr_el3: 0x2051c
- mair_el3: 0x774400
- sctlr_el3: 0xc01815
- id_aa64mmfr0_el1: 0x1122
- MMU and cache setup complete
ARM clock(CA53) rate: 1800MHz
DDR Clock: 2000MHz
DDR configuration
DDR type is LPDDR4
Data width: 32, bank num: 8
Row size: 17, col size: 10
One chip select is used
Number of DDR controllers used on the SoC: 1
Density per chip select: 4096MB
Density per controller is: 4096MB
Total density detected on the board is: 4096MB
MX8M-plus: Cortex-A53 is found
============ Step 1: DDRPHY Training... ============
---DDR 1D-Training @2000Mhz...
[Process] End of CA training
[Process] End of initialization
[Process] End of read enable training
[Process] End of fine write leveling
[Process] End of read DQ deskew training
[Process] End of MPR read delay center optimization
[Process] End of Write Leveling coarse delay
[Process] End of write delay center optimization
[Process] End of read delay center optimization
[Process] End of max read latency training
[Result] PASS
---DDR 1D-Training @200Mhz...
[Result] PASS
---DDR 1D-Training @50Mhz...
[Result] PASS
---DDR 2D-Training @2000Mhz...
[Process] End of 2D write delay/voltage center optimization
[Process] End of 2D read delay/voltage center optimization
[Result] PASS
============ Step 2: DDR memory accessing... ============
Verifying DDR frequency [email protected] of failure: 0x0000000040080000
Data read was: 0x0000000040000010
But pattern was: 0x0000000040000000
Failed
Please modify DDRC/DFI parameters!!!
NXP iMX/MSCALE tool Version - 3.31
iMX8MP RPA Tool version - v9
The DDR configuration updated on RPA tool as below for reference.
Please someone can help how to fix 'Please modify DDRC/DFI parameters' for LPDDR4 on IMX8MPLUS board.
Prashanth K
4,061件の閲覧回数
pengyong_zhang
Hi, @prashanthk_k
 i will support your this problem on your case https://nxp.lightning.force.com/lightning/r/Case/5002p00002zp06EAAQ/view, So please close this ticket, and  see the reply on case 00626079.
B.R
4 返答(返信)
3,479件の閲覧回数
bozsahin
Hello, I’m getting the same fail. I'm using THE MT53E1G32D2FW . Could you please share how you resolved it? I’d appreciate your help.
Data read was: 0x0000000040000020
Failed
4,062件の閲覧回数
pengyong_zhang
Hi, @prashanthk_k
B.R
3,267件の閲覧回数
Zhirong_Yang
Hi @pengyong_zhang
I am facing the same failure on DDR calibration, and I can not access below link https://nxp.lightning.force.com/lightning/r/Case/5002p00002zp06EAAQ/view, is there any way to view this link?
3,295件の閲覧回数
Zhirong_Yang
%3CLINGO-SUB%20id%3D%22lingo-sub-1886645%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX8MP%E3%81%A7LPDDR4%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1886645%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3Ei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hardware_init%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSTRONG%3EPMIC%20PCA9450**********%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Ehardware_init%E5%87%BA%E5%8F%A3%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E*************************************************************************%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E*************************************************************************%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E*************************************************************************%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EMX8%20DDR%E3%82%B9%E3%83%88%E3%83%AC%E3%82%B9%E3%83%86%E3%82%B9%E3%83%88V3.30%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E2021%E5%B9%B411%E6%9C%8824%E6%97%A5%2013%3A52%3A12%E3%81%AB%E6%A7%8B%E7%AF%89%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E*************************************************************************%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EPC%E3%82%A8%E3%83%B3%E3%83%89%E3%81%8B%E3%82%89%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E6%A7%8B%E6%88%90%E3%82%92%E5%BE%85%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E--MMU%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A8I%2FD%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E6%9C%89%E5%8A%B9%E5%8C%96--%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20Cortex-A53%E3%82%B3%E3%82%A2%E3%81%A7%E3%81%99%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20I%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20TTB%E3%81%AE%E3%83%99%E3%83%BC%E3%82%B9%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92TTBR0_EL3%E3%81%AB%E3%83%97%E3%83%83%E3%82%B7%E3%83%A5%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%B0TCR_EL3%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%B0MAIR_EL3%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20MMU%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E7%A2%BA%E8%AA%8D(%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AE%E3%81%BF)%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E-%20VMCR%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%3A%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20ttbr0_el3%3A0x97d000%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20tcr_el3%3A0x2051c%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20mair_el3%3A0x774400%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20sctlr_el3%3A0xc01815%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E-%20id_aa64mmfr0_el1%3A0x1122%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E-%20MMU%E3%81%A8%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E*************************************************************************%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EARM%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF(CA53)%E3%83%AC%E3%83%BC%E3%83%88%3A1800MHz%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EDDR%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A2000MHz%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EDDR%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EDDR%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AFLPDDR4%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%83%87%E3%83%BC%E3%82%BF%E5%B9%85%3A%2032%E3%80%81%E9%8A%80%E8%A1%8C%E7%95%AA%E5%8F%B7%3A%208%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E8%A1%8C%E3%82%B5%E3%82%A4%E3%82%BA%3A17%E3%80%81%E5%88%97%E3%82%B5%E3%82%A4%E3%82%BA%3A10%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E1%E3%81%A4%E3%81%AE%E3%83%81%E3%83%83%E3%83%97%E3%82%BB%E3%83%AC%E3%82%AF%E3%83%88%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3ESoC%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8BDDR%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AE%E6%95%B0%3A1%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%83%81%E3%83%83%E3%83%97%E3%82%BB%E3%83%AC%E3%82%AF%E3%83%88%E3%81%82%E3%81%9F%E3%82%8A%E3%81%AE%E5%AF%86%E5%BA%A6%3A4096MB%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%82%E3%81%9F%E3%82%8A%E3%81%AE%E5%AF%86%E5%BA%A6%3A%204096MB%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%9F%E5%90%88%E8%A8%88%E5%AF%86%E5%BA%A6%3A4096MB%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EMX8M-plus%3ACortex-A53%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E*************************************************************************%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%201%3A%20DDRPHY%20%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0...%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E---DDR%201D-%E8%A8%93%E7%B7%B4%402000Mhz...%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91CA%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%AE%E7%B5%82%E4%BA%86%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AE%E7%B5%82%E4%BA%86%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E7%B5%82%E4%BA%86%20enable%20%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91%E7%B4%B0%E3%81%8B%E3%81%84%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%AC%E3%83%99%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AE%E7%B5%82%E4%BA%86%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91%E3%83%AA%E3%83%BC%E3%83%89%E7%B5%82%E4%BA%86%E6%99%82%E3%81%AEDQ%E3%83%87%E3%82%B9%E3%82%AD%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91MPR%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E9%81%85%E5%BB%B6%E3%82%BB%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AE%E6%9C%80%E9%81%A9%E5%8C%96%E3%81%AE%E7%B5%82%E4%BA%86%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91%E3%83%A9%E3%82%A4%E3%83%88%E3%83%AC%E3%83%99%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AE%E7%B5%82%E4%BA%86%E3%81%AE%E7%B2%97%E3%81%84%E9%81%85%E5%BB%B6%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E7%B5%82%E4%BA%86%E9%81%85%E5%BB%B6%E3%82%BB%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AE%E6%9C%80%E9%81%A9%E5%8C%96%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E9%81%85%E5%BB%B6%E3%82%BB%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AE%E6%9C%80%E9%81%A9%E5%8C%96%E3%81%AE%E7%B5%82%E4%BA%86%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91%E6%9C%80%E5%A4%A7%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%81%AE%E7%B5%82%E4%BA%86%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E7%B5%90%E6%9E%9C%E3%80%91%E9%80%9A%E3%82%8B%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E---DDR%201D-%E8%A8%93%E7%B7%B4%40200Mhz...%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91CA%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%AE%E7%B5%82%E4%BA%86%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AE%E7%B5%82%E4%BA%86%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E7%B5%82%E4%BA%86%20enable%20%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91%E7%B4%B0%E3%81%8B%E3%81%84%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%AC%E3%83%99%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AE%E7%B5%82%E4%BA%86%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91MPR%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E9%81%85%E5%BB%B6%E3%82%BB%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AE%E6%9C%80%E9%81%A9%E5%8C%96%E3%81%AE%E7%B5%82%E4%BA%86%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91%E3%83%A9%E3%82%A4%E3%83%88%E3%83%AC%E3%83%99%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AE%E7%B5%82%E4%BA%86%E3%81%AE%E7%B2%97%E3%81%84%E9%81%85%E5%BB%B6%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E7%B5%82%E4%BA%86%E9%81%85%E5%BB%B6%E3%82%BB%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AE%E6%9C%80%E9%81%A9%E5%8C%96%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E9%81%85%E5%BB%B6%E3%82%BB%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AE%E6%9C%80%E9%81%A9%E5%8C%96%E3%81%AE%E7%B5%82%E4%BA%86%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91%E6%9C%80%E5%A4%A7%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%81%AE%E7%B5%82%E4%BA%86%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E7%B5%90%E6%9E%9C%E3%80%91%E9%80%9A%E3%82%8B%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E---DDR%201D-%E8%A8%93%E7%B7%B4%4050Mhz...%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91CA%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%AE%E7%B5%82%E4%BA%86%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AE%E7%B5%82%E4%BA%86%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E7%B5%82%E4%BA%86%20enable%20%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91%E7%B4%B0%E3%81%8B%E3%81%84%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%AC%E3%83%99%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AE%E7%B5%82%E4%BA%86%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91MPR%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E9%81%85%E5%BB%B6%E3%82%BB%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AE%E6%9C%80%E9%81%A9%E5%8C%96%E3%81%AE%E7%B5%82%E4%BA%86%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91%E3%83%A9%E3%82%A4%E3%83%88%E3%83%AC%E3%83%99%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AE%E7%B5%82%E4%BA%86%E3%81%AE%E7%B2%97%E3%81%84%E9%81%85%E5%BB%B6%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E7%B5%82%E4%BA%86%E9%81%85%E5%BB%B6%E3%82%BB%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AE%E6%9C%80%E9%81%A9%E5%8C%96%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E9%81%85%E5%BB%B6%E3%82%BB%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AE%E6%9C%80%E9%81%A9%E5%8C%96%E3%81%AE%E7%B5%82%E4%BA%86%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91%E6%9C%80%E5%A4%A7%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%AC%E3%82%A4%E3%83%86%E3%83%B3%E3%82%B7%E3%81%AE%E7%B5%82%E4%BA%86%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E7%B5%90%E6%9E%9C%E3%80%91%E9%80%9A%E3%82%8B%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E---DDR%202D-%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%402000Mhz...%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%91%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AE%E7%B5%82%E4%BA%86%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%912D%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E9%81%85%E5%BB%B6%E3%81%AE%E7%B5%82%E4%BA%86%2F%E9%9B%BB%E5%9C%A7%E3%82%BB%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AE%E6%9C%80%E9%81%A9%E5%8C%96%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%912D%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E9%81%85%E5%BB%B6%E3%81%AE%E7%B5%82%E4%BA%86%2F%E9%9B%BB%E5%9C%A7%E3%82%BB%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AE%E6%9C%80%E9%81%A9%E5%8C%96%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%912D%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E9%81%85%E5%BB%B6%E3%81%AE%E7%B5%82%E4%BA%86%2F%E9%9B%BB%E5%9C%A7%E4%B8%AD%E5%BF%83%E3%81%AE%E6%9C%80%E9%81%A9%E5%8C%96%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%80%912D%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E9%81%85%E5%BB%B6%E3%81%AE%E7%B5%82%E4%BA%86%2F%E9%9B%BB%E5%9C%A7%E4%B8%AD%E5%BF%83%E3%81%AE%E6%9C%80%E9%81%A9%E5%8C%96%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%80%90%E7%B5%90%E6%9E%9C%E3%80%91%E9%80%9A%E3%82%8B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%202%3A%20DDR%20%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9...%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EDDR%20%E5%91%A8%E6%B3%A2%E6%95%B0point0%402000MHz......%E3%81%AE%E7%A2%BA%E8%AA%8D%E9%9A%9C%E5%AE%B3%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A%200x0000000040080000%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%82%8C%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%3A%200x0000000040000010%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%91%E3%82%BF%E3%83%BC%E3%83%B3%E3%81%AF0x0000000040000000%E3%81%A7%E3%81%97%E3%81%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%E5%A4%B1%E6%95%97%20%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EDDRC%2FDFI%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84!!%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3ENXP%20iMX%2FMSCALE%E3%83%84%E3%83%BC%E3%83%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%20-%203.31%3C%2FP%3E%3CP%3EiMX8MP%20RPA%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%20-%20v9%3C%2FP%3E%3CP%3ERPA%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%9FDDR%E6%A7%8B%E6%88%90%E3%81%AF%E3%80%81%E5%8F%82%E7%85%A7%E7%94%A8%E3%81%AB%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22rpa_tool.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rpa_tool.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F283871i54B1E25B9CEF0A62%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22rpa_tool.png%22%20alt%3D%22rpa_tool.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AELPDDR4%E3%81%AE%E3%80%8C%3CSTRONG%3EDDRC%2FDFI%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSTRONG%3E%E3%80%8D%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FIMX8MPLUS%2Fpd-p%2FIMX8MPLUS%22%20class%3D%22lia-product-mention%22%20data-product%3D%2221-1%22%20target%3D%22_blank%22%3EIMX8MPLUS%3C%2FA%3E%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88K%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2067049%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AIMX8MP%E3%81%A7LPDDR4%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067049%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%3EDDR%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E5%90%8C%E3%81%98%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%20%3CA%20href%3D%22https%3A%2F%2Fnxp.lightning.force.com%2Flightning%2Fr%2FCase%2F5002p00002zp06EAAQ%2Fview%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.lightning.force.com%2Flightning%2Fr%2FCase%2F5002p00002zp06EAAQ%2Fview%3C%2FA%3E%20%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.lightning.force.com%2Flightning%2Fr%2FCase%2F5002p00002zp06EAAQ%2Fview%2C%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%81%8C%E3%80%81%3C%2FA%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2066197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AIMX8MP%E3%81%A7LPDDR4%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2066197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDDR%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E5%90%8C%E3%81%98%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%20%3CA%20href%3D%22https%3A%2F%2Fnxp.lightning.force.com%2Flightning%2Fr%2FCase%2F5002p00002zp06EAAQ%2Fview%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.lightning.force.com%2Flightning%2Fr%2FCase%2F5002p00002zp06EAAQ%2Fview%3C%2FA%3E%20%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CA%20href%3D%22https%3A%2F%2Fnxp.lightning.force.com%2Flightning%2Fr%2FCase%2F5002p00002zp06EAAQ%2Fview%2C%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%81%8C%E3%80%81%3C%2FA%3E%E3%81%93%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2035538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AIMX8MP%E3%81%A7LPDDR4%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2035538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%A7%81%E3%82%82%E5%90%8C%E3%81%98%E5%A4%B1%E6%95%97%E3%82%92%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AFMT53E1G32D2FW%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%9F%E3%81%AE%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%202%3A%20DDR%20%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9...%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3EDDR%20%E5%91%A8%E6%B3%A2%E6%95%B0point0%402000MHz......%E3%81%AE%E7%A2%BA%E8%AA%8D%E9%9A%9C%E5%AE%B3%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A%200x0000000040080000%3CBR%20%2F%3E%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%82%8C%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%3A%200x0000000040000020%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%91%E3%82%BF%E3%83%BC%E3%83%B3%E3%81%AF0x0000000040000000%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E5%A4%B1%E6%95%97%20%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EDDRC%2FDFI%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84!!%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1886727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AIMX8MP%E3%81%A7LPDDR4%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1886727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F234740%22%20target%3D%22_blank%22%3E%40prashanthk_k%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%B1%E3%83%BC%E3%82%B9%20%3CA%20href%3D%22https%3A%2F%2Fnxp.lightning.force.com%2Flightning%2Fr%2FCase%2F5002p00002zp06EAAQ%2Fview%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.lightning.force.com%2Flightning%2Fr%2FCase%2F5002p00002zp06EAAQ%2Fview%3C%2FA%3E%20%E3%81%A7%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%20%3CA%20href%3D%22https%3A%2F%2Fnxp.lightning.force.com%2Flightning%2Fr%2FCase%2F5002p00002zp06EAAQ%2Fview%2C%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%80%81%3C%2FA%3E%26nbsp%3B%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%81%93%E3%81%AE%E3%83%81%E3%82%B1%E3%83%83%E3%83%88%E3%82%92%E9%96%89%E3%81%98%E3%81%A6%E3%80%81%E3%82%B1%E3%83%BC%E3%82%B900626079%E3%81%AE%E8%BF%94%E4%BF%A1%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EB.R%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
